RTEMS 6.1-rc2
start Directory Reference
file  bspidle.c
 Idle task.
file  bspreset-armv4.c
 Reset code.
file  bspstart.c
 Startup code.
file  bspstarthooks.c
 Startup code.
file  dma-copy.c
 Direct memory access (DMA) support.
file  dma.c
file  io.c
 Input and output module.
file  restart.c
 Restart implementation.
file  start-config-emc-dynamic.c
 BSP start EMC dynamic memory configuration.
file  start-config-emc-static.c
 BSP start EMC static memory configuration.
file  start-config-mpu.c
 BSP start MPU configuration.
file  start-config-pinsel.c
 BSP start pin selection configuration.
file  system-clocks.c
 System clocks.
file  timer.c
 Benchmark timer support.
