RTEMS 6.1-rc2
BeagleBone Black PWM support definitions. More...
#define | BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4)) |
BeagleBone Black PWM Macros. | |
#define | BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4)) |
#define | BBB_P8_13_MUX_PWM 4 |
#define | BBB_P8_19_MUX_PWM 4 |
#define | BBB_P8_45_MUX_PWM 3 |
#define | BBB_P8_46_MUX_PWM 3 |
#define | BBB_P8_34_MUX_PWM 2 |
#define | BBB_P8_36_MUX_PWM 2 |
#define | BBB_P9_14_MUX_PWM 6 |
#define | BBB_P9_16_MUX_PWM 6 |
#define | BBB_P9_21_MUX_PWM 3 |
#define | BBB_P9_22_MUX_PWM 3 |
#define | BBB_P9_29_MUX_PWM 1 |
#define | BBB_P9_31_MUX_PWM 1 |
#define | BBB_PWM_FREQ_THRESHOLD 0.5f |
bool | beagle_pwm_init (BBB_PWMSS pwmss_id) |
BeagleBone Black PWM API. | |
int | beagle_pwm_configure (BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b) |
bool | beagle_pwm_enable (BBB_PWMSS pwmid) |
This API enables the particular PWM module. | |
bool | beagle_pwm_disable (BBB_PWMSS pwmid) |
This API disables the particular PWM module. | |
bool | beagle_pwm_pinmux_setup (bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id) |
This function enables pinmuxing for PWM module. | |
bool | beagle_pwmss_is_running (unsigned int pwmss_id) |
This function determines whether PWMSS-wide clocks enabled or not. | |
#define BBB_CONTROL_CONF_GPMC_AD | ( | n | ) | (0x800 + (n * 4)) |
Some constants are taken from https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.h
bool beagle_pwm_disable | ( | BBB_PWMSS | pwmid | ) |
pwmid | It is the instance number of EPWM of pwm sub system. |
bool beagle_pwm_enable | ( | BBB_PWMSS | pwmid | ) |
bool beagle_pwm_init | ( | BBB_PWMSS | pwmss_id | ) |
This function intilizes clock for pwm sub system.
PWMSS_ID | It is the instance number of EPWM of pwm sub system. |
bool beagle_pwm_pinmux_setup | ( | bbb_pwm_pin_t | pin_no, |
BBB_PWMSS | pwm_id | ||
pin_no | It is individual pin at which freuqency need to be generated. It should be according to pwm sub system. |
pwm_id | It is the instance number of EPWM of pwmsubsystem. |
bool beagle_pwmss_is_running | ( | unsigned int | pwmss_id | ) |
pwmss_id | It is the instance number of PWMSS which clocks need to be checked. |
