RTEMS 6.1-rc2
REG0 - DCDC Register 0 | |
#define | DCDC_REG0_PWD_ZCD_MASK (0x1U) |
#define | DCDC_REG0_PWD_ZCD_SHIFT (0U) |
#define | DCDC_REG0_PWD_ZCD(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_ZCD_SHIFT)) & DCDC_REG0_PWD_ZCD_MASK) |
#define | DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_MASK (0x2U) |
#define | DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_SHIFT (1U) |
#define | DCDC_REG0_DISABLE_AUTO_CLK_SWITCH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_SHIFT)) & DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_MASK) |
#define | DCDC_REG0_SEL_CLK_MASK (0x4U) |
#define | DCDC_REG0_SEL_CLK_SHIFT (2U) |
#define | DCDC_REG0_SEL_CLK(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_SEL_CLK_SHIFT)) & DCDC_REG0_SEL_CLK_MASK) |
#define | DCDC_REG0_PWD_OSC_INT_MASK (0x8U) |
#define | DCDC_REG0_PWD_OSC_INT_SHIFT (3U) |
#define | DCDC_REG0_PWD_OSC_INT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_OSC_INT_SHIFT)) & DCDC_REG0_PWD_OSC_INT_MASK) |
#define | DCDC_REG0_PWD_CUR_SNS_CMP_MASK (0x10U) |
#define | DCDC_REG0_PWD_CUR_SNS_CMP_SHIFT (4U) |
#define | DCDC_REG0_PWD_CUR_SNS_CMP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CUR_SNS_CMP_SHIFT)) & DCDC_REG0_PWD_CUR_SNS_CMP_MASK) |
#define | DCDC_REG0_CUR_SNS_THRSH_MASK (0xE0U) |
#define | DCDC_REG0_CUR_SNS_THRSH_SHIFT (5U) |
#define | DCDC_REG0_CUR_SNS_THRSH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_CUR_SNS_THRSH_SHIFT)) & DCDC_REG0_CUR_SNS_THRSH_MASK) |
#define | DCDC_REG0_PWD_OVERCUR_DET_MASK (0x100U) |
#define | DCDC_REG0_PWD_OVERCUR_DET_SHIFT (8U) |
#define | DCDC_REG0_PWD_OVERCUR_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_OVERCUR_DET_SHIFT)) & DCDC_REG0_PWD_OVERCUR_DET_MASK) |
#define | DCDC_REG0_OVERCUR_TRIG_ADJ_MASK (0x600U) |
#define | DCDC_REG0_OVERCUR_TRIG_ADJ_SHIFT (9U) |
#define | DCDC_REG0_OVERCUR_TRIG_ADJ(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_OVERCUR_TRIG_ADJ_SHIFT)) & DCDC_REG0_OVERCUR_TRIG_ADJ_MASK) |
#define | DCDC_REG0_PWD_CMP_BATT_DET_MASK (0x800U) |
#define | DCDC_REG0_PWD_CMP_BATT_DET_SHIFT (11U) |
#define | DCDC_REG0_PWD_CMP_BATT_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_BATT_DET_SHIFT)) & DCDC_REG0_PWD_CMP_BATT_DET_MASK) |
#define | DCDC_REG0_EN_LP_OVERLOAD_SNS_MASK (0x10000U) |
#define | DCDC_REG0_EN_LP_OVERLOAD_SNS_SHIFT (16U) |
#define | DCDC_REG0_EN_LP_OVERLOAD_SNS(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_EN_LP_OVERLOAD_SNS_SHIFT)) & DCDC_REG0_EN_LP_OVERLOAD_SNS_MASK) |
#define | DCDC_REG0_PWD_HIGH_VOLT_DET_MASK (0x20000U) |
#define | DCDC_REG0_PWD_HIGH_VOLT_DET_SHIFT (17U) |
#define | DCDC_REG0_PWD_HIGH_VOLT_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VOLT_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VOLT_DET_MASK) |
#define | DCDC_REG0_LP_OVERLOAD_THRSH_MASK (0xC0000U) |
#define | DCDC_REG0_LP_OVERLOAD_THRSH_SHIFT (18U) |
#define | DCDC_REG0_LP_OVERLOAD_THRSH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_OVERLOAD_THRSH_SHIFT)) & DCDC_REG0_LP_OVERLOAD_THRSH_MASK) |
#define | DCDC_REG0_LP_OVERLOAD_FREQ_SEL_MASK (0x100000U) |
#define | DCDC_REG0_LP_OVERLOAD_FREQ_SEL_SHIFT (20U) |
#define | DCDC_REG0_LP_OVERLOAD_FREQ_SEL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_OVERLOAD_FREQ_SEL_SHIFT)) & DCDC_REG0_LP_OVERLOAD_FREQ_SEL_MASK) |
#define | DCDC_REG0_LP_HIGH_HYS_MASK (0x200000U) |
#define | DCDC_REG0_LP_HIGH_HYS_SHIFT (21U) |
#define | DCDC_REG0_LP_HIGH_HYS(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_HIGH_HYS_SHIFT)) & DCDC_REG0_LP_HIGH_HYS_MASK) |
#define | DCDC_REG0_PWD_CMP_OFFSET_MASK (0x4000000U) |
#define | DCDC_REG0_PWD_CMP_OFFSET_SHIFT (26U) |
#define | DCDC_REG0_PWD_CMP_OFFSET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_OFFSET_SHIFT)) & DCDC_REG0_PWD_CMP_OFFSET_MASK) |
#define | DCDC_REG0_XTALOK_DISABLE_MASK (0x8000000U) |
#define | DCDC_REG0_XTALOK_DISABLE_SHIFT (27U) |
#define | DCDC_REG0_XTALOK_DISABLE(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_XTALOK_DISABLE_SHIFT)) & DCDC_REG0_XTALOK_DISABLE_MASK) |
#define | DCDC_REG0_CURRENT_ALERT_RESET_MASK (0x10000000U) |
#define | DCDC_REG0_CURRENT_ALERT_RESET_SHIFT (28U) |
#define | DCDC_REG0_CURRENT_ALERT_RESET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_CURRENT_ALERT_RESET_SHIFT)) & DCDC_REG0_CURRENT_ALERT_RESET_MASK) |
#define | DCDC_REG0_XTAL_24M_OK_MASK (0x20000000U) |
#define | DCDC_REG0_XTAL_24M_OK_SHIFT (29U) |
#define | DCDC_REG0_XTAL_24M_OK(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_XTAL_24M_OK_SHIFT)) & DCDC_REG0_XTAL_24M_OK_MASK) |
#define | DCDC_REG0_STS_DC_OK_MASK (0x80000000U) |
#define | DCDC_REG0_STS_DC_OK_SHIFT (31U) |
#define | DCDC_REG0_STS_DC_OK(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_STS_DC_OK_SHIFT)) & DCDC_REG0_STS_DC_OK_MASK) |
