RTEMS 6.1-rc2
MIF_AUTHEN_CTRL - MIF Authentication Control
#define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK   (0x100000U)
#define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT   (20U)
#define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK)
MIF_MLPL_SLEEP - MIF MLPL control of SLEEP
#define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK)
MIF_MLPL_IG - MIF MLPL control of IG
#define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK)
MIF_MLPL_LS - MIF MLPL control of LS
#define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK)
MIF_MLPL_HS - MIF MLPL control of HS
#define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK)
MIF_MLPL_STDBY - MIF MLPL control of STDBY
#define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK)
MIF_MLPL_ARR_PDN - MIF MLPL control of array power down
#define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK)
MIF_MLPL_PER_PDN - MIF MLPL control of peripheral power down
#define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK)
MIF_MLPL_INITN - MIF MLPL control of INITN
#define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK)
#define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK   (0x80000000U)
#define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT   (31U)
#define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK)
MIF_MLPL_ISO - MIF MLPL control of isolation enable
#define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK   (0xFFFFU)
#define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT   (0U)
#define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG [1/2]
#define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT)) & PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK)
LOCK_CFG - Configuration lock
◆ PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG [2/2]
◆ PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK)
MLPL_CTRL - Signal behavior at each MLPL
◆ PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK [1/2]
#define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK)
BYPASS_VDD_OK - Bypass vdd_ok. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
◆ PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK [2/2]
◆ PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL [2/2]
◆ PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL [1/2]
#define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT)) & PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK)
◆ PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL [2/2]
