RTEMS 6.1-rc2
Macros | Typedefs | Enumerations
Interrupt Controller Common Definitions
#define ALT_INT_ICCIAR_CPUID_GET(icciar)   ((icciar >> 10) & 0x7)
#define ALT_INT_ICCIAR_ACKINTID_GET(icciar)   (icciar & 0x3FF)
typedef enum ALT_INT_INTERRUPT_e ALT_INT_INTERRUPT_t
typedef uint32_t alt_int_cpu_target_t
typedef enum ALT_INT_TRIGGER_e ALT_INT_TRIGGER_t
typedef enum ALT_INT_SGI_TARGET_e ALT_INT_SGI_TARGET_t
typedef void(* alt_int_callback_t) (uint32_t icciar, void *context)
enum  ALT_INT_INTERRUPT_e {
  ALT_INT_INTERRUPT_SGI0 = 0 , ALT_INT_INTERRUPT_SGI1 = 1 , ALT_INT_INTERRUPT_SGI2 = 2 , ALT_INT_INTERRUPT_SGI3 = 3 ,
  ALT_INT_INTERRUPT_SGI4 = 4 , ALT_INT_INTERRUPT_SGI5 = 5 , ALT_INT_INTERRUPT_SGI6 = 6 , ALT_INT_INTERRUPT_SGI7 = 7 ,
  ALT_INT_INTERRUPT_SGI8 = 8 , ALT_INT_INTERRUPT_SGI9 = 9 , ALT_INT_INTERRUPT_SGI10 = 10 , ALT_INT_INTERRUPT_SGI11 = 11 ,
  ALT_INT_INTERRUPT_SGI12 = 12 , ALT_INT_INTERRUPT_SGI13 = 13 , ALT_INT_INTERRUPT_SGI14 = 14 , ALT_INT_INTERRUPT_SGI15 = 15 ,
  ALT_INT_INTERRUPT_PPI_TIMER_GLOBAL = 27 , ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE = 29 , ALT_INT_INTERRUPT_PPI_TIMER_WATCHDOG = 30 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL = 32 ,
  ALT_INT_INTERRUPT_CPU0_PARITYFAIL_BTAC = 33 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_GHB = 34 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_TAG = 35 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_DATA = 36 ,
  ALT_INT_INTERRUPT_CPU0_PARITYFAIL_TLB = 37 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_OUTER = 38 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_TAG = 39 , ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_DATA = 40 ,
  ALT_INT_INTERRUPT_CPU0_DEFLAGS0 = 41 , ALT_INT_INTERRUPT_CPU0_DEFLAGS1 = 42 , ALT_INT_INTERRUPT_CPU0_DEFLAGS2 = 43 , ALT_INT_INTERRUPT_CPU0_DEFLAGS3 = 44 ,
  ALT_INT_INTERRUPT_CPU0_DEFLAGS4 = 45 , ALT_INT_INTERRUPT_CPU0_DEFLAGS5 = 46 , ALT_INT_INTERRUPT_CPU0_DEFLAGS6 = 47 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL = 48 ,
  ALT_INT_INTERRUPT_CPU1_PARITYFAIL_BTAC = 49 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_GHB = 50 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_TAG = 51 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_DATA = 52 ,
  ALT_INT_INTERRUPT_CPU1_PARITYFAIL_TLB = 53 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_OUTER = 54 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_TAG = 55 , ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_DATA = 56 ,
  ALT_INT_INTERRUPT_CPU1_DEFLAGS0 = 57 , ALT_INT_INTERRUPT_CPU1_DEFLAGS1 = 58 , ALT_INT_INTERRUPT_CPU1_DEFLAGS2 = 59 , ALT_INT_INTERRUPT_CPU1_DEFLAGS3 = 60 ,
  ALT_INT_INTERRUPT_CPU1_DEFLAGS4 = 61 , ALT_INT_INTERRUPT_CPU1_DEFLAGS5 = 62 , ALT_INT_INTERRUPT_CPU1_DEFLAGS6 = 63 , ALT_INT_INTERRUPT_SCU_PARITYFAIL0 = 64 ,
  ALT_INT_INTERRUPT_SCU_PARITYFAIL1 = 65 , ALT_INT_INTERRUPT_SCU_EV_ABORT = 66 , ALT_INT_INTERRUPT_L2_ECC_BYTE_WR_IRQ = 67 , ALT_INT_INTERRUPT_L2_ECC_CORRECTED_IRQ = 68 ,
  ALT_INT_INTERRUPT_L2_ECC_UNCORRECTED_IRQ = 69 , ALT_INT_INTERRUPT_L2_COMBINED_IRQ = 70 , ALT_INT_INTERRUPT_DDR_ECC_ERROR_IRQ = 71 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ0 = 72 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ1 = 73 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ2 = 74 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ3 = 75 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ4 = 76 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ5 = 77 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ6 = 78 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ7 = 79 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ8 = 80 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ9 = 81 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ10 = 82 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ11 = 83 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ12 = 84 