REG1 - DCDC Register 1 | |
#define | DCDC_REG1_REG_FBK_SEL_MASK (0x180U) |
#define | DCDC_REG1_REG_FBK_SEL_SHIFT (7U) |
#define | DCDC_REG1_REG_FBK_SEL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_REG_FBK_SEL_SHIFT)) & DCDC_REG1_REG_FBK_SEL_MASK) |
#define | DCDC_REG1_REG_RLOAD_SW_MASK (0x200U) |
#define | DCDC_REG1_REG_RLOAD_SW_SHIFT (9U) |
#define | DCDC_REG1_REG_RLOAD_SW(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_REG_RLOAD_SW_SHIFT)) & DCDC_REG1_REG_RLOAD_SW_MASK) |
#define | DCDC_REG1_LP_CMP_ISRC_SEL_MASK (0x3000U) |
#define | DCDC_REG1_LP_CMP_ISRC_SEL_SHIFT (12U) |
#define | DCDC_REG1_LP_CMP_ISRC_SEL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LP_CMP_ISRC_SEL_SHIFT)) & DCDC_REG1_LP_CMP_ISRC_SEL_MASK) |
#define | DCDC_REG1_LOOPCTRL_HST_THRESH_MASK (0x200000U) |
#define | DCDC_REG1_LOOPCTRL_HST_THRESH_SHIFT (21U) |
#define | DCDC_REG1_LOOPCTRL_HST_THRESH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_HST_THRESH_MASK) |
#define | DCDC_REG1_LOOPCTRL_EN_HYST_MASK (0x800000U) |
#define | DCDC_REG1_LOOPCTRL_EN_HYST_SHIFT (23U) |
#define | DCDC_REG1_LOOPCTRL_EN_HYST(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_HYST_MASK) |
#define | DCDC_REG1_VBG_TRIM_MASK (0x1F000000U) |
#define | DCDC_REG1_VBG_TRIM_SHIFT (24U) |
#define | DCDC_REG1_VBG_TRIM(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_VBG_TRIM_SHIFT)) & DCDC_REG1_VBG_TRIM_MASK) |
REG2 - DCDC Register 2 | |
#define | DCDC_REG2_LOOPCTRL_DC_FF_MASK (0x1C0U) |
#define | DCDC_REG2_LOOPCTRL_DC_FF_SHIFT (6U) |
#define | DCDC_REG2_LOOPCTRL_DC_FF(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_DC_FF_SHIFT)) & DCDC_REG2_LOOPCTRL_DC_FF_MASK) |
#define | DCDC_REG2_LOOPCTRL_EN_RCSCALE_MASK (0xE00U) |
#define | DCDC_REG2_LOOPCTRL_EN_RCSCALE_SHIFT (9U) |
#define | DCDC_REG2_LOOPCTRL_EN_RCSCALE(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_EN_RCSCALE_SHIFT)) & DCDC_REG2_LOOPCTRL_EN_RCSCALE_MASK) |
#define | DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_MASK (0x1000U) |
#define | DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_SHIFT (12U) |
#define | DCDC_REG2_LOOPCTRL_RCSCALE_THRSH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_SHIFT)) & DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_MASK) |
#define | DCDC_REG2_LOOPCTRL_HYST_SIGN_MASK (0x2000U) |
#define | DCDC_REG2_LOOPCTRL_HYST_SIGN_SHIFT (13U) |
#define | DCDC_REG2_LOOPCTRL_HYST_SIGN(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_HYST_SIGN_SHIFT)) & DCDC_REG2_LOOPCTRL_HYST_SIGN_MASK) |
#define | DCDC_REG2_DISABLE_PULSE_SKIP_MASK (0x8000000U) |
#define | DCDC_REG2_DISABLE_PULSE_SKIP_SHIFT (27U) |
#define | DCDC_REG2_DISABLE_PULSE_SKIP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_DISABLE_PULSE_SKIP_SHIFT)) & DCDC_REG2_DISABLE_PULSE_SKIP_MASK) |
#define | DCDC_REG2_DCM_SET_CTRL_MASK (0x10000000U) |
#define | DCDC_REG2_DCM_SET_CTRL_SHIFT (28U) |
#define | DCDC_REG2_DCM_SET_CTRL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_DCM_SET_CTRL_SHIFT)) & DCDC_REG2_DCM_SET_CTRL_MASK) |
REG3 - DCDC Register 3 | |
#define | DCDC_REG3_TRG_MASK (0x1FU) |
#define | DCDC_REG3_TRG_SHIFT (0U) |
#define | DCDC_REG3_TRG(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_TRG_SHIFT)) & DCDC_REG3_TRG_MASK) |
#define | DCDC_REG3_TARGET_LP_MASK (0x700U) |
#define | DCDC_REG3_TARGET_LP_SHIFT (8U) |
#define | DCDC_REG3_TARGET_LP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_TARGET_LP_SHIFT)) & DCDC_REG3_TARGET_LP_MASK) |
#define | DCDC_REG3_MINPWR_DC_HALFCLK_MASK (0x1000000U) |
#define | DCDC_REG3_MINPWR_DC_HALFCLK_SHIFT (24U) |
#define | DCDC_REG3_MINPWR_DC_HALFCLK(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_MINPWR_DC_HALFCLK_SHIFT)) & DCDC_REG3_MINPWR_DC_HALFCLK_MASK) |
#define | DCDC_REG3_DISABLE_STEP_MASK (0x40000000U) |
#define | DCDC_REG3_DISABLE_STEP_SHIFT (30U) |
#define | DCDC_REG3_DISABLE_STEP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_STEP_SHIFT)) & DCDC_REG3_DISABLE_STEP_MASK) |
CTRL0 - DCDC Control Register 0 | |
#define | DCDC_CTRL0_ENABLE_MASK (0x1U) |
#define | DCDC_CTRL0_ENABLE_SHIFT (0U) |
#define | DCDC_CTRL0_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_ENABLE_SHIFT)) & DCDC_CTRL0_ENABLE_MASK) |
#define | DCDC_CTRL0_DIG_EN_MASK (0x2U) |
#define | DCDC_CTRL0_DIG_EN_SHIFT (1U) |
#define | DCDC_CTRL0_DIG_EN(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_DIG_EN_SHIFT)) & DCDC_CTRL0_DIG_EN_MASK) |
#define | DCDC_CTRL0_STBY_EN_MASK (0x4U) |
#define | DCDC_CTRL0_STBY_EN_SHIFT (2U) |
#define | DCDC_CTRL0_STBY_EN(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_STBY_EN_SHIFT)) & DCDC_CTRL0_STBY_EN_MASK) |
#define | DCDC_CTRL0_LP_MODE_EN_MASK (0x8U) |
#define | DCDC_CTRL0_LP_MODE_EN_SHIFT (3U) |
#define | DCDC_CTRL0_LP_MODE_EN(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_LP_MODE_EN_SHIFT)) & DCDC_CTRL0_LP_MODE_EN_MASK) |
