RTEMS 6.1-rc2
Data Structures | Macros | Typedefs
This header file defines the GR740 I/O and PLL configuration register block interface. More...
#include <stdint.h>
struct  gr740_iopll
 This structure defines the GR740 I/0 and PLL Configuration register block memory map. More...
#define GR740_IOPLL_FTMFUNC_FTMEN_SHIFT   0
#define GR740_IOPLL_FTMFUNC_FTMEN_MASK   0x3fffffU
#define GR740_IOPLL_FTMFUNC_FTMEN_GET(_reg)
#define GR740_IOPLL_FTMFUNC_FTMEN_SET(_reg, _val)
#define GR740_IOPLL_FTMFUNC_FTMEN(_val)
#define GR740_IOPLL_ALTFUNC_ALTEN_SHIFT   0
#define GR740_IOPLL_ALTFUNC_ALTEN_MASK   0x3fffffU
#define GR740_IOPLL_ALTFUNC_ALTEN_GET(_reg)
#define GR740_IOPLL_ALTFUNC_ALTEN_SET(_reg, _val)
#define GR740_IOPLL_ALTFUNC_ALTEN(_val)
#define GR740_IOPLL_LVDSMCLK_SMEM   0x20000U
#define GR740_IOPLL_LVDSMCLK_DMEM   0x10000U
#define GR740_IOPLL_LVDSMCLK_SPWOE_SHIFT   0
#define GR740_IOPLL_LVDSMCLK_SPWOE_MASK   0xffU
#define GR740_IOPLL_LVDSMCLK_SPWOE_GET(_reg)
#define GR740_IOPLL_LVDSMCLK_SPWOE_SET(_reg, _val)
#define GR740_IOPLL_LVDSMCLK_SPWOE(_val)
#define GR740_IOPLL_PLLNEWCFG_SWTAG_SHIFT   27
#define GR740_IOPLL_PLLNEWCFG_SWTAG_MASK   0x18000000U
#define GR740_IOPLL_PLLNEWCFG_SWTAG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SWTAG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SWTAG(_val)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SHIFT   18
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_MASK   0x7fc0000U
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SPWPLLCFG(_val)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SHIFT   9
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_MASK   0x3fe00U
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_MEMPLLCFG(_val)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SHIFT   0
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_MASK   0x1ffU
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLNEWCFG_SYSPLLCFG(_val)
#define GR740_IOPLL_PLLRECFG_RECONF_SHIFT   0
#define GR740_IOPLL_PLLRECFG_RECONF_MASK   0x7U
#define GR740_IOPLL_PLLRECFG_RECONF_GET(_reg)
#define GR740_IOPLL_PLLRECFG_RECONF_SET(_reg, _val)
#define GR740_IOPLL_PLLRECFG_RECONF(_val)
#define GR740_IOPLL_PLLCURCFG_SWTAG_SHIFT   27
#define GR740_IOPLL_PLLCURCFG_SWTAG_MASK   0x18000000U
#define GR740_IOPLL_PLLCURCFG_SWTAG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SWTAG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SWTAG(_val)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SHIFT   18
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK   0x7fc0000U
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG(_val)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SHIFT   9
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK   0x3fe00U
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG(_val)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SHIFT   0
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK   0x1ffU
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG(_val)
#define GR740_IOPLL_DRVSTR1_S9_SHIFT   18
#define GR740_IOPLL_DRVSTR1_S9_MASK   0xc0000U
#define GR740_IOPLL_DRVSTR1_S9_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S9_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S9(_val)
#define GR740_IOPLL_DRVSTR1_S8_SHIFT   16
#define GR740_IOPLL_DRVSTR1_S8_MASK   0x30000U
#define GR740_IOPLL_DRVSTR1_S8_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S8_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S8(_val)
#define GR740_IOPLL_DRVSTR1_S7_SHIFT   14
#define GR740_IOPLL_DRVSTR1_S7_MASK   0xc000U
#define GR740_IOPLL_DRVSTR1_S7_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S7_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S7(_val)
#define GR740_IOPLL_DRVSTR1_S6_SHIFT   12
#define GR740_IOPLL_DRVSTR1_S6_MASK   0x3000U
#define GR740_IOPLL_DRVSTR1_S6_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S6_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S6(_val)
#define GR740_IOPLL_DRVSTR1_S5_SHIFT   10
#define GR740_IOPLL_DRVSTR1_S5_MASK   0xc00U
#define GR740_IOPLL_DRVSTR1_S5_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S5_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S5(_val)