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ13 = 85 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ14 = 86 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ15 = 87 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ16 = 88 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ17 = 89 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ18 = 90 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ19 = 91 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ20 = 92 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ21 = 93 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ22 = 94 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ23 = 95 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ24 = 96 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ25 = 97 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ26 = 98 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ27 = 99 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ28 = 100 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ29 = 101 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ30 = 102 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ31 = 103 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ32 = 104 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ33 = 105 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ34 = 106 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ35 = 107 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ36 = 108 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ37 = 109 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ38 = 110 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ39 = 111 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ40 = 112 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ41 = 113 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ42 = 114 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ43 = 115 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ44 = 116 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ45 = 117 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ46 = 118 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ47 = 119 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ48 = 120 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ49 = 121 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ50 = 122 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ51 = 123 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ52 = 124 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ53 = 125 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ54 = 126 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ55 = 127 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ56 = 128 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ57 = 129 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ58 = 130 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ59 = 131 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ60 = 132 ,
  ALT_INT_INTERRUPT_F2S_FPGA_IRQ61 = 133 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ62 = 134 , ALT_INT_INTERRUPT_F2S_FPGA_IRQ63 = 135 , ALT_INT_INTERRUPT_DMA_IRQ0 = 136 ,
  ALT_INT_INTERRUPT_DMA_IRQ1 = 137 , ALT_INT_INTERRUPT_DMA_IRQ2 = 138 , ALT_INT_INTERRUPT_DMA_IRQ3 = 139 , ALT_INT_INTERRUPT_DMA_IRQ4 = 140 ,
  ALT_INT_INTERRUPT_DMA_IRQ5 = 141 , ALT_INT_INTERRUPT_DMA_IRQ6 = 142 , ALT_INT_INTERRUPT_DMA_IRQ7 = 143 , ALT_INT_INTERRUPT_DMA_IRQ_ABORT = 144 ,
  ALT_INT_INTERRUPT_DMA_ECC_CORRECTED_IRQ = 145 , ALT_INT_INTERRUPT_DMA_ECC_UNCORRECTED_IRQ = 146 , ALT_INT_INTERRUPT_EMAC0_IRQ = 147 , ALT_INT_INTERRUPT_EMAC0_TX_ECC_CORRECTED_IRQ = 148 ,
  ALT_INT_INTERRUPT_EMAC0_TX_ECC_UNCORRECTED_IRQ = 149 , ALT_INT_INTERRUPT_EMAC0_RX_ECC_CORRECTED_IRQ = 150 , ALT_INT_INTERRUPT_EMAC0_RX_ECC_UNCORRECTED_IRQ = 151 , ALT_INT_INTERRUPT_EMAC1_IRQ = 152 ,
