RTEMS 6.1-rc2
ISCR - Interrupt Status and Control Register
#define CM7_MCM_ISCR_WABS_MASK   (0x20U)
#define CM7_MCM_ISCR_WABS_SHIFT   (5U)
#define CM7_MCM_ISCR_WABS(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABS_SHIFT)) & CM7_MCM_ISCR_WABS_MASK)
#define CM7_MCM_ISCR_WABSO_MASK   (0x40U)
#define CM7_MCM_ISCR_WABSO_SHIFT   (6U)
#define CM7_MCM_ISCR_WABSO(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABSO_SHIFT)) & CM7_MCM_ISCR_WABSO_MASK)
#define CM7_MCM_ISCR_FIOC_MASK   (0x100U)
#define CM7_MCM_ISCR_FIOC_SHIFT   (8U)
#define CM7_MCM_ISCR_FIOC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIOC_SHIFT)) & CM7_MCM_ISCR_FIOC_MASK)
#define CM7_MCM_ISCR_FDZC_MASK   (0x200U)
#define CM7_MCM_ISCR_FDZC_SHIFT   (9U)
#define CM7_MCM_ISCR_FDZC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FDZC_SHIFT)) & CM7_MCM_ISCR_FDZC_MASK)
#define CM7_MCM_ISCR_FOFC_MASK   (0x400U)
#define CM7_MCM_ISCR_FOFC_SHIFT   (10U)
#define CM7_MCM_ISCR_FOFC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FOFC_SHIFT)) & CM7_MCM_ISCR_FOFC_MASK)
#define CM7_MCM_ISCR_FUFC_MASK   (0x800U)
#define CM7_MCM_ISCR_FUFC_SHIFT   (11U)
#define CM7_MCM_ISCR_FUFC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FUFC_SHIFT)) & CM7_MCM_ISCR_FUFC_MASK)
#define CM7_MCM_ISCR_FIXC_MASK   (0x1000U)
#define CM7_MCM_ISCR_FIXC_SHIFT   (12U)
#define CM7_MCM_ISCR_FIXC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIXC_SHIFT)) & CM7_MCM_ISCR_FIXC_MASK)
#define CM7_MCM_ISCR_FIDC_MASK   (0x8000U)
#define CM7_MCM_ISCR_FIDC_SHIFT   (15U)
#define CM7_MCM_ISCR_FIDC(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIDC_SHIFT)) & CM7_MCM_ISCR_FIDC_MASK)
#define CM7_MCM_ISCR_WABE_MASK   (0x200000U)
#define CM7_MCM_ISCR_WABE_SHIFT   (21U)
#define CM7_MCM_ISCR_WABE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABE_SHIFT)) & CM7_MCM_ISCR_WABE_MASK)
#define CM7_MCM_ISCR_FIOCE_MASK   (0x1000000U)
#define CM7_MCM_ISCR_FIOCE_SHIFT   (24U)
#define CM7_MCM_ISCR_FIOCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIOCE_SHIFT)) & CM7_MCM_ISCR_FIOCE_MASK)
#define CM7_MCM_ISCR_FDZCE_MASK   (0x2000000U)
#define CM7_MCM_ISCR_FDZCE_SHIFT   (25U)
#define CM7_MCM_ISCR_FDZCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FDZCE_SHIFT)) & CM7_MCM_ISCR_FDZCE_MASK)
#define CM7_MCM_ISCR_FOFCE_MASK   (0x4000000U)
#define CM7_MCM_ISCR_FOFCE_SHIFT   (26U)
#define CM7_MCM_ISCR_FOFCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FOFCE_SHIFT)) & CM7_MCM_ISCR_FOFCE_MASK)
#define CM7_MCM_ISCR_FUFCE_MASK   (0x8000000U)
#define CM7_MCM_ISCR_FUFCE_SHIFT   (27U)
#define CM7_MCM_ISCR_FUFCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FUFCE_SHIFT)) & CM7_MCM_ISCR_FUFCE_MASK)
#define CM7_MCM_ISCR_FIXCE_MASK   (0x10000000U)
#define CM7_MCM_ISCR_FIXCE_SHIFT   (28U)
#define CM7_MCM_ISCR_FIXCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIXCE_SHIFT)) & CM7_MCM_ISCR_FIXCE_MASK)
#define CM7_MCM_ISCR_FIDCE_MASK   (0x80000000U)
#define CM7_MCM_ISCR_FIDCE_SHIFT   (31U)
#define CM7_MCM_ISCR_FIDCE(x)   (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIDCE_SHIFT)) & CM7_MCM_ISCR_FIDCE_MASK)
◆ CM7_MCM_ISCR_FDZC
