RTEMS 6.1-rc2
CFG_NUM_LANES - Lane Configuration Register
#define MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK   (0x3U)
#define MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT)) & MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK)
CFG_DISABLE_DATA_LANES - Disable Data Lane Register
#define MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK   (0xFU)
#define MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK)
BIT_ERR - ECC and CRC Error Status Register
#define MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK   (0x3FFU)
#define MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT   (0U)
#define MIPI_CSI2RX_BIT_ERR_BIT_ERR(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT)) & MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK)
IRQ_STATUS - IRQ Status Register
#define MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK   (0x1FFU)
#define MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT)) & MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK)
IRQ_MASK - IRQ Mask Setting Register
#define MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK   (0x1FFU)
#define MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT   (0U)
#define MIPI_CSI2RX_IRQ_MASK_IRQ_MASK(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT)) & MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK)
ULPS_STATUS - Ultra Low Power State (ULPS) Status Register
#define MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK   (0x3FFU)
#define MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_ULPS_STATUS_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT)) & MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK)
PPI_ERRSOT_HS - ERRSot HS Status Register
#define MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK   (0xFU)
#define MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK)
PPI_ERRSOTSYNC_HS - ErrSotSync HS Status Register
#define MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK   (0xFU)
#define MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK)
PPI_ERRESC - ErrEsc Status Register
#define MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK   (0xFU)
#define MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_PPI_ERRESC_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK)
PPI_ERRSYNCESC - ErrSyncEsc Status Register
#define MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK   (0xFU)
#define MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK)
PPI_ERRCONTROL - ErrControl Status Register
#define MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK   (0xFU)
#define MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT   (0U)
#define MIPI_CSI2RX_PPI_ERRCONTROL_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK)
CFG_DISABLE_PAYLOAD_0 - Disable Payload 0 Register
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK   (0x1U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK   (0x2U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT   (1U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK   (0x4U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT   (2U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK   (0x400U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT   (10U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK   (0x4000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT   (14U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK   (0x10000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT   (16U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK   (0x20000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT   (17U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK   (0x40000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT   (18U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK   (0x80000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT   (19U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK   (0x100000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT   (20U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK)
CFG_DISABLE_PAYLOAD_1 - Disable Payload 1 Register
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK   (0x1U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK   (0x2U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT   (1U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK   (0x4U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT   (2U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK   (0x8U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT   (3U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK   (0x10U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT   (4U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK   (0x20U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT   (5U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK   (0x40U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT   (6U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK   (0x80U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT   (7U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK   (0x10000U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT   (16U)
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK)
CFG_IGNORE_VC - Ignore Virtual Channel Register
#define MIPI_CSI2RX_CFG_IGNORE_VC_IGNORE_VC_MASK   (0x1U)
#define MIPI_CSI2RX_CFG_IGNORE_VC_IGNORE_VC_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_IGNORE_VC_IGNORE_VC(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_IGNORE_VC_IGNORE_VC_SHIFT)) & MIPI_CSI2RX_CFG_IGNORE_VC_IGNORE_VC_MASK)
CFG_VID_VC - Virtual Channel value Register
#define MIPI_CSI2RX_CFG_VID_VC_VID_VC_MASK   (0x3U)
#define MIPI_CSI2RX_CFG_VID_VC_VID_VC_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_VC_VID_VC(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_VC_VID_VC_SHIFT)) & MIPI_CSI2RX_CFG_VID_VC_VID_VC_MASK)
CFG_VID_P_FIFO_SEND_LEVEL - FIFO Send Level Configuration Register
#define MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK   (0xFFFFU)
#define MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT)) & MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK)
CFG_VID_VSYNC - VSYNC Configuration Register
#define MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK   (0xFFU)
#define MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK)
CFG_VID_HSYNC_FP - Start of HSYNC Delay control Register
#define MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK   (0xFFU)
#define MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK)
CFG_VID_HSYNC - HSYNC Configuration Register
#define MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK   (0xFFU)
#define MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK)
CFG_VID_HSYNC_BP - End of HSYNC Delay Control Register
#define MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK   (0xFFU)
#define MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT   (0U)
#define MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL(x)   (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK)
◆ MIPI_CSI2RX_BIT_ERR_BIT_ERR [1/2]
#define MIPI_CSI2RX_BIT_ERR_BIT_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT)) & MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK)
BIT_ERR - This field shows the error status of ECC and CRC
◆ MIPI_CSI2RX_BIT_ERR_BIT_ERR [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK)
CFG_DISABLE_DATA_LANES - This field is used to disable data lanes.