  ALT_INT_INTERRUPT_EMAC1_TX_ECC_CORRECTED_IRQ = 153 , ALT_INT_INTERRUPT_EMAC1_TX_ECC_UNCORRECTED_IRQ = 154 , ALT_INT_INTERRUPT_EMAC1_RX_ECC_CORRECTED_IRQ = 155 , ALT_INT_INTERRUPT_EMAC1_RX_ECC_UNCORRECTED_IRQ = 156 ,
  ALT_INT_INTERRUPT_USB0_IRQ = 157 , ALT_INT_INTERRUPT_USB0_ECC_CORRECTED = 158 , ALT_INT_INTERRUPT_USB0_ECC_UNCORRECTED = 159 , ALT_INT_INTERRUPT_USB1_IRQ = 160 ,
  ALT_INT_INTERRUPT_USB1_ECC_CORRECTED = 161 , ALT_INT_INTERRUPT_USB1_ECC_UNCORRECTED = 162 , ALT_INT_INTERRUPT_CAN0_STS_IRQ = 163 , ALT_INT_INTERRUPT_CAN0_MO_IRQ = 164 ,
  ALT_INT_INTERRUPT_CAN0_ECC_CORRECTED_IRQ = 165 , ALT_INT_INTERRUPT_CAN0_ECC_UNCORRECTED_IRQ = 166 , ALT_INT_INTERRUPT_CAN1_STS_IRQ = 167 , ALT_INT_INTERRUPT_CAN1_MO_IRQ = 168 ,
  ALT_INT_INTERRUPT_CAN1_ECC_CORRECTED_IRQ = 169 , ALT_INT_INTERRUPT_CAN1_ECC_UNCORRECTED_IRQ = 170 , ALT_INT_INTERRUPT_SDMMC_IRQ = 171 , ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_CORRECTED = 172 ,
  ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_UNCORRECTED = 173 , ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_CORRECTED = 174 , ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_UNCORRECTED = 175 , ALT_INT_INTERRUPT_NAND_IRQ = 176 ,
  ALT_INT_INTERRUPT_NANDR_ECC_CORRECTED_IRQ = 177 , ALT_INT_INTERRUPT_NANDR_ECC_UNCORRECTED_IRQ = 178 , ALT_INT_INTERRUPT_NANDW_ECC_CORRECTED_IRQ = 179 , ALT_INT_INTERRUPT_NANDW_ECC_UNCORRECTED_IRQ = 180 ,
  ALT_INT_INTERRUPT_NANDE_ECC_CORRECTED_IRQ = 181 , ALT_INT_INTERRUPT_NANDE_ECC_UNCORRECTED_IRQ = 182 , ALT_INT_INTERRUPT_QSPI_IRQ = 183 , ALT_INT_INTERRUPT_QSPI_ECC_CORRECTED_IRQ = 184 ,
  ALT_INT_INTERRUPT_QSPI_ECC_UNCORRECTED_IRQ = 185 , ALT_INT_INTERRUPT_SPI0_IRQ = 186 , ALT_INT_INTERRUPT_SPI1_IRQ = 187 , ALT_INT_INTERRUPT_SPI2_IRQ = 188 ,
  ALT_INT_INTERRUPT_SPI3_IRQ = 189 , ALT_INT_INTERRUPT_I2C0_IRQ = 190 , ALT_INT_INTERRUPT_I2C1_IRQ = 191 , ALT_INT_INTERRUPT_I2C2_IRQ = 192 ,
  ALT_INT_INTERRUPT_I2C3_IRQ = 193 , ALT_INT_INTERRUPT_UART0 = 194 , ALT_INT_INTERRUPT_UART1 = 195 , ALT_INT_INTERRUPT_GPIO0 = 196 ,
  ALT_INT_INTERRUPT_GPIO1 = 197 , ALT_INT_INTERRUPT_GPIO2 = 198 , ALT_INT_INTERRUPT_TIMER_L4SP_0_IRQ = 199 , ALT_INT_INTERRUPT_TIMER_L4SP_1_IRQ = 200 ,
  ALT_INT_INTERRUPT_TIMER_OSC1_0_IRQ = 201 , ALT_INT_INTERRUPT_TIMER_OSC1_1_IRQ = 202 , ALT_INT_INTERRUPT_WDOG0_IRQ = 203 , ALT_INT_INTERRUPT_WDOG1_IRQ = 204 ,
  ALT_INT_INTERRUPT_CLKMGR_IRQ = 205 , ALT_INT_INTERRUPT_MPUWAKEUP_IRQ = 206 , ALT_INT_INTERRUPT_FPGA_MAN_IRQ = 207 , ALT_INT_INTERRUPT_NCTIIRQ0 = 208 ,
  ALT_INT_INTERRUPT_NCTIIRQ1 = 209 , ALT_INT_INTERRUPT_RAM_ECC_CORRECTED_IRQ = 210 , ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ = 211
enum  ALT_INT_TRIGGER_e {
  ALT_INT_TRIGGER_EDGE , ALT_INT_TRIGGER_LEVEL , ALT_INT_TRIGGER_SOFTWARE , ALT_INT_TRIGGER_AUTODETECT ,
  ALT_INT_TRIGGER_NA
enum  ALT_INT_SGI_TARGET_e { ALT_INT_SGI_TARGET_LIST , ALT_INT_SGI_TARGET_ALL_EXCL_SENDER , ALT_INT_SGI_TARGET_SENDER_ONLY }
This module contains the definitions common to the Interrupt Controller Low-Level API and Interrupt Controller Manager Interface.
◆ ALT_INT_ICCIAR_ACKINTID_GET
#define ALT_INT_ICCIAR_ACKINTID_GET (   icciar)    (icciar & 0x3FF)
Extracts the ACKINTID field from the ICCIAR register.
◆ ALT_INT_ICCIAR_CPUID_GET
#define ALT_INT_ICCIAR_CPUID_GET (   icciar)    ((icciar >> 10) & 0x7)
Extracts the CPUID field from the ICCIAR register.
Typedef Documentation
◆ alt_int_callback_t
The callback to use when an interrupt needs to be serviced.
Parameters
icciarThe Interrupt Controller CPU Interrupt Acknowledgement Register value (ICCIAR) value corresponding to the current interrupt.
contextThe user provided context.
◆ alt_int_cpu_target_t
This is the CPU target type. It is used to specify a set of CPUs on the system. If only bit 0 is set then it specifies a set of CPUs containing only CPU 0. Multiple CPUs can be specified by setting the appropriate bit up to the number of CPUs on the system.
◆ ALT_INT_INTERRUPT_t
This type definition enumerates all the interrupt identification types.