#define | DCDC_CTRL0_STBY_LP_MODE_EN_MASK (0x10U) |
#define | DCDC_CTRL0_STBY_LP_MODE_EN_SHIFT (4U) |
#define | DCDC_CTRL0_STBY_LP_MODE_EN(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_STBY_LP_MODE_EN_SHIFT)) & DCDC_CTRL0_STBY_LP_MODE_EN_MASK) |
#define | DCDC_CTRL0_ENABLE_DCDC_CNT_MASK (0x20U) |
#define | DCDC_CTRL0_ENABLE_DCDC_CNT_SHIFT (5U) |
#define | DCDC_CTRL0_ENABLE_DCDC_CNT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_ENABLE_DCDC_CNT_SHIFT)) & DCDC_CTRL0_ENABLE_DCDC_CNT_MASK) |
#define | DCDC_CTRL0_TRIM_HOLD_MASK (0x40U) |
#define | DCDC_CTRL0_TRIM_HOLD_SHIFT (6U) |
#define | DCDC_CTRL0_TRIM_HOLD(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_TRIM_HOLD_SHIFT)) & DCDC_CTRL0_TRIM_HOLD_MASK) |
#define | DCDC_CTRL0_DEBUG_BITS_MASK (0x7FF80000U) |
#define | DCDC_CTRL0_DEBUG_BITS_SHIFT (19U) |
#define | DCDC_CTRL0_DEBUG_BITS(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_DEBUG_BITS_SHIFT)) & DCDC_CTRL0_DEBUG_BITS_MASK) |
#define | DCDC_CTRL0_CONTROL_MODE_MASK (0x80000000U) |
#define | DCDC_CTRL0_CONTROL_MODE_SHIFT (31U) |
#define | DCDC_CTRL0_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_CONTROL_MODE_SHIFT)) & DCDC_CTRL0_CONTROL_MODE_MASK) |
CTRL1 - DCDC Control Register 1 | |
#define | DCDC_CTRL1_VDD1P8CTRL_TRG_MASK (0x1FU) |
#define | DCDC_CTRL1_VDD1P8CTRL_TRG_SHIFT (0U) |
#define | DCDC_CTRL1_VDD1P8CTRL_TRG(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P8CTRL_TRG_SHIFT)) & DCDC_CTRL1_VDD1P8CTRL_TRG_MASK) |
#define | DCDC_CTRL1_VDD1P0CTRL_TRG_MASK (0x1F00U) |
#define | DCDC_CTRL1_VDD1P0CTRL_TRG_SHIFT (8U) |
#define | DCDC_CTRL1_VDD1P0CTRL_TRG(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P0CTRL_TRG_SHIFT)) & DCDC_CTRL1_VDD1P0CTRL_TRG_MASK) |
#define | DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_MASK (0x1F0000U) |
#define | DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_SHIFT (16U) |
#define | DCDC_CTRL1_VDD1P8CTRL_STBY_TRG(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_SHIFT)) & DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_MASK) |
#define | DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_MASK (0x1F000000U) |
#define | DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_SHIFT (24U) |
#define | DCDC_CTRL1_VDD1P0CTRL_STBY_TRG(x) (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_SHIFT)) & DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_MASK) |
#define | DCDC_REG0_PWD_CMP_DCDC_IN_DET_MASK (0x800U) |
#define | DCDC_REG0_PWD_CMP_DCDC_IN_DET_SHIFT (11U) |
#define | DCDC_REG0_PWD_CMP_DCDC_IN_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_DCDC_IN_DET_SHIFT)) & DCDC_REG0_PWD_CMP_DCDC_IN_DET_MASK) |
#define | DCDC_REG0_PWD_HIGH_VDD1P8_DET_MASK (0x10000U) |
#define | DCDC_REG0_PWD_HIGH_VDD1P8_DET_SHIFT (16U) |
#define | DCDC_REG0_PWD_HIGH_VDD1P8_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VDD1P8_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VDD1P8_DET_MASK) |
#define | DCDC_REG0_PWD_HIGH_VDD1P0_DET_MASK (0x20000U) |
#define | DCDC_REG0_PWD_HIGH_VDD1P0_DET_SHIFT (17U) |
#define | DCDC_REG0_PWD_HIGH_VDD1P0_DET(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VDD1P0_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VDD1P0_DET_MASK) |
#define | DCDC_REG1_DM_CTRL_MASK (0x8U) |
#define | DCDC_REG1_DM_CTRL_SHIFT (3U) |
#define | DCDC_REG1_DM_CTRL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_DM_CTRL_SHIFT)) & DCDC_REG1_DM_CTRL_MASK) |
#define | DCDC_REG1_RLOAD_REG_EN_LPSR_MASK (0x10U) |
#define | DCDC_REG1_RLOAD_REG_EN_LPSR_SHIFT (4U) |
#define | DCDC_REG1_RLOAD_REG_EN_LPSR(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_RLOAD_REG_EN_LPSR_SHIFT)) & DCDC_REG1_RLOAD_REG_EN_LPSR_MASK) |
#define | DCDC_REG1_VBG_TRIM_MASK (0x7C0U) |
#define | DCDC_REG1_VBG_TRIM_SHIFT (6U) |
#define | DCDC_REG1_LP_CMP_ISRC_SEL_MASK (0x1800U) |
#define | DCDC_REG1_LP_CMP_ISRC_SEL_SHIFT (11U) |
#define | DCDC_REG1_LOOPCTRL_CM_HST_THRESH_MASK (0x8000000U) |
#define | DCDC_REG1_LOOPCTRL_CM_HST_THRESH_SHIFT (27U) |
#define | DCDC_REG1_LOOPCTRL_CM_HST_THRESH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_CM_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_CM_HST_THRESH_MASK) |
#define | DCDC_REG1_LOOPCTRL_DF_HST_THRESH_MASK (0x10000000U) |
#define | DCDC_REG1_LOOPCTRL_DF_HST_THRESH_SHIFT (28U) |
#define | DCDC_REG1_LOOPCTRL_DF_HST_THRESH(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_DF_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_DF_HST_THRESH_MASK) |
#define | DCDC_REG1_LOOPCTRL_EN_CM_HYST_MASK (0x20000000U) |
#define | DCDC_REG1_LOOPCTRL_EN_CM_HYST_SHIFT (29U) |
#define | DCDC_REG1_LOOPCTRL_EN_CM_HYST(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_CM_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_CM_HYST_MASK) |
