RTEMS 6.1-rc2
CRC Extended Exported Macros
#define __HAL_CRC_OUTPUTREVERSAL_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT)
 Set CRC output reversal.
#define __HAL_CRC_OUTPUTREVERSAL_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT))
 Unset CRC output reversal.
#define __HAL_CRC_POLYNOMIAL_CONFIG(__HANDLE__, __POLYNOMIAL__)   ((__HANDLE__)->Instance->POL = (__POLYNOMIAL__))
 Set CRC non-default polynomial.
◆ __HAL_CRC_OUTPUTREVERSAL_DISABLE
#define __HAL_CRC_OUTPUTREVERSAL_DISABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR &= ~(CRC_CR_REV_OUT))
Parameters
__HANDLE__CRC handle
Return values
None
◆ __HAL_CRC_OUTPUTREVERSAL_ENABLE
#define __HAL_CRC_OUTPUTREVERSAL_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR |= CRC_CR_REV_OUT)
Parameters
Return values
None
◆ __HAL_CRC_POLYNOMIAL_CONFIG
#define __HAL_CRC_POLYNOMIAL_CONFIG (   __HANDLE__,
  __POLYNOMIAL__
Parameters
__POLYNOMIAL__7, 8, 16 or 32-bit polynomial
Return values
None