◆ ALT_INT_SGI_TARGET_t
This type definition enumerates all the target list filter options. This is used by the trigger Software Generated Interrupt (SGI) feature to issue a SGI to the specified processor(s) in the system. Depending on the target list filter and the target list, interrupts can be routed to any combinations of CPUs.
◆ ALT_INT_TRIGGER_t
This type definition enumerates all the interrupt trigger types.
◆ ALT_INT_INTERRUPT_e
Software Generated Interrupts (SGI), 0 - 15.
  • All interrupts in this group are software triggered.
Private Peripheral Interrupts (PPI) for the Global Timer, per CPU private timer, and watchdog timer.
  • All interrupts in this group are edge triggered.
Interrupts sourced from CPU0.
The ALT_INT_INTERRUPT_CPU0_PARITYFAIL interrupt combines the BTAC, GHB, I_TAG, I_DATA, TLB, D_OUTER, D_TAG, and D_DATA interrupts for CPU0.
  • PARITYFAIL interrupts in this group are edge triggered.
  • DEFFLAGS interrupts in this group are level triggered.
Interrupts sourced from CPU1.
The ALT_INT_INTERRUPT_CPU1_PARITYFAIL interrupt combines the BTAC, GHB, I_TAG, I_DATA, TLB, D_OUTER, D_TAG, and D_DATA interrupts for CPU1.
Interrupts sourced from the Snoop Control Unit (SCU).
Interrupts sourced from the L2 Cache Controller.
The ALT_INT_INTERRUPT_L2_COMBINED_IRQ interrupt combines the cache controller internal DECERRINTR, ECNTRINTR, ERRRDINTR, ERRRTINTR, ERRWDINTR, ERRWTINTR, PARRDINTR, PARRTINTR, and SLVERRINTR interrupts. Consult the L2C documentation for information on these interrupts.
  • ECC interrupts in this group are edge triggered.
  • Other interrupts in this group are level triggered.
Interrupts sourced from the SDRAM Controller.
  • All interrupts in this group are level triggered.
Interrupt request from the FPGA logic, 0 - 63.
  • Trigger type depends on the implementation in the FPGA.
Interrupts sourced from the DMA Controller.
Interrupts sourced from the Ethernet MAC 0 (EMAC0).
Interrupts sourced from the Ethernet MAC 1 (EMAC1).
Interrupts sourced from the USB OTG 0.
Interrupts sourced from the USB OTG 1.
Interrupts sourced from the CAN Controller 0.
Interrupts sourced from the CAN Controller 1.
Interrupts sourced from the SDMMC Controller.
Interrupts sourced from the NAND Controller.
Interrupts sourced from the QSPI Controller.
Interrupts sourced from the SPI Controllers 0 - 3. SPI0_IRQ corresponds to SPIM0. SPI1_IRQ corresponds to SPIM1. SPI2_IRQ corresponds to SPIS0. SPI3_IRQ corresponds to SPIS1.
Interrupts sourced from the I2C Controllers 0 - 3.
Interrupts sourced from the UARTs 0 - 1.
Interrupts sourced from the GPIO 0 - 2.
Interrupts sourced from the Timer controllers.
Interrupts sourced from the Watchdog Timers 0 - 1.
Interrupts sourced from the Clock Manager.
Interrupts sourced from the Clock Manager MPU Wakeup.
Interrupts sourced from the FPGA Manager.
Interrupts sourced from the CoreSight for CPU0 and CPU1's CTI.
Interrupts sourced from the On-chip RAM.
◆ ALT_INT_SGI_TARGET_e
This filter list uses the target list parameter to specify which CPUs to send the interrupt to. If target list is 0, no interrupts are sent.
This filter list sends the interrupt all CPUs except the current CPU. The target list parameter is ignored.
This filter list sends the interrupt to the current CPU only. The target list parameter is ignored.
◆ ALT_INT_TRIGGER_e
Edge triggered interrupt. This applies to Private Peripheral Interrupts (PPI) and Shared Peripheral Interrupts (SPI) only, with interrupt IDs 16 - 1019.
Level triggered interrupt. This applies to Private Peripheral Interrupts (PPI) and Shared Peripheral Interrupts (SPI) only, with interrupt IDs 16 - 1019.
Software triggered interrupt. This applies to Software Generated Interrupts (SGI) only, with interrupt IDs 0 - 15.
All triggering types except for those in the Shared Peripheral Interrupts (SPI) F2S FPGA family interrupts can be determined by the system automatically. In all functions which ask for the triggering type, the ALT_INT_TRIGGER_AUTODETECT can be used to select the correct trigger type for all non F2S interrupt types.
ALT_INT_TRIGGER_NA
The interrupt triggering information is not applicable. This is possibly due to querying an invalid interrupt identifier.
