RTEMS 6.1-rc2
Milkymist USB input devices driver. More...
#define COMLOCV(x)   (*(volatile unsigned char *)(x))
#define COMLOC_DEBUG_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000)
#define COMLOC_DEBUG(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset)
#define COMLOC_MEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101)
#define COMLOC_MEVT(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset)
#define COMLOC_KEVT_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142)
#define COMLOC_KEVT(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset)
#define COMLOC_MIDI_PRODUCE   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183)
#define COMLOC_MIDI(offset)   COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset)
