RTEMS 6.1-rc2
errata_SSWF021_45.h File Reference
This header file provides errata SSWF021#45 interfaces. More...
#include <stdint.h>
uint32_t _errata_SSWF021_45_both_plls (uint32_t count)
 This handles the errata for PLL1 and PLL2. This function is called in device startup.
uint32_t _errata_SSWF021_45_pll1 (uint32_t count)
 This handles the errata for PLL1. This function is called in device startup.
uint32_t _errata_SSWF021_45_pll2 (uint32_t count)
 This handles the errata for PLL2. This function is called in device startup.
Pulled in from Halcogen v4.7.1. This is a rare but high-severity errata that should always be checked for at system start.
◆ _errata_SSWF021_45_both_plls()
uint32_t _errata_SSWF021_45_both_plls ( uint32_t  count)
Parameters
[in]count: Number of retries until both PLLs are locked successfully Minimum value recommended is 5
Returns
0 = Success (the PLL or both PLLs have successfully locked and then been disabled) 1 = PLL1 failed to successfully lock in "count" tries 2 = PLL2 failed to successfully lock in "count" tries 3 = Neither PLL1 nor PLL2 successfully locked in "count" tries 4 = The workaround function was not able to disable at least one of the PLLs. The most likely reason is that a PLL is already being used as a clock source. This can be caused by the workaround function being called from the wrong place in the code.
◆ _errata_SSWF021_45_pll1()
uint32_t _errata_SSWF021_45_pll1 ( uint32_t  count)
Parameters
[in]count: Number of retries until both PLL1 is locked successfully Minimum value recommended is 5
Returns
◆ _errata_SSWF021_45_pll2()
uint32_t _errata_SSWF021_45_pll2 ( uint32_t  count)
Parameters
[in]count: Number of retries until PLL2 is locked successfully Minimum value recommended is 5
Returns