#define | DCDC_REG1_LOOPCTRL_EN_DF_HYST_MASK (0x40000000U) |
#define | DCDC_REG1_LOOPCTRL_EN_DF_HYST_SHIFT (30U) |
#define | DCDC_REG1_LOOPCTRL_EN_DF_HYST(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_DF_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_DF_HYST_MASK) |
#define | DCDC_REG2_LOOPCTRL_DC_C_MASK (0x3U) |
#define | DCDC_REG2_LOOPCTRL_DC_C_SHIFT (0U) |
#define | DCDC_REG2_LOOPCTRL_DC_C(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_DC_C_SHIFT)) & DCDC_REG2_LOOPCTRL_DC_C_MASK) |
#define | DCDC_REG2_LOOPCTRL_DC_R_MASK (0x3CU) |
#define | DCDC_REG2_LOOPCTRL_DC_R_SHIFT (2U) |
#define | DCDC_REG2_LOOPCTRL_DC_R(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_DC_R_SHIFT)) & DCDC_REG2_LOOPCTRL_DC_R_MASK) |
#define | DCDC_REG2_BATTMONITOR_EN_BATADJ_MASK (0x8000U) |
#define | DCDC_REG2_BATTMONITOR_EN_BATADJ_SHIFT (15U) |
#define | DCDC_REG2_BATTMONITOR_EN_BATADJ(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_BATTMONITOR_EN_BATADJ_SHIFT)) & DCDC_REG2_BATTMONITOR_EN_BATADJ_MASK) |
#define | DCDC_REG2_BATTMONITOR_BATT_VAL_MASK (0x3FF0000U) |
#define | DCDC_REG2_BATTMONITOR_BATT_VAL_SHIFT (16U) |
#define | DCDC_REG2_BATTMONITOR_BATT_VAL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_BATTMONITOR_BATT_VAL_SHIFT)) & DCDC_REG2_BATTMONITOR_BATT_VAL_MASK) |
#define | DCDC_REG2_LOOPCTRL_TOGGLE_DIF_MASK (0x40000000U) |
#define | DCDC_REG2_LOOPCTRL_TOGGLE_DIF_SHIFT (30U) |
#define | DCDC_REG2_LOOPCTRL_TOGGLE_DIF(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_TOGGLE_DIF_SHIFT)) & DCDC_REG2_LOOPCTRL_TOGGLE_DIF_MASK) |
#define | DCDC_REG3_IN_BROWNOUT_MASK (0x4000U) |
#define | DCDC_REG3_IN_BROWNOUT_SHIFT (14U) |
#define | DCDC_REG3_IN_BROWNOUT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_IN_BROWNOUT_SHIFT)) & DCDC_REG3_IN_BROWNOUT_MASK) |
#define | DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_MASK (0x8000U) |
#define | DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_SHIFT (15U) |
#define | DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_SHIFT)) & DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_MASK) |
#define | DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_MASK (0x10000U) |
#define | DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_SHIFT (16U) |
#define | DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_SHIFT)) & DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_MASK) |
#define | DCDC_REG3_OVERCUR_DETECT_OUT_MASK (0x20000U) |
#define | DCDC_REG3_OVERCUR_DETECT_OUT_SHIFT (17U) |
#define | DCDC_REG3_OVERCUR_DETECT_OUT(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERCUR_DETECT_OUT_SHIFT)) & DCDC_REG3_OVERCUR_DETECT_OUT_MASK) |
#define | DCDC_REG3_ENABLE_FF_MASK (0x40000U) |
#define | DCDC_REG3_ENABLE_FF_SHIFT (18U) |
#define | DCDC_REG3_ENABLE_FF(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_ENABLE_FF_SHIFT)) & DCDC_REG3_ENABLE_FF_MASK) |
#define | DCDC_REG3_DISABLE_PULSE_SKIP_MASK (0x80000U) |
#define | DCDC_REG3_DISABLE_PULSE_SKIP_SHIFT (19U) |
#define | DCDC_REG3_DISABLE_PULSE_SKIP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_PULSE_SKIP_SHIFT)) & DCDC_REG3_DISABLE_PULSE_SKIP_MASK) |
#define | DCDC_REG3_DISABLE_IDLE_SKIP_MASK (0x100000U) |
#define | DCDC_REG3_DISABLE_IDLE_SKIP_SHIFT (20U) |
#define | DCDC_REG3_DISABLE_IDLE_SKIP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_IDLE_SKIP_SHIFT)) & DCDC_REG3_DISABLE_IDLE_SKIP_MASK) |
#define | DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_MASK (0x200000U) |
#define | DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_SHIFT (21U) |
#define | DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_SHIFT)) & DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_MASK) |
#define | DCDC_REG3_REG_FBK_SEL_MASK (0xC00000U) |
#define | DCDC_REG3_REG_FBK_SEL_SHIFT (22U) |
#define | DCDC_REG3_REG_FBK_SEL(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_REG_FBK_SEL_SHIFT)) & DCDC_REG3_REG_FBK_SEL_MASK) |
#define | DCDC_REG3_MINPWR_HALF_FETS_MASK (0x4000000U) |
#define | DCDC_REG3_MINPWR_HALF_FETS_SHIFT (26U) |
#define | DCDC_REG3_MINPWR_HALF_FETS(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_MINPWR_HALF_FETS_SHIFT)) & DCDC_REG3_MINPWR_HALF_FETS_MASK) |
#define | DCDC_REG3_MISC_DELAY_TIMING_MASK (0x8000000U) |
#define | DCDC_REG3_MISC_DELAY_TIMING_SHIFT (27U) |
#define | DCDC_REG3_MISC_DELAY_TIMING(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_MISC_DELAY_TIMING_SHIFT)) & DCDC_REG3_MISC_DELAY_TIMING_MASK) |
#define | DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_MASK (0x20000000U) |
#define | DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_SHIFT (29U) |
#define | DCDC_REG3_VDD1P0CTRL_DISABLE_STEP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_SHIFT)) & DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_MASK) |
