RTEMS 6.1-rc2
comloc.h
1
7/* comloc.h
8 *
9 * Milkymist USB input devices driver for RTEMS
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 *
15 * COPYRIGHT (c) 2010 Sebastien Bourdeauducq
16 */
17
18#ifndef __COMLOC_H_
19#define __COMLOC_H_
20
21#define COMLOCV(x) (*(volatile unsigned char *)(x))
22
23#define COMLOC_DEBUG_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000)
24#define COMLOC_DEBUG(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset)
25#define COMLOC_MEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101)
26#define COMLOC_MEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset)
27#define COMLOC_KEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142)
28#define COMLOC_KEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset)
29#define COMLOC_MIDI_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183)
30#define COMLOC_MIDI(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset)
31
32#endif /* __COMLOC_H_ */