#define GR740_IOPLL_DRVSTR1_S4_SHIFT   8
#define GR740_IOPLL_DRVSTR1_S4_MASK   0x300U
#define GR740_IOPLL_DRVSTR1_S4_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S4_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S4(_val)
#define GR740_IOPLL_DRVSTR1_S3_SHIFT   6
#define GR740_IOPLL_DRVSTR1_S3_MASK   0xc0U
#define GR740_IOPLL_DRVSTR1_S3_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S3_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S3(_val)
#define GR740_IOPLL_DRVSTR1_S2_SHIFT   4
#define GR740_IOPLL_DRVSTR1_S2_MASK   0x30U
#define GR740_IOPLL_DRVSTR1_S2_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S2_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S2(_val)
#define GR740_IOPLL_DRVSTR1_S1_SHIFT   2
#define GR740_IOPLL_DRVSTR1_S1_MASK   0xcU
#define GR740_IOPLL_DRVSTR1_S1_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S1_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S1(_val)
#define GR740_IOPLL_DRVSTR1_S0_SHIFT   0
#define GR740_IOPLL_DRVSTR1_S0_MASK   0x3U
#define GR740_IOPLL_DRVSTR1_S0_GET(_reg)
#define GR740_IOPLL_DRVSTR1_S0_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR1_S0(_val)
#define GR740_IOPLL_DRVSTR2_S19_SHIFT   18
#define GR740_IOPLL_DRVSTR2_S19_MASK   0xc0000U
#define GR740_IOPLL_DRVSTR2_S19_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S19_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S19(_val)
#define GR740_IOPLL_DRVSTR2_S18_SHIFT   16
#define GR740_IOPLL_DRVSTR2_S18_MASK   0x30000U
#define GR740_IOPLL_DRVSTR2_S18_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S18_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S18(_val)
#define GR740_IOPLL_DRVSTR2_S17_SHIFT   14
#define GR740_IOPLL_DRVSTR2_S17_MASK   0xc000U
#define GR740_IOPLL_DRVSTR2_S17_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S17_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S17(_val)
#define GR740_IOPLL_DRVSTR2_S16_SHIFT   12
#define GR740_IOPLL_DRVSTR2_S16_MASK   0x3000U
#define GR740_IOPLL_DRVSTR2_S16_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S16_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S16(_val)
#define GR740_IOPLL_DRVSTR2_S15_SHIFT   10
#define GR740_IOPLL_DRVSTR2_S15_MASK   0xc00U
#define GR740_IOPLL_DRVSTR2_S15_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S15_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S15(_val)
#define GR740_IOPLL_DRVSTR2_S14_SHIFT   8
#define GR740_IOPLL_DRVSTR2_S14_MASK   0x300U
#define GR740_IOPLL_DRVSTR2_S14_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S14_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S14(_val)
#define GR740_IOPLL_DRVSTR2_S13_SHIFT   6
#define GR740_IOPLL_DRVSTR2_S13_MASK   0xc0U
#define GR740_IOPLL_DRVSTR2_S13_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S13_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S13(_val)
#define GR740_IOPLL_DRVSTR2_S12_SHIFT   4
#define GR740_IOPLL_DRVSTR2_S12_MASK   0x30U
#define GR740_IOPLL_DRVSTR2_S12_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S12_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S12(_val)
#define GR740_IOPLL_DRVSTR2_S11_SHIFT   2
#define GR740_IOPLL_DRVSTR2_S11_MASK   0xcU
#define GR740_IOPLL_DRVSTR2_S11_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S11_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S11(_val)
#define GR740_IOPLL_DRVSTR2_S10_SHIFT   0
#define GR740_IOPLL_DRVSTR2_S10_MASK   0x3U
#define GR740_IOPLL_DRVSTR2_S10_GET(_reg)
#define GR740_IOPLL_DRVSTR2_S10_SET(_reg, _val)
#define GR740_IOPLL_DRVSTR2_S10(_val)
#define GR740_IOPLL_LOCKDOWN_PERMANENT_SHIFT   16
#define GR740_IOPLL_LOCKDOWN_PERMANENT_MASK   0xff0000U
#define GR740_IOPLL_LOCKDOWN_PERMANENT_GET(_reg)
#define GR740_IOPLL_LOCKDOWN_PERMANENT_SET(_reg, _val)
#define GR740_IOPLL_LOCKDOWN_PERMANENT(_val)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_SHIFT   0
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_MASK   0xffU
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_GET(_reg)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE_SET(_reg, _val)
#define GR740_IOPLL_LOCKDOWN_REVOCABLE(_val)
typedef struct gr740_iopll gr740_iopll
