RTEMS 6.1-rc2
macros to handle SDRAM interrupts More...
#define __FMC_SDRAM_ENABLE_IT(__INSTANCE__, __INTERRUPT__)   ((__INSTANCE__)->SDRTR |= (__INTERRUPT__))
 Enable the SDRAM device interrupt.
#define __FMC_SDRAM_DISABLE_IT(__INSTANCE__, __INTERRUPT__)   ((__INSTANCE__)->SDRTR &= ~(__INTERRUPT__))
 Disable the SDRAM device interrupt.
#define __FMC_SDRAM_GET_FLAG(__INSTANCE__, __FLAG__)   (((__INSTANCE__)->SDSR &(__FLAG__)) == (__FLAG__))
 Get flag status of the SDRAM device.
#define __FMC_SDRAM_CLEAR_FLAG(__INSTANCE__, __FLAG__)   ((__INSTANCE__)->SDRTR |= (__FLAG__))
 Clear flag status of the SDRAM device.
◆ __FMC_SDRAM_CLEAR_FLAG
#define __FMC_SDRAM_CLEAR_FLAG (   __INSTANCE__,
  __FLAG__
Parameters
__INSTANCE__FMC_SDRAM instance
__FLAG__FMC_SDRAM flag This parameter can be any combination of the following values:
  • FMC_SDRAM_FLAG_REFRESH_ERROR
Return values
None
◆ __FMC_SDRAM_DISABLE_IT
#define __FMC_SDRAM_DISABLE_IT (   __INSTANCE__,
  __INTERRUPT__
Parameters
__INTERRUPT__FMC_SDRAM interrupt This parameter can be any combination of the following values:
  • FMC_IT_REFRESH_ERROR: Interrupt refresh error
Return values
None
◆ __FMC_SDRAM_ENABLE_IT
#define __FMC_SDRAM_ENABLE_IT (   __INSTANCE__,
  __INTERRUPT__
Parameters
Return values
None
◆ __FMC_SDRAM_GET_FLAG
#define __FMC_SDRAM_GET_FLAG (   __INSTANCE__,
  __FLAG__
Parameters
  • FMC_SDRAM_FLAG_REFRESH_IT: Interrupt refresh error.
  • FMC_SDRAM_FLAG_BUSY: SDRAM busy flag.
  • FMC_SDRAM_FLAG_REFRESH_ERROR: Refresh error flag.
Return values
Thestate of FLAG (SET or RESET).
