RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Enumerator | Variables
DCIC
struct  _dcic_config
 DCIC configuration. More...
struct  _dcic_region_config
 Region of interest (ROI) configuration. More...
#define DCIC_REGION_COUNT   DCIC_DCICRCS_COUNT
#define FSL_DCIC_DRIVER_VERSION   (MAKE_VERSION(2, 0, 3))
 DCIC driver version.
#define DCIC_CRC32_POLYNOMIAL   0x04C11DB7UL
 CRC32 calculation polynomial.
#define DCIC_CRC32_INIT_VALUE   0UL
 CRC32 calculation initialize value.
#define DCIC_REGION_MISMATCH_STATUS(region)   (1UL << (DCIC_DCICS_ROI_MATCH_STAT_SHIFT + (region)))
 ROI CRC32 value mismatch status.
typedef struct _dcic_config dcic_config_t
 DCIC configuration.
typedef struct _dcic_region_config dcic_region_config_t
enum  _DCIC_polarity_flags {
  kDCIC_VsyncActiveHigh = 0U , kDCIC_HsyncActiveHigh = 0U , kDCIC_DataEnableActiveHigh = 0U , kDCIC_DriveDataOnFallingClkEdge = 0U ,
  kDCIC_VsyncActiveLow = DCIC_DCICC_VSYNC_POL_MASK , kDCIC_HsyncActiveLow = DCIC_DCICC_HSYNC_POL_MASK , kDCIC_DataEnableActiveLow = DCIC_DCICC_DE_POL_MASK , kDCIC_DriveDataOnRisingClkEdge = DCIC_DCICC_CLK_POL_MASK
 DCIC display signal polarity flags . More...
enum  _DCIC_status_flags {
  kDCIC_FunctionalInterruptStatus = DCIC_DCICS_FI_STAT_MASK , kDCIC_ErrorInterruptStatus = DCIC_DCICS_EI_STAT_MASK , kDCIC_Region0MismatchStatus = DCIC_REGION_MISMATCH_STATUS(0U) , kDCIC_Region1MismatchStatus = DCIC_REGION_MISMATCH_STATUS(1U) ,
  kDCIC_Region2MismatchStatus = DCIC_REGION_MISMATCH_STATUS(2U) , kDCIC_Region3MismatchStatus = DCIC_REGION_MISMATCH_STATUS(3U) , kDCIC_Region4MismatchStatus = DCIC_REGION_MISMATCH_STATUS(4U) , kDCIC_Region5MismatchStatus = DCIC_REGION_MISMATCH_STATUS(5U) ,
  kDCIC_Region6MismatchStatus = DCIC_REGION_MISMATCH_STATUS(6U) , kDCIC_Region7MismatchStatus = DCIC_REGION_MISMATCH_STATUS(7U) , kDCIC_Region8MismatchStatus = DCIC_REGION_MISMATCH_STATUS(8U) , kDCIC_Region9MismatchStatus = DCIC_REGION_MISMATCH_STATUS(9U) ,
  kDCIC_Region10MismatchStatus = DCIC_REGION_MISMATCH_STATUS(10U) , kDCIC_Region11MismatchStatus = DCIC_REGION_MISMATCH_STATUS(11U) , kDCIC_Region12MismatchStatus = DCIC_REGION_MISMATCH_STATUS(12U) , kDCIC_Region13MismatchStatus = DCIC_REGION_MISMATCH_STATUS(13U) ,
  kDCIC_Region14MismatchStatus = DCIC_REGION_MISMATCH_STATUS(14U) , kDCIC_Region15MismatchStatus = DCIC_REGION_MISMATCH_STATUS(15U)
 Status flags. . More...
enum  _dcic_interrupt_enable { kDCIC_FunctionalInterruptEnable = DCIC_DCICIC_FI_MASK_MASK , kDCIC_ErrorInterruptEnable = DCIC_DCICIC_EI_MASK_MASK }
 Interrupts. . More...
bool _dcic_config::enableExternalSignal
uint8_t _dcic_config::polarityFlags
uint32_t _dcic_config::enableInterrupts
bool _dcic_region_config::lock
uint16_t _dcic_region_config::upperLeftX
uint16_t _dcic_region_config::upperLeftY
uint16_t _dcic_region_config::lowerRightX
uint16_t _dcic_region_config::lowerRightY
uint32_t _dcic_region_config::refCrc
Initialization and deinitialization
void DCIC_Init (DCIC_Type *base, const dcic_config_t *config)
 Initializes the DCIC.
void DCIC_Deinit (DCIC_Type *base)
 Deinitialize the DCIC.
void DCIC_GetDefaultConfig (dcic_config_t *config)
 Get the default configuration to initialize DCIC.