◆ MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK)
DIS_PAYLOAD_BLANK - Blank
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK)
DIS_PAYLOAD_EMBEDDED - Embedded
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK)
DIS_PAYLOAD_NULL - Null
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK)
DIS_PAYLOAD_RGB444 - RGB444
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK)
DIS_PAYLOAD_RGB555 - RGB555
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK)
DIS_PAYLOAD_RGB565 - RGB565
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK)
DIS_PAYLOAD_RGB666 - RGB666
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK)
DIS_PAYLOAD_RGB888 - RGB888
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK)
DIS_PAYLOAD_YUV420 - Legacy YUV 420 8 bit
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK)
DIS_PAYLOAD_YUV422_8BIT - YUV422 8 bit
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK)
DIS_PAYLOAD_UDEF_30 - User defined type 0x31
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK)
DIS_PAYLOAD_UDEF_31 - User defined type 0x32
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK)
DIS_PAYLOAD_UDEF_32 - User defined type 0x33
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK)
DIS_PAYLOAD_UDEF_33 - User defined type 0x34
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK)
DIS_PAYLOAD_UDEF_34 - User defined type 0x35
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK)
DIS_PAYLOAD_UDEF_35 - User defined type 0x35
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK)
DIS_PAYLOAD_UDEF_36 - User defined type 0x36
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37 [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37 (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK)
DIS_PAYLOAD_UDEF_37 - User defined type 0x37
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37 [2/2]
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED [1/2]
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK)
DIS_PAYLOAD_UNSUPPORTED - Unsupported Data Types
◆ MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED [2/2]
◆ MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES [1/2]
#define MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT)) & MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK)
CFG_NUM_LANES - This field is used to set the number of active lanes for receiving data. 0b00..1 Lane 0b01..2 Lane 0b10-0b11..Reserved
◆ MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES [2/2]
◆ MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL [1/2]
#define MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK)
DELAY_CTL - Delay Control for end of HSYNC pulse
◆ MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL [2/2]
◆ MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL [1/2]
#define MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK)
DELAY_CTL - Delay control for beginning of HSYNC pulse
◆ MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL [2/2]
◆ MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH [1/2]
#define MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK)
WIDTH - Width of HSYNC
◆ MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH [2/2]
◆ MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL [1/2]
#define MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT)) & MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK)
SEND_LEVEL - FIFO Send Level field
◆ MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL [2/2]
◆ MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH [1/2]
#define MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK)
WIDTH - Width of VSYNC
◆ MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH [2/2]
◆ MIPI_CSI2RX_IRQ_MASK_IRQ_MASK [1/2]
#define MIPI_CSI2RX_IRQ_MASK_IRQ_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT)) & MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK)
IRQ_MASK - This field shows the IRQ Mask setting
◆ MIPI_CSI2RX_IRQ_MASK_IRQ_MASK [2/2]
◆ MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS [1/2]
#define MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT)) & MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK)
IRQ_STATUS - This field shows the IRQ status
◆ MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS [2/2]
◆ MIPI_CSI2RX_PPI_ERRCONTROL_STATUS [1/2]
#define MIPI_CSI2RX_PPI_ERRCONTROL_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK)
STATUS - This field indicates PPI ErrControl captured status from D-PHY
◆ MIPI_CSI2RX_PPI_ERRCONTROL_STATUS [2/2]
◆ MIPI_CSI2RX_PPI_ERRESC_STATUS [1/2]
#define MIPI_CSI2RX_PPI_ERRESC_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK)
STATUS - This field indicates PPI ErrEsc captured status from D-PHY
◆ MIPI_CSI2RX_PPI_ERRESC_STATUS [2/2]
◆ MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS [1/2]
#define MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK)
STATUS - This field indicates PPI ErrSotHS captured status from D-PHY
◆ MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS [2/2]
◆ MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS [1/2]
#define MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK)
STATUS - This field indicates PPI ErrSotSync_HS captured status from D-PHY
◆ MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS [2/2]
◆ MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS [1/2]
#define MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK)
STATUS - This field indicates PPI ErrSyncEsc captured status from D-PHY
◆ MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS [2/2]
◆ MIPI_CSI2RX_ULPS_STATUS_STATUS [1/2]
#define MIPI_CSI2RX_ULPS_STATUS_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT)) & MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK)
STATUS - This field shows the status of Rx D-PHY ULPS state
◆ MIPI_CSI2RX_ULPS_STATUS_STATUS [2/2]
