RTEMS 6.1-rc2
TEMPSENSOR - Tempsensor Register
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK   (0x8000U)
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT   (15U)
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK)
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK   (0x10000U)
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT   (16U)
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK)
TEMPSNS_OTP_TRIM_VALUE - TEMPSNS_OTP_TRIM_VALUE_REGISTER
#define ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK   (0x3FFC00U)
#define ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT   (10U)
#define ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL(x)   (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK)
◆ ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY [1/2]
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK)
TEMPSNS_AI_BUSY - AI Busy monitor
◆ ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY [2/2]
◆ ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE [1/2]
#define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK)
TEMPSNS_AI_TOGGLE - AI toggle
◆ ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE [2/2]
◆ ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL [1/2]
#define ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK)
TEMPSNS_TEMP_VAL - Temperature Value at 25C
◆ ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL [2/2]
