RTEMS 6.1-rc2
Modules | Functions
HAL Exported Functions
 HAL Control functions
 HAL Control functions.
 Initialization and de-initialization Functions
 Initialization and de-initialization functions.
void HAL_IncTick (void)
 This function is called to increment a global variable "uwTick" used as application time base.
void HAL_Delay (uint32_t Delay)
 This function provides minimum delay (in milliseconds) based on variable incremented.
uint32_t HAL_GetTick (void)
 Provides a tick value in millisecond.
uint32_t HAL_GetTickPrio (void)
 This function returns a tick priority.
HAL_StatusTypeDef HAL_SetTickFreq (HAL_TickFreqTypeDef Freq)
 Set new tick Freq.
HAL_TickFreqTypeDef HAL_GetTickFreq (void)
 Return tick frequency.
void HAL_SuspendTick (void)
 Suspend Tick increment.
void HAL_ResumeTick (void)
 Resume Tick increment.
uint32_t HAL_GetHalVersion (void)
 Returns the HAL revision.
uint32_t HAL_GetREVID (void)
 Returns the device revision identifier.
uint32_t HAL_GetDEVID (void)
 Returns the device identifier.
uint32_t HAL_GetUIDw0 (void)
 Return the first word of the unique device identifier (UID based on 96 bits)
uint32_t HAL_GetUIDw1 (void)
 Return the second word of the unique device identifier (UID based on 96 bits)
uint32_t HAL_GetUIDw2 (void)
 Return the third word of the unique device identifier (UID based on 96 bits)
void HAL_SYSCFG_AnalogSwitchConfig (uint32_t SYSCFG_AnalogSwitch, uint32_t SYSCFG_SwitchState)
 Analog Switch control for dual analog pads.
void HAL_EnableCompensationCell (void)
 Enables the I/O Compensation Cell.
void HAL_DisableCompensationCell (void)
 Power-down the I/O Compensation Cell.
void HAL_SYSCFG_EnableIOSpeedOptimize (void)
 To Enable optimize the I/O speed when the product voltage is low.
void HAL_SYSCFG_DisableIOSpeedOptimize (void)
 To Disable optimize the I/O speed when the product voltage is low.
void HAL_SYSCFG_CompensationCodeSelect (uint32_t SYSCFG_CompCode)
 Code selection for the I/O Compensation cell.
void HAL_SYSCFG_CompensationCodeConfig (uint32_t SYSCFG_PMOSCode, uint32_t SYSCFG_NMOSCode)
void HAL_DBGMCU_EnableDBGSleepMode (void)
 Enable the Debug Module during Domain1/CDomain SLEEP mode.
void HAL_DBGMCU_DisableDBGSleepMode (void)
 Disable the Debug Module during Domain1/CDomain SLEEP mode.
void HAL_DBGMCU_EnableDBGStopMode (void)
 Enable the Debug Module during Domain1/CDomain STOP mode.
void HAL_DBGMCU_DisableDBGStopMode (void)
 Disable the Debug Module during Domain1/CDomain STOP mode.
void HAL_DBGMCU_EnableDBGStandbyMode (void)
 Enable the Debug Module during Domain1/CDomain STANDBY mode.
void HAL_DBGMCU_DisableDBGStandbyMode (void)
 Disable the Debug Module during Domain1/CDomain STANDBY mode.
void HAL_EXTI_EdgeConfig (uint32_t EXTI_Line, uint32_t EXTI_Edge)
 Configure the EXTI input event line edge.
void HAL_EXTI_GenerateSWInterrupt (uint32_t EXTI_Line)
 Generates a Software interrupt on selected EXTI line.
void HAL_EXTI_D1_ClearFlag (uint32_t EXTI_Line)
 Clears the EXTI's line pending flags for Domain D1.
void HAL_EXTI_D1_EventInputConfig (uint32_t EXTI_Line, uint32_t EXTI_Mode, uint32_t EXTI_LineCmd)
 Configure the EXTI input event line for Domain D1.
void HAL_EXTI_D3_EventInputConfig (uint32_t EXTI_Line, uint32_t EXTI_LineCmd, uint32_t EXTI_ClearSrc)
 Configure the EXTI input event line for Domain D3.
void HAL_SetFMCMemorySwappingConfig (uint32_t BankMapConfig)
 Set the FMC Memory Mapping Swapping config.
uint32_t HAL_GetFMCMemorySwappingConfig (void)
 Get FMC Bank mapping mode.
void HAL_SYSCFG_VREFBUF_VoltageScalingConfig (uint32_t VoltageScaling)
 Configure the internal voltage reference buffer voltage scale.
void HAL_SYSCFG_VREFBUF_HighImpedanceConfig (uint32_t Mode)
 Configure the internal voltage reference buffer high impedance mode.
void HAL_SYSCFG_VREFBUF_TrimmingConfig (uint32_t TrimmingValue)
 Tune the Internal Voltage Reference buffer (VREFBUF).