#define | DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_MASK (0x40000000U) |
#define | DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_SHIFT (30U) |
#define | DCDC_REG3_VDD1P8CTRL_DISABLE_STEP(x) (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_SHIFT)) & DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_MASK) |
#define DCDC_CTRL0_CONTROL_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_CONTROL_MODE_SHIFT)) & DCDC_CTRL0_CONTROL_MODE_MASK) |
CONTROL_MODE - Control mode 0b0..Software control mode 0b1..Hardware control mode (controlled by GPC Setpoints)
#define DCDC_CTRL0_DEBUG_BITS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_DEBUG_BITS_SHIFT)) & DCDC_CTRL0_DEBUG_BITS_MASK) |
DEBUG_BITS - DEBUG_BITS[11:0]
#define DCDC_CTRL0_DIG_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_DIG_EN_SHIFT)) & DCDC_CTRL0_DIG_EN_MASK) |
DIG_EN 0b0..Reserved 0b1..Enable
#define DCDC_CTRL0_ENABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_ENABLE_SHIFT)) & DCDC_CTRL0_ENABLE_MASK) |
ENABLE 0b0..Disable (Bypass) 0b1..Enable
#define DCDC_CTRL0_ENABLE_DCDC_CNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_ENABLE_DCDC_CNT_SHIFT)) & DCDC_CTRL0_ENABLE_DCDC_CNT_MASK) |
ENABLE_DCDC_CNT - Enable internal count for DCDC_OK timeout 0b0..Wait DCDC_OK for ACK 0b1..Enable internal count for DCDC_OK timeout
#define DCDC_CTRL0_LP_MODE_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_LP_MODE_EN_SHIFT)) & DCDC_CTRL0_LP_MODE_EN_MASK) |
LP_MODE_EN 0b1..Enter into low-power mode
#define DCDC_CTRL0_STBY_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_STBY_EN_SHIFT)) & DCDC_CTRL0_STBY_EN_MASK) |
STBY_EN 0b1..Enter into standby mode
#define DCDC_CTRL0_STBY_LP_MODE_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_STBY_LP_MODE_EN_SHIFT)) & DCDC_CTRL0_STBY_LP_MODE_EN_MASK) |
STBY_LP_MODE_EN 0b0..Disable DCDC entry into low-power mode from a GPC standby request 0b1..Enable DCDC to enter into low-power mode from a GPC standby request
#define DCDC_CTRL0_TRIM_HOLD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL0_TRIM_HOLD_SHIFT)) & DCDC_CTRL0_TRIM_HOLD_MASK) |
TRIM_HOLD - Hold trim input 0b0..Sample trim input 0b1..Hold trim input
#define DCDC_CTRL1_VDD1P0CTRL_STBY_TRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_SHIFT)) & DCDC_CTRL1_VDD1P0CTRL_STBY_TRG_MASK) |
VDD1P0CTRL_STBY_TRG 0b11111..1.4V 0b01111..1.0V 0b00000..0.625V
#define DCDC_CTRL1_VDD1P0CTRL_TRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P0CTRL_TRG_SHIFT)) & DCDC_CTRL1_VDD1P0CTRL_TRG_MASK) |
VDD1P0CTRL_TRG 0b11111..1.375V 0b10000..1.0V 0b00000..0.6V
#define DCDC_CTRL1_VDD1P8CTRL_STBY_TRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_SHIFT)) & DCDC_CTRL1_VDD1P8CTRL_STBY_TRG_MASK) |
VDD1P8CTRL_STBY_TRG 0b11111..2.3V 0b01011..1.8V 0b00000..1.525V
#define DCDC_CTRL1_VDD1P8CTRL_TRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_CTRL1_VDD1P8CTRL_TRG_SHIFT)) & DCDC_CTRL1_VDD1P8CTRL_TRG_MASK) |
VDD1P8CTRL_TRG 0b11111..2.275V 0b01100..1.8V 0b00000..1.5V
#define DCDC_REG0_CUR_SNS_THRSH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_CUR_SNS_THRSH_SHIFT)) & DCDC_REG0_CUR_SNS_THRSH_MASK) |
CUR_SNS_THRSH - Current Sense (detector) Threshold 0b000..150 mA 0b001..250 mA 0b010..350 mA 0b011..450 mA 0b100..550 mA 0b101..650 mA
#define DCDC_REG0_CURRENT_ALERT_RESET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_CURRENT_ALERT_RESET_SHIFT)) & DCDC_REG0_CURRENT_ALERT_RESET_MASK) |
CURRENT_ALERT_RESET - Reset Current Alert Signal 0b0..Current Alert Signal not reset 0b1..Current Alert Signal reset
#define DCDC_REG0_DISABLE_AUTO_CLK_SWITCH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_SHIFT)) & DCDC_REG0_DISABLE_AUTO_CLK_SWITCH_MASK) |
DISABLE_AUTO_CLK_SWITCH - Disable Auto Clock Switch 0b0..If DISABLE_AUTO_CLK_SWITCH is set to 0 and 24M xtal is OK, the clock source will switch from internal ring OSC to 24M xtal automatically 0b1..If DISABLE_AUTO_CLK_SWITCH is set to 1, SEL_CLK will determine which clock source the DCDC uses
DISABLE_AUTO_CLK_SWITCH - Disable Auto Clock Switch 0b0..If DISABLE_AUTO_CLK_SWITCH is set to 0 and 24M xtal is OK, the clock source will switch from internal ring oscillator to 24M xtal automatically 0b1..If DISABLE_AUTO_CLK_SWITCH is set to 1, SEL_CLK will determine which clock source the DCDC uses
#define DCDC_REG0_EN_LP_OVERLOAD_SNS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_EN_LP_OVERLOAD_SNS_SHIFT)) & DCDC_REG0_EN_LP_OVERLOAD_SNS_MASK) |
EN_LP_OVERLOAD_SNS - Low Power Overload Sense Enable 0b0..Overload Detection in power save mode disabled 0b1..Overload Detection in power save mode enabled
#define DCDC_REG0_LP_HIGH_HYS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_HIGH_HYS_SHIFT)) & DCDC_REG0_LP_HIGH_HYS_MASK) |
