RTEMS 6.1-rc2
#define __HAL_GPIO_EXTI_GET_FLAG(__EXTI_LINE__)   (EXTI->PR1 & (__EXTI_LINE__))
 Checks whether the specified EXTI line flag is set or not.
#define __HAL_GPIO_EXTI_CLEAR_FLAG(__EXTI_LINE__)   (EXTI->PR1 = (__EXTI_LINE__))
 Clears the EXTI's line pending flags.
#define __HAL_GPIO_EXTI_GET_IT(__EXTI_LINE__)   (EXTI->PR1 & (__EXTI_LINE__))
 Checks whether the specified EXTI line is asserted or not.
#define __HAL_GPIO_EXTI_CLEAR_IT(__EXTI_LINE__)   (EXTI->PR1 = (__EXTI_LINE__))
 Clears the EXTI's line pending bits.
#define __HAL_GPIO_EXTI_GENERATE_SWIT(__EXTI_LINE__)   (EXTI->SWIER1 |= (__EXTI_LINE__))
 Generates a Software interrupt on selected EXTI line.
◆ __HAL_GPIO_EXTI_CLEAR_FLAG
#define __HAL_GPIO_EXTI_CLEAR_FLAG (   __EXTI_LINE__)    (EXTI->PR1 = (__EXTI_LINE__))
Parameters
__EXTI_LINE__specifies the EXTI lines flags to clear. This parameter can be any combination of GPIO_PIN_x where x can be (0..15)
Return values
None
◆ __HAL_GPIO_EXTI_CLEAR_IT
#define __HAL_GPIO_EXTI_CLEAR_IT (   __EXTI_LINE__)    (EXTI->PR1 = (__EXTI_LINE__))
Parameters
__EXTI_LINE__specifies the EXTI lines to clear. This parameter can be any combination of GPIO_PIN_x where x can be (0..15)
Return values
None
◆ __HAL_GPIO_EXTI_GENERATE_SWIT
#define __HAL_GPIO_EXTI_GENERATE_SWIT (   __EXTI_LINE__)    (EXTI->SWIER1 |= (__EXTI_LINE__))
Parameters
__EXTI_LINE__specifies the EXTI line to check. This parameter can be GPIO_PIN_x where x can be(0..15)
Return values
None
◆ __HAL_GPIO_EXTI_GET_FLAG
#define __HAL_GPIO_EXTI_GET_FLAG (   __EXTI_LINE__)    (EXTI->PR1 & (__EXTI_LINE__))
Parameters
__EXTI_LINE__specifies the EXTI line flag to check. This parameter can be GPIO_PIN_x where x can be(0..15)
Return values
Thenew state of EXTI_LINE (SET or RESET).
◆ __HAL_GPIO_EXTI_GET_IT
#define __HAL_GPIO_EXTI_GET_IT (   __EXTI_LINE__)    (EXTI->PR1 & (__EXTI_LINE__))
Parameters
Return values