#define CM7_MCM_ISCR_FDZC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FDZC_SHIFT)) & CM7_MCM_ISCR_FDZC_MASK)
FDZC - FPU Divide-by-Zero Interrupt Status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FDZCE
#define CM7_MCM_ISCR_FDZCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FDZCE_SHIFT)) & CM7_MCM_ISCR_FDZCE_MASK)
FDZCE - FPU Divide-by-Zero Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_FIDC
#define CM7_MCM_ISCR_FIDC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIDC_SHIFT)) & CM7_MCM_ISCR_FIDC_MASK)
FIDC - FPU Input Denormal Interrupt Status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FIDCE
#define CM7_MCM_ISCR_FIDCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIDCE_SHIFT)) & CM7_MCM_ISCR_FIDCE_MASK)
FIDCE - FPU Input Denormal Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_FIOC
#define CM7_MCM_ISCR_FIOC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIOC_SHIFT)) & CM7_MCM_ISCR_FIOC_MASK)
FIOC - FPU Invalid Operation interrupt Status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FIOCE
#define CM7_MCM_ISCR_FIOCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIOCE_SHIFT)) & CM7_MCM_ISCR_FIOCE_MASK)
FIOCE - FPU Invalid Operation Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_FIXC
#define CM7_MCM_ISCR_FIXC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIXC_SHIFT)) & CM7_MCM_ISCR_FIXC_MASK)
FIXC - FPU Inexact Interrupt Status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FIXCE
#define CM7_MCM_ISCR_FIXCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FIXCE_SHIFT)) & CM7_MCM_ISCR_FIXCE_MASK)
FIXCE - FPU Inexact Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_FOFC
#define CM7_MCM_ISCR_FOFC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FOFC_SHIFT)) & CM7_MCM_ISCR_FOFC_MASK)
FOFC - FPU Overflow interrupt status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FOFCE
#define CM7_MCM_ISCR_FOFCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FOFCE_SHIFT)) & CM7_MCM_ISCR_FOFCE_MASK)
FOFCE - FPU Overflow Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_FUFC
#define CM7_MCM_ISCR_FUFC (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FUFC_SHIFT)) & CM7_MCM_ISCR_FUFC_MASK)
FUFC - FPU Underflow Interrupt Status 0b0..No interrupt 0b1..Interrupt occured
◆ CM7_MCM_ISCR_FUFCE
#define CM7_MCM_ISCR_FUFCE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_FUFCE_SHIFT)) & CM7_MCM_ISCR_FUFCE_MASK)
FUFCE - FPU Underflow Interrupt Enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_WABE
#define CM7_MCM_ISCR_WABE (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABE_SHIFT)) & CM7_MCM_ISCR_WABE_MASK)
WABE - TCM Write Abort Interrupt enable 0b0..Disable interrupt 0b1..Enable interrupt
◆ CM7_MCM_ISCR_WABS
#define CM7_MCM_ISCR_WABS (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABS_SHIFT)) & CM7_MCM_ISCR_WABS_MASK)
WABS - Write Abort on Slave 0b0..No abort 0b1..Abort
◆ CM7_MCM_ISCR_WABSO
#define CM7_MCM_ISCR_WABSO (   x)    (((uint32_t)(((uint32_t)(x)) << CM7_MCM_ISCR_WABSO_SHIFT)) & CM7_MCM_ISCR_WABSO_MASK)
WABSO - Write Abort on Slave Overrun 0b0..No write abort overrun 0b1..Write abort overrun occurred