LP_HIGH_HYS - Low Power High Hysteric Value 0b0..Adjust hysteretic value in low power to 12.5mV 0b1..Adjust hysteretic value in low power to 25mV
#define DCDC_REG0_LP_OVERLOAD_FREQ_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_OVERLOAD_FREQ_SEL_SHIFT)) & DCDC_REG0_LP_OVERLOAD_FREQ_SEL_MASK) |
LP_OVERLOAD_FREQ_SEL - Low Power Overload Frequency Select 0b0..eight 32k cycle 0b1..sixteen 32k cycle
#define DCDC_REG0_LP_OVERLOAD_THRSH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_LP_OVERLOAD_THRSH_SHIFT)) & DCDC_REG0_LP_OVERLOAD_THRSH_MASK) |
LP_OVERLOAD_THRSH - Low Power Overload Threshold 0b00..32 0b01..64 0b10..16 0b11..8
#define DCDC_REG0_OVERCUR_TRIG_ADJ | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_OVERCUR_TRIG_ADJ_SHIFT)) & DCDC_REG0_OVERCUR_TRIG_ADJ_MASK) |
OVERCUR_TRIG_ADJ - Overcurrent Trigger Adjust 0b00..In Run Mode, 1 A. In Power Save Mode, 0.25 A 0b01..In Run Mode, 2 A. In Power Save Mode, 0.25 A 0b10..In Run Mode, 1 A. In Power Save Mode, 0.2 A 0b11..In Run Mode, 2 A. In Power Save Mode, 0.2 A
#define DCDC_REG0_PWD_CMP_BATT_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_BATT_DET_SHIFT)) & DCDC_REG0_PWD_CMP_BATT_DET_MASK) |
PWD_CMP_BATT_DET - Power Down Battery Detection Comparator 0b0..Low voltage detection comparator is enabled 0b1..Low voltage detection comparator is disabled
#define DCDC_REG0_PWD_CMP_DCDC_IN_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_DCDC_IN_DET_SHIFT)) & DCDC_REG0_PWD_CMP_DCDC_IN_DET_MASK) |
PWD_CMP_DCDC_IN_DET 0b0..Low voltage detection comparator is enabled 0b1..Low voltage detection comparator is disabled
#define DCDC_REG0_PWD_CMP_OFFSET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CMP_OFFSET_SHIFT)) & DCDC_REG0_PWD_CMP_OFFSET_MASK) |
PWD_CMP_OFFSET - Power down output range comparator 0b0..Output range comparator powered up 0b1..Output range comparator powered down
PWD_CMP_OFFSET - power down the out-of-range detection comparator 0b0..Out-of-range comparator powered up 0b1..Out-of-range comparator powered down
#define DCDC_REG0_PWD_CUR_SNS_CMP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_CUR_SNS_CMP_SHIFT)) & DCDC_REG0_PWD_CUR_SNS_CMP_MASK) |
PWD_CUR_SNS_CMP - Power down signal of the current detector. 0b0..Current Detector powered up 0b1..Current Detector powered down
PWD_CUR_SNS_CMP - Power down signal of the current detector 0b0..Current Detector powered up 0b1..Current Detector powered down
#define DCDC_REG0_PWD_HIGH_VDD1P0_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VDD1P0_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VDD1P0_DET_MASK) |
PWD_HIGH_VDD1P0_DET - Power Down High Voltage Detection for VDD1P0 0b0..Overvoltage detection comparator for the VDD1P0 output is enabled 0b1..Overvoltage detection comparator for the VDD1P0 output is disabled
#define DCDC_REG0_PWD_HIGH_VDD1P8_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VDD1P8_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VDD1P8_DET_MASK) |
PWD_HIGH_VDD1P8_DET - Power Down High Voltage Detection for VDD1P8 0b0..Overvoltage detection comparator for the VDD1P8 output is enabled 0b1..Overvoltage detection comparator for the VDD1P8 output is disabled
#define DCDC_REG0_PWD_HIGH_VOLT_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_HIGH_VOLT_DET_SHIFT)) & DCDC_REG0_PWD_HIGH_VOLT_DET_MASK) |
PWD_HIGH_VOLT_DET - Power Down High Voltage Detection 0b0..Overvoltage detection comparator is enabled 0b1..Overvoltage detection comparator is disabled
#define DCDC_REG0_PWD_OSC_INT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_OSC_INT_SHIFT)) & DCDC_REG0_PWD_OSC_INT_MASK) |
PWD_OSC_INT - Power down internal osc 0b0..Internal oscillator powered up 0b1..Internal oscillator powered down
PWD_OSC_INT - Power down internal ring oscillator 0b0..Internal ring oscillator powered up 0b1..Internal ring oscillator powered down
#define DCDC_REG0_PWD_OVERCUR_DET | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_OVERCUR_DET_SHIFT)) & DCDC_REG0_PWD_OVERCUR_DET_MASK) |
PWD_OVERCUR_DET - Power down overcurrent detection comparator 0b0..Overcurrent detection comparator is enabled 0b1..Overcurrent detection comparator is disabled
#define DCDC_REG0_PWD_ZCD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_PWD_ZCD_SHIFT)) & DCDC_REG0_PWD_ZCD_MASK) |
PWD_ZCD - Power Down Zero Cross Detection 0b0..Zero cross detetion function powered up 0b1..Zero cross detetion function powered down
#define DCDC_REG0_SEL_CLK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_SEL_CLK_SHIFT)) & DCDC_REG0_SEL_CLK_MASK) |
SEL_CLK - Select Clock 0b0..DCDC uses internal ring oscillator 0b1..DCDC uses 24M xtal
#define DCDC_REG0_STS_DC_OK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_STS_DC_OK_SHIFT)) & DCDC_REG0_STS_DC_OK_MASK) |
