RTEMS 6.1-rc2
Typedefs | Functions
btimer.h File Reference
RTEMS Benchmark Timer API for all Boards. More...
#include <stdbool.h>
#include <stdint.h>
typedef uint32_t benchmark_timer_t
 This type is used to return a Benchmark Timer value.
void benchmark_timer_initialize (void)
 Initialize the Benchmark Timer.
benchmark_timer_t benchmark_timer_read (void)
 Read the Benchmark Timer.
rtems_status_code benchmark_timer_empty_function (void)
 Benchmark Timer Empty Function.
void benchmark_timer_disable_subtracting_average_overhead (bool find_flag)
 Disable Average Overhead Removal from the Benchmark Timer.
Typedef Documentation
◆ benchmark_timer_t
This type is used to contain benchmark times. The units are BSP specific.
◆ benchmark_timer_disable_subtracting_average_overhead()
void benchmark_timer_disable_subtracting_average_overhead ( bool  find_flag)
This method places the benchmark timer in a "raw" mode where it returns the actual number of units which have passed between calls to benchmark_timer_initialize and benchmark_timer_read counting.
Parameters
[in]find_flagindicates to enable or disable the mode
◆ benchmark_timer_empty_function()
rtems_status_code benchmark_timer_empty_function ( void  )
This method is used to determine loop overhead.
◆ benchmark_timer_initialize()
void benchmark_timer_initialize ( void  )
This method initializes the benchmark timer and resets it to begin counting.
◆ benchmark_timer_read()
benchmark_timer_t benchmark_timer_read ( void  )
This method stops the benchmark timer and returns the number of units that have passed since benchmark_timer_initialize was invoked.
Returns
This method returns the number of units with the average overhead removed. If the value is below the minimum trusted value, zero is returned.