HAL_StatusTypeDef HAL_SYSCFG_EnableVREFBUF (void)
 Enable the Internal Voltage Reference buffer (VREFBUF).
void HAL_SYSCFG_DisableVREFBUF (void)
 Disable the Internal Voltage Reference buffer (VREFBUF).
◆ HAL_DBGMCU_DisableDBGSleepMode()
void HAL_DBGMCU_DisableDBGSleepMode ( void  )
Return values
None
◆ HAL_DBGMCU_DisableDBGStandbyMode()
void HAL_DBGMCU_DisableDBGStandbyMode ( void  )
Return values
None
◆ HAL_DBGMCU_DisableDBGStopMode()
void HAL_DBGMCU_DisableDBGStopMode ( void  )
Return values
None
◆ HAL_DBGMCU_EnableDBGSleepMode()
void HAL_DBGMCU_EnableDBGSleepMode ( void  )
Return values
None
◆ HAL_DBGMCU_EnableDBGStandbyMode()
void HAL_DBGMCU_EnableDBGStandbyMode ( void  )
Return values
None
◆ HAL_DBGMCU_EnableDBGStopMode()
void HAL_DBGMCU_EnableDBGStopMode ( void  )
Return values
None
◆ HAL_Delay()
void HAL_Delay ( uint32_t  Delay)
Note
In the default implementation , SysTick timer is the source of time base. It is used to generate interrupts at regular time intervals where uwTick is incremented.
This function is declared as __weak to be overwritten in case of other implementations in user file.
Parameters
Delayspecifies the delay time length, in milliseconds.
Return values
None
◆ HAL_DisableCompensationCell()
void HAL_DisableCompensationCell ( void  )
Note
The I/O compensation cell can be used only when the device supply voltage ranges from 1.62 to 2.0 V and from 2.7 to 3.6 V.
Return values
None
◆ HAL_EnableCompensationCell()
void HAL_EnableCompensationCell ( void  )
Note
Return values
None
◆ HAL_EXTI_D1_ClearFlag()
void HAL_EXTI_D1_ClearFlag ( uint32_t  EXTI_Line)
Parameters
EXTI_LineSpecifies the EXTI LINE, it can be one of the following values, (EXTI_LINE0....EXTI_LINE87)excluding :line45, line81,line83 which are reserved
Return values
None
◆ HAL_EXTI_D1_EventInputConfig()
void HAL_EXTI_D1_EventInputConfig ( uint32_t  EXTI_Line,
uint32_t  EXTI_Mode,
Parameters
EXTI_ModeSpecifies which EXTI line is used as interrupt or an event. This parameter can be one or a combination of the following values :
  • EXTI_MODE_IT : Interrupt Mode selected
  • EXTI_MODE_EVT : Event Mode selected
EXTI_LineCmdcontrols (Enable/Disable) the EXTI line.
Return values
None
◆ HAL_EXTI_D3_EventInputConfig()
void HAL_EXTI_D3_EventInputConfig ( uint32_t  EXTI_Line,
Parameters
EXTI_LineSpecifies the EXTI LINE, it can be one of the following values, (EXTI_LINE0...EXTI_LINE15),(EXTI_LINE19...EXTI_LINE21),EXTI_LINE25, EXTI_LINE34, EXTI_LINE35,EXTI_LINE41,(EXTI_LINE48...EXTI_LINE53)
EXTI_ClearSrcSpecifies the clear source of D3 pending event. This parameter can be one of the following values :
  • BDMA_CH6_CLEAR : BDMA ch6 event selected as D3 domain pendclear source
  • BDMA_CH7_CLEAR : BDMA ch7 event selected as D3 domain pendclear source
  • LPTIM4_OUT_CLEAR : LPTIM4 out selected as D3 domain pendclear source
  • LPTIM5_OUT_CLEAR : LPTIM5 out selected as D3 domain pendclear source
Return values
None
◆ HAL_EXTI_EdgeConfig()
void HAL_EXTI_EdgeConfig ( uint32_t  EXTI_Line,
uint32_t  EXTI_Edge
Note
No edge configuration for direct lines but for configurable lines:(EXTI_LINE0..EXTI_LINE21), EXTI_LINE49,EXTI_LINE51,EXTI_LINE82,EXTI_LINE84,EXTI_LINE85 and EXTI_LINE86.