STS_DC_OK - DCDC Output OK 0b0..DCDC is settling 0b1..DCDC already settled
#define DCDC_REG0_XTAL_24M_OK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_XTAL_24M_OK_SHIFT)) & DCDC_REG0_XTAL_24M_OK_MASK) |
XTAL_24M_OK - 24M XTAL OK 0b0..DCDC uses internal ring OSC 0b1..DCDC uses xtal 24M
XTAL_24M_OK - 24M XTAL OK 0b0..DCDC uses internal ring oscillator 0b1..DCDC uses xtal 24M
#define DCDC_REG0_XTALOK_DISABLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG0_XTALOK_DISABLE_SHIFT)) & DCDC_REG0_XTALOK_DISABLE_MASK) |
XTALOK_DISABLE - Disable xtalok detection circuit 0b0..Enable xtalok detection circuit 0b1..Disable xtalok detection circuit and always outputs OK signal "1"
#define DCDC_REG1_DM_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_DM_CTRL_SHIFT)) & DCDC_REG1_DM_CTRL_MASK) |
DM_CTRL - DM Control 0b0..No change to ripple when the discontinuous current is present in DCM. 0b1..Improves ripple when the inductor current goes to zero in DCM.
#define DCDC_REG1_LOOPCTRL_CM_HST_THRESH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_CM_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_CM_HST_THRESH_MASK) |
LOOPCTRL_CM_HST_THRESH - Increase Threshold Detection
#define DCDC_REG1_LOOPCTRL_DF_HST_THRESH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_DF_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_DF_HST_THRESH_MASK) |
LOOPCTRL_DF_HST_THRESH - Increase Threshold Detection
#define DCDC_REG1_LOOPCTRL_EN_CM_HYST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_CM_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_CM_HYST_MASK) |
LOOPCTRL_EN_CM_HYST 0b0..Disable hysteresis in switching converter common mode analog comparators 0b1..Enable hysteresis in switching converter common mode analog comparators
#define DCDC_REG1_LOOPCTRL_EN_DF_HYST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_DF_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_DF_HYST_MASK) |
LOOPCTRL_EN_DF_HYST 0b0..Disable hysteresis in switching converter differential mode analog comparators 0b1..Enable hysteresis in switching converter differential mode analog comparators
#define DCDC_REG1_LOOPCTRL_EN_HYST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_EN_HYST_SHIFT)) & DCDC_REG1_LOOPCTRL_EN_HYST_MASK) |
LOOPCTRL_EN_HYST - Enable Hysteresis 0b0..Disable hysteresis in switching converter common mode analog comparators 0b1..Enable hysteresis in switching converter common mode analog comparators
#define DCDC_REG1_LOOPCTRL_HST_THRESH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LOOPCTRL_HST_THRESH_SHIFT)) & DCDC_REG1_LOOPCTRL_HST_THRESH_MASK) |
LOOPCTRL_HST_THRESH - Increase Threshold Detection 0b0..Lower hysteresis threshold (about 2.5mV in typical, but this value can vary with PVT corners 0b1..Higher hysteresis threshold (about 5mV in typical)
#define DCDC_REG1_LP_CMP_ISRC_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_LP_CMP_ISRC_SEL_SHIFT)) & DCDC_REG1_LP_CMP_ISRC_SEL_MASK) |
LP_CMP_ISRC_SEL - Low Power Comparator Current Bias 0b00..50 nA 0b01..100 nA 0b10..200 nA 0b11..400 nA
LP_CMP_ISRC_SEL - Low Power Comparator Current Bias 0b00..50nA 0b01..100nA 0b10..200nA 0b11..400nA
#define DCDC_REG1_REG_FBK_SEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_REG_FBK_SEL_SHIFT)) & DCDC_REG1_REG_FBK_SEL_MASK) |
REG_FBK_SEL 0b00..The regulator outputs 1.0V with 1.2V reference voltage 0b01..The regulator outputs 1.1V with 1.2V reference voltage 0b10..The regulator outputs 1.0V with 1.3V reference voltage 0b11..The regulator outputs 1.1V with 1.3V reference voltage
#define DCDC_REG1_REG_RLOAD_SW | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_REG_RLOAD_SW_SHIFT)) & DCDC_REG1_REG_RLOAD_SW_MASK) |
REG_RLOAD_SW 0b0..Load resistor disconnected 0b1..Load resistor connected
#define DCDC_REG1_RLOAD_REG_EN_LPSR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_RLOAD_REG_EN_LPSR_SHIFT)) & DCDC_REG1_RLOAD_REG_EN_LPSR_MASK) |
RLOAD_REG_EN_LPSR - Load Resistor Enable 0b0..Disconnect load resistor 0b1..Connect load resistor
#define DCDC_REG1_VBG_TRIM | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG1_VBG_TRIM_SHIFT)) & DCDC_REG1_VBG_TRIM_MASK) |
VBG_TRIM - Trim Bandgap Voltage
VBG_TRIM - Trim Bandgap Voltage 0b00000..0.452V 0b10000..0.5V 0b11111..0.545V
#define DCDC_REG2_DCM_SET_CTRL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_DCM_SET_CTRL_SHIFT)) & DCDC_REG2_DCM_SET_CTRL_MASK) |
DCM_SET_CTRL - DCM Set Control
#define DCDC_REG2_DISABLE_PULSE_SKIP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_DISABLE_PULSE_SKIP_SHIFT)) & DCDC_REG2_DISABLE_PULSE_SKIP_MASK) |
DISABLE_PULSE_SKIP - Disable Pulse Skip 0b0..DCDC will be idle to save current dissipation when the duty cycle get to the low limit which is set by NEGLIMIT_IN. 0b1..DCDC will keep working with the low limited duty cycle NEGLIMIT_IN.
