RTEMS 6.1-rc2
arm-generic-timer-aarch64.c File Reference
AArch64-specific ARM GPT system register accessors. More...
#include <dev/clock/arm-generic-timer.h>
#include <bsp/irq.h>
uint64_t arm_gt_clock_get_compare_value (void)
void arm_gt_clock_set_compare_value (uint64_t cval)
uint64_t arm_gt_clock_get_count (void)
void arm_gt_clock_set_control (uint32_t ctl)
void arm_generic_timer_get_config (uint32_t *frequency, uint32_t *irq)
◆ arm_generic_timer_get_config()
void arm_generic_timer_get_config ( uint32_t *  frequency,
uint32_t *  irq
This function gets the frequency and IRQ number used by the ARM General Purpose Timer.
Parameters
[out]frequencyThe frequency at which the timer will fire.
[out]irqThe number of the IRQ on which the timer will fire.
◆ arm_gt_clock_get_compare_value()
uint64_t arm_gt_clock_get_compare_value ( void  )
This function returns the current compare value for the ARM General Purpose Timer.
Returns
The current compare value.
◆ arm_gt_clock_get_count()
uint64_t arm_gt_clock_get_count ( void  )
This function returns the count for the ARM General Purpose Timer.
Returns
The current count.
◆ arm_gt_clock_set_compare_value()
void arm_gt_clock_set_compare_value ( uint64_t  cval)
This function sets the current compare value for the ARM General Purpose Timer.
Parameters
[in]cvalThe value to set as the compare value
◆ arm_gt_clock_set_control()
void arm_gt_clock_set_control ( uint32_t  ctl)
This function sets the control register for the ARM General Purpose Timer.
Parameters
[in]ctlThe value to set to the control register
