RTEMS 6.1-rc2
#define | __HAL_COMP_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_COMP_STATE_RESET) |
Reset COMP handle state. | |
#define | COMP_CLEAR_ERRORCODE(__HANDLE__) ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE) |
Clear COMP error code (set it to no error code "HAL_COMP_ERROR_NONE"). | |
#define | __HAL_COMP_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
Enable the specified comparator. | |
#define | __HAL_COMP_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
Disable the specified comparator. | |
#define | __HAL_COMP_LOCK(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) |
Lock the specified comparator configuration. | |
#define | __HAL_COMP_IS_LOCKED(__HANDLE__) (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK) |
Check whether the specified comparator is locked. | |
#define __HAL_COMP_DISABLE | ( | __HANDLE__ | ) | CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
__HANDLE__ | COMP handle |
None |
#define __HAL_COMP_ENABLE | ( | __HANDLE__ | ) | SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
None |
#define __HAL_COMP_IS_LOCKED | ( | __HANDLE__ | ) | (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK) |
Value | 0 if COMP instance is not locked, value 1 if COMP instance is locked |
#define __HAL_COMP_LOCK | ( | __HANDLE__ | ) | SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) |
None |
#define __HAL_COMP_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_COMP_STATE_RESET) |
None |
#define COMP_CLEAR_ERRORCODE | ( | __HANDLE__ | ) | ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE) |
None |