#define DCDC_REG2_LOOPCTRL_EN_RCSCALE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_EN_RCSCALE_SHIFT)) & DCDC_REG2_LOOPCTRL_EN_RCSCALE_MASK) |
LOOPCTRL_EN_RCSCALE - Enable RC Scale
#define DCDC_REG2_LOOPCTRL_HYST_SIGN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_HYST_SIGN_SHIFT)) & DCDC_REG2_LOOPCTRL_HYST_SIGN_MASK) |
LOOPCTRL_HYST_SIGN 0b0..Do not invert sign of the hysteresis 0b1..Invert sign of the hysteresis
#define DCDC_REG2_LOOPCTRL_RCSCALE_THRSH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_SHIFT)) & DCDC_REG2_LOOPCTRL_RCSCALE_THRSH_MASK) |
LOOPCTRL_RCSCALE_THRSH 0b0..Do not increase the threshold detection for RC scale circuit. 0b1..Increase the threshold detection for RC scale circuit.
#define DCDC_REG3_DISABLE_IDLE_SKIP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_IDLE_SKIP_SHIFT)) & DCDC_REG3_DISABLE_IDLE_SKIP_MASK) |
DISABLE_IDLE_SKIP 0b0..Enable the idle skip function. The DCDC will be idle when out-of-range comparator detects the output voltage is higher than the target by 25mV. This function requires the out-of-range comparator to be enabled (PWD_CMP_OFFSET=0).
#define DCDC_REG3_DISABLE_PULSE_SKIP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_PULSE_SKIP_SHIFT)) & DCDC_REG3_DISABLE_PULSE_SKIP_MASK) |
DISABLE_PULSE_SKIP - Disable Pulse Skip 0b0..Stop charging if the duty cycle is lower than what is set by NEGLIMIT_IN
#define DCDC_REG3_DISABLE_STEP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DISABLE_STEP_SHIFT)) & DCDC_REG3_DISABLE_STEP_MASK) |
DISABLE_STEP - Disable Step 0b0..Enable stepping for the output of VDD_SOC of DCDC 0b1..Disable stepping for the output of VDD_SOC of DCDC
#define DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_SHIFT)) & DCDC_REG3_DOUBLE_IBIAS_CMP_LP_LPSR_MASK) |
DOUBLE_IBIAS_CMP_LP_LPSR 0b1..Double the bias current of the comparator for low-voltage detector in LP (low-power) mode
#define DCDC_REG3_ENABLE_FF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_ENABLE_FF_SHIFT)) & DCDC_REG3_ENABLE_FF_MASK) |
ENABLE_FF 0b1..Enable feed-forward (FF) function that can speed up transient settling.
#define DCDC_REG3_IN_BROWNOUT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_IN_BROWNOUT_SHIFT)) & DCDC_REG3_IN_BROWNOUT_MASK) |
IN_BROWNOUT 0b1..DCDC_IN is lower than 2.6V
#define DCDC_REG3_MINPWR_DC_HALFCLK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_MINPWR_DC_HALFCLK_SHIFT)) & DCDC_REG3_MINPWR_DC_HALFCLK_MASK) |
MINPWR_DC_HALFCLK 0b0..DCDC clock remains at full frequency for continuous mode 0b1..DCDC clock set to half frequency for continuous mode
#define DCDC_REG3_MISC_DELAY_TIMING | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_MISC_DELAY_TIMING_SHIFT)) & DCDC_REG3_MISC_DELAY_TIMING_MASK) |
MISC_DELAY_TIMING - Miscellaneous Delay Timing
#define DCDC_REG3_OVERCUR_DETECT_OUT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERCUR_DETECT_OUT_SHIFT)) & DCDC_REG3_OVERCUR_DETECT_OUT_MASK) |
OVERCUR_DETECT_OUT 0b1..Overcurrent
#define DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_SHIFT)) & DCDC_REG3_OVERVOLT_VDD1P0_DET_OUT_MASK) |
OVERVOLT_VDD1P0_DET_OUT 0b1..VDD1P0 Overvoltage
#define DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_SHIFT)) & DCDC_REG3_OVERVOLT_VDD1P8_DET_OUT_MASK) |
OVERVOLT_VDD1P8_DET_OUT 0b1..VDD1P8 Overvoltage
#define DCDC_REG3_TARGET_LP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_TARGET_LP_SHIFT)) & DCDC_REG3_TARGET_LP_MASK) |
TARGET_LP - Low Power Target Value 0b000..0.9 V 0b001..0.925 V 0b010..0.95 V 0b011..0.975 V 0b100..1.0 V
#define DCDC_REG3_TRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_TRG_SHIFT)) & DCDC_REG3_TRG_MASK) |
TRG - Target value of VDD_SOC
#define DCDC_REG3_VDD1P0CTRL_DISABLE_STEP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_SHIFT)) & DCDC_REG3_VDD1P0CTRL_DISABLE_STEP_MASK) |
VDD1P0CTRL_DISABLE_STEP - Disable Step for VDD1P0 0b0..Enable stepping for VDD1P0 0b1..Disable stepping for VDD1P0
#define DCDC_REG3_VDD1P8CTRL_DISABLE_STEP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_SHIFT)) & DCDC_REG3_VDD1P8CTRL_DISABLE_STEP_MASK) |
VDD1P8CTRL_DISABLE_STEP - Disable Step for VDD1P8 0b0..Enable stepping for VDD1P8 0b1..Disable stepping for VDD1P8