Region
void DCIC_EnableRegion (DCIC_Type *base, uint8_t regionIdx, const dcic_region_config_t *config)
 Enable the region of interest (ROI) with configuration.
◆ _dcic_interrupt_enable
Interrupts. .
Interrupt when match results ready.
Interrupt when there is a signature mismatch.
◆ _DCIC_polarity_flags
VSYNC active high.
HSYNC active high.
Data enable line active high.
Output data on rising clock edge, capture data on falling clock edge.
VSYNC active low.
HSYNC active low.
Data enable line active low.
Output data on falling clock edge, capture data on rising clock edge.
◆ _DCIC_status_flags
Status flags. .
Asserted when match results ready.
Asserted when there is a signature mismatch.
Region 0 CRC32 value mismatch.
Region 1 CRC32 value mismatch.
Region 2 CRC32 value mismatch.
Region 3 CRC32 value mismatch.
Region 4 CRC32 value mismatch.
Region 5 CRC32 value mismatch.
Region 6 CRC32 value mismatch.
Region 7 CRC32 value mismatch.
Region 8 CRC32 value mismatch.
Region 9 CRC32 value mismatch.
Region 10 CRC32 value mismatch.
Region 11 CRC32 value mismatch.
Region 12 CRC32 value mismatch.
Region 13 CRC32 value mismatch.
Region 14 CRC32 value mismatch.
Region 15 CRC32 value mismatch.
◆ DCIC_Deinit()
void DCIC_Deinit ( DCIC_Type base)
Disable the DCIC functions.
Parameters
baseDCIC peripheral base address.
◆ DCIC_EnableRegion()
void DCIC_EnableRegion ( DCIC_Type base,
uint8_t  regionIdx,
const dcic_region_config_t config
Enable the ROI with configuration. To change the configuration except reference CRC value, the region should be disabled first by DCIC_DisableRegion, then call this function again. The reference CRC value could be changed by DCIC_SetRegionRefCrc without disabling the region. If the configuration is locked, only the reference CRC value could be changed, the region size and position, enable status could not be changed until reset.
Parameters
regionIdxRegion index, from 0 to (DCIC_REGION_COUNT - 1).
configPointer to the configuration.
◆ DCIC_GetDefaultConfig()
void DCIC_GetDefaultConfig ( dcic_config_t config)
The default configuration is:
config->enableExternalSignal = false;
config->enableInterrupts = 0;
@ kDCIC_DataEnableActiveLow
Definition: fsl_dcic.h:51
@ kDCIC_VsyncActiveLow
Definition: fsl_dcic.h:49
@ kDCIC_DriveDataOnFallingClkEdge
Definition: fsl_dcic.h:46
@ kDCIC_HsyncActiveLow
Definition: fsl_dcic.h:50
Definition: deflate.c:114
Parameters
config->polarityFlags = kDCIC_VsyncActiveLow | kDCIC_HsyncActiveLow | kDCIC_DataEnableActiveLow | kDCIC_DriveDataOnFallingClkEdge; config->enableExternalSignal = false; config->enableInterrupts = 0;
param config Pointer to the configuration.
◆ DCIC_Init()
void DCIC_Init ( DCIC_Type base,
const dcic_config_t config
This function resets DCIC registers to default value, then set the configurations. This function does not start the DCIC to work, application should call DCIC_DisableRegion to configure regions, then call DCIC_Enable to start the DCIC to work.
Parameters
Variable Documentation
◆ enableExternalSignal
Enable the mismatch external signal. When enabled, the mismatch status could be monitored from the extern pin.
◆ enableInterrupts
Interrupts to enable, should be OR'ed of _dcic_interrupt_enable.
◆ lock
Lock the region configuration except reference CRC32 value setting.
◆ lowerRightX
X of lower right corner. Range: 0 to 2^13-1.
◆ lowerRightY
Y of lower right corner. Range: 0 to 2^12-1.
◆ polarityFlags
Display signal polarity, logical OR'ed of _DCIC_polarity_flags.
◆ refCrc
Reference CRC32 value.
◆ upperLeftX
X of upper left corner. Range: 0 to 2^13-1.
◆ upperLeftY
Y of upper left corner. Range: 0 to 2^12-1.