Parameters
EXTI_EdgeSpecifies EXTI line Edge used. This parameter can be one of the following values :
  • EXTI_RISING_EDGE : Configurable line, with Rising edge trigger detection
  • EXTI_FALLING_EDGE: Configurable line, with Falling edge trigger detection
Return values
None
◆ HAL_EXTI_GenerateSWInterrupt()
void HAL_EXTI_GenerateSWInterrupt ( uint32_t  EXTI_Line)
Parameters
EXTI_LineSpecifies the EXTI LINE, it can be one of the following values, (EXTI_LINE0..EXTI_LINE21),EXTI_LINE49,EXTI_LINE51,EXTI_LINE82,EXTI_LINE84,EXTI_LINE85 and EXTI_LINE86.
Return values
None
◆ HAL_GetDEVID()
uint32_t HAL_GetDEVID ( void  )
Return values
Deviceidentifier
◆ HAL_GetFMCMemorySwappingConfig()
uint32_t HAL_GetFMCMemorySwappingConfig ( void  )
Return values
TheFMC Bank mapping mode. This parameter can be FMC_SWAPBMAP_DISABLE, FMC_SWAPBMAP_SDRAM_SRAM, FMC_SWAPBMAP_SDRAMB2
◆ HAL_GetHalVersion()
uint32_t HAL_GetHalVersion ( void  )
Return values
version: 0xXYZR (8bits for each decimal, R for RC)
◆ HAL_GetREVID()
uint32_t HAL_GetREVID ( void  )
Return values
Devicerevision identifier
◆ HAL_GetTick()
uint32_t HAL_GetTick ( void  )
Note
Return values
tickvalue
◆ HAL_GetTickFreq()
HAL_TickFreqTypeDef HAL_GetTickFreq ( void  )
Return values
Tickfrequency. Value of HAL_TickFreqTypeDef.
◆ HAL_GetTickPrio()
uint32_t HAL_GetTickPrio ( void  )
Return values
tickpriority
◆ HAL_GetUIDw0()
uint32_t HAL_GetUIDw0 ( void  )
Return values
Deviceidentifier
◆ HAL_GetUIDw1()
uint32_t HAL_GetUIDw1 ( void  )
Return values
Deviceidentifier
◆ HAL_GetUIDw2()
uint32_t HAL_GetUIDw2 ( void  )
Return values
Deviceidentifier
◆ HAL_IncTick()
void HAL_IncTick ( void  )
Note
In the default implementation, this variable is incremented each 1ms in Systick ISR.
Return values
None
◆ HAL_ResumeTick()
void HAL_ResumeTick ( void  )
Note
In the default implementation , SysTick timer is the source of time base. It is used to generate interrupts at regular time intervals. Once HAL_ResumeTick() is called, the SysTick interrupt will be enabled and so Tick increment is resumed.
Return values
None
Note
Enable the tick increment by Enabling RTC ALARM interrupt.
Return values
None
Note
Enable the tick increment by Enabling RTC_WKUP interrupt.
Return values
None
Note
Enable the tick increment by Enabling TIM6 update interrupt.
Parameters
None
Return values
None
◆ HAL_SetFMCMemorySwappingConfig()
void HAL_SetFMCMemorySwappingConfig ( uint32_t  BankMapConfig)
Parameters
BankMapConfigDefines the FMC Bank mapping configuration. This parameter can be FMC_SWAPBMAP_DISABLE, FMC_SWAPBMAP_SDRAM_SRAM, FMC_SWAPBMAP_SDRAMB2
Return values
HALstate
◆ HAL_SetTickFreq()
HAL_StatusTypeDef HAL_SetTickFreq ( HAL_TickFreqTypeDef  Freq)
Set new tick Freq.
Return values
Status
◆ HAL_SuspendTick()
void HAL_SuspendTick ( void  )
Note
In the default implementation , SysTick timer is the source of time base. It is used to generate interrupts at regular time intervals. Once HAL_SuspendTick() is called, the SysTick interrupt will be disabled and so Tick increment is suspended.
Return values
None
Note
Disable the tick increment by disabling RTC ALARM interrupt.
Return values
None
Note
Disable the tick increment by disabling RTC_WKUP interrupt.
Return values
None
Note
Disable the tick increment by disabling TIM6 update interrupt.
