RTEMS 6.1-rc2
Support for the I2C bus on the Raspberry Pi GPIO P1 header (model A/B) and GPIO J8 header on model B+. More...
#include <bsp.h>
#include <bsp/raspberrypi.h>
#include <bsp/gpio.h>
#include <bsp/rpi-gpio.h>
#include <bsp/irq.h>
#include <bsp/i2c.h>
#include <assert.h>
struct | rpi_i2c_bus |
Object containing relevant information about an I2C bus. More... | |
#define | TRANSFER_COUNT(buffer_size) (buffer_size + 0xFFFE) / 0xFFFF |
#define | ADJUST_TRANSFER_SIZE(transfer_count, remaining_bytes) transfer_count > 1 ? 0xFFFF : (remaining_bytes & 0xFFFF) |
#define | I2C_POLLING(condition) |
int | rpi_i2c_register_bus (const char *bus_path, uint32_t bus_clock) |
Registers the Raspberry Pi BSC I2C bus with the Linux I2C User-Space API. | |
void | rpi_i2c_init (void) |
Setups the Raspberry Pi GPIO header to activate the BSC I2C bus. | |
#define I2C_POLLING | ( | condition | ) |
int rpi_i2c_register_bus | ( | const char * | bus_path, |
uint32_t | bus_clock | ||
[in] | bus_path | Path to the bus device file. |
[in] | bus_clock | Bus clock in Hz. |
0 | Bus registered successfully. |
<0 | Could not register the bus. The return value is a negative errno code. |
