RTEMS 6.1-rc2
Macros | Typedefs | Functions | Variables
error.h File Reference
RTEMS Error Reporting. More...
#include <rtems/fatal.h>
#include <stdarg.h>
#define RTEMS_ERROR_ERRNO   (0x40000000) /* hi bit; use 'errno' */
#define RTEMS_ERROR_PANIC   (0x20000000) /* err fatal; no return */
#define RTEMS_ERROR_ABORT   (0x10000000) /* err is fatal; panic */
#define RTEMS_ERROR_MASK    (RTEMS_ERROR_ERRNO | RTEMS_ERROR_ABORT | RTEMS_ERROR_PANIC) /* all */
typedef Internal_errors_t rtems_error_code_t
int rtems_error (rtems_error_code_t error_code, const char *printf_format,...)
 Report an Error.
int rtems_verror (rtems_error_code_t error_code, const char *printf_format, va_list arglist)
 Report an Error.
int rtems_panic_in_progress
Defines and externs for rtems error reporting
These routines provide general purpose error reporting. rtems_error reports an error to stderr and allows use of printf style formatting. A newline is appended to all messages.
error_flag can be specified as any of the following:
RTEMS_ERROR_ERRNO – include errno text in output RTEMS_ERROR_PANIC – halts local system after output RTEMS_ERROR_ABORT – abort after output
It can also include a rtems_status value which can be OR'd with the above flags. *
Example 1:
#include <rtems/error.h>
rtems_error(0, "stray interrupt %d", intr);
int rtems_error(rtems_error_code_t error_code, const char *printf_format,...)
Report an Error.
Definition: error.c:103
Example 2:
if ((status = rtems_task_create(...)) != RTEMS_SUCCCESSFUL)
rtems_error(status | RTEMS_ERROR_ABORT,
"could not create task");
rtems_status_code rtems_task_create(rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
Creates a task.
Definition: taskcreate.c:66
Example 3:
if ((fd = open(pathname, O_RDNLY)) < 0)
rtems_error(RTEMS_ERROR_ERRNO, "open of '%s' failed", pathname);
goto failed;
int open(const char *path, int oflag,...)
Definition: open.c:171
◆ rtems_error()
int rtems_error ( rtems_error_code_t  error_code,
const char *  printf_format,
Report an Error.
Parameters
[in]error_codecan be specified as any of the following: RTEMS_ERROR_ERRNO – include errno text in output RTEMS_ERROR_PANIC – halts local system after output RTEMS_ERROR_ABORT – abort after output
[in]printf_formatis a normal printf(3) format string, with its concommitant arguments
Returns
the number of characters written.
◆ rtems_verror()
int rtems_verror ( rtems_error_code_t  error_code,
va_list  arglist
Report an Error.
Parameters
[in]arglistis a varargs list corresponding to printf_format
Returns