Parameters
None
Return values
None
◆ HAL_SYSCFG_AnalogSwitchConfig()
void HAL_SYSCFG_AnalogSwitchConfig ( uint32_t  SYSCFG_AnalogSwitch,
Parameters
SYSCFG_AnalogSwitchSelects the analog pad This parameter can be one or a combination of the following values:
  • SYSCFG_SWITCH_PA0 : Select PA0 analog switch
  • SYSCFG_SWITCH_PA1: Select PA1 analog switch
  • SYSCFG_SWITCH_PC2 : Select PC2 analog switch
  • SYSCFG_SWITCH_PC3: Select PC3 analog switch
SYSCFG_SwitchStateOpen or Close the analog switch between dual pads (PXn and PXn_C) This parameter can be one or a combination of the following values:
  • SYSCFG_SWITCH_PA0_OPEN
  • SYSCFG_SWITCH_PA0_CLOSE
  • SYSCFG_SWITCH_PA1_OPEN
  • SYSCFG_SWITCH_PA1_CLOSE
  • SYSCFG_SWITCH_PC2_OPEN
  • SYSCFG_SWITCH_PC2_CLOSE
  • SYSCFG_SWITCH_PC3_OPEN
  • SYSCFG_SWITCH_PC3_CLOSE
Return values
None
◆ HAL_SYSCFG_CompensationCodeConfig()
void HAL_SYSCFG_CompensationCodeConfig ( uint32_t  SYSCFG_PMOSCode,
Parameters
SYSCFG_PMOSCodePMOS compensation code This code is applied to the I/O compensation cell when the CS bit of the SYSCFG_CMPCR is set
SYSCFG_NMOSCodeNMOS compensation code This code is applied to the I/O compensation cell when the CS bit of the SYSCFG_CMPCR is set
Return values
None
◆ HAL_SYSCFG_CompensationCodeSelect()
void HAL_SYSCFG_CompensationCodeSelect ( uint32_t  SYSCFG_CompCode)
Parameters
SYSCFG_CompCodeSelects the code to be applied for the I/O compensation cell This parameter can be one of the following values:
  • SYSCFG_CELL_CODE : Select Code from the cell (available in the SYSCFG_CCVR)
  • SYSCFG_REGISTER_CODE: Select Code from the SYSCFG compensation cell code register (SYSCFG_CCCR)
Return values
None
◆ HAL_SYSCFG_DisableIOSpeedOptimize()
void HAL_SYSCFG_DisableIOSpeedOptimize ( void  )
Note
This bit is active only if PRODUCT_BELOW_25V user option bit is set. It must be used only if the product supply voltage is below 2.5 V. Setting this bit when VDD is higher than 2.5 V might be destructive.
Return values
None
◆ HAL_SYSCFG_DisableVREFBUF()
void HAL_SYSCFG_DisableVREFBUF ( void  )
Return values
None
◆ HAL_SYSCFG_EnableIOSpeedOptimize()
void HAL_SYSCFG_EnableIOSpeedOptimize ( void  )
Note
Return values
None
◆ HAL_SYSCFG_EnableVREFBUF()
HAL_StatusTypeDef HAL_SYSCFG_EnableVREFBUF ( void  )
Return values
HAL_OK/HAL_TIMEOUT
◆ HAL_SYSCFG_VREFBUF_HighImpedanceConfig()
void HAL_SYSCFG_VREFBUF_HighImpedanceConfig ( uint32_t  Mode)
Parameters
Modespecifies the high impedance mode This parameter can be one of the following values:
  • SYSCFG_VREFBUF_HIGH_IMPEDANCE_DISABLE: VREF+ pin is internally connect to VREFINT output.
  • SYSCFG_VREFBUF_HIGH_IMPEDANCE_ENABLE: VREF+ pin is high impedance.
Return values
None
◆ HAL_SYSCFG_VREFBUF_TrimmingConfig()
void HAL_SYSCFG_VREFBUF_TrimmingConfig ( uint32_t  TrimmingValue)
Return values
None
◆ HAL_SYSCFG_VREFBUF_VoltageScalingConfig()
void HAL_SYSCFG_VREFBUF_VoltageScalingConfig ( uint32_t  VoltageScaling)
Parameters
VoltageScalingspecifies the output voltage to achieve This parameter can be one of the following values:
  • SYSCFG_VREFBUF_VOLTAGE_SCALE0: VREF_OUT1 around 2.5 V. This requires VDDA equal to or higher than 2.8 V.
  • SYSCFG_VREFBUF_VOLTAGE_SCALE1: VREF_OUT2 around 2.048 V. This requires VDDA equal to or higher than 2.4 V.
  • SYSCFG_VREFBUF_VOLTAGE_SCALE2: VREF_OUT3 around 1.8 V. This requires VDDA equal to or higher than 2.1 V.
  • SYSCFG_VREFBUF_VOLTAGE_SCALE3: VREF_OUT4 around 1.5 V. This requires VDDA equal to or higher than 1.8 V.
Return values
None
