RTEMS 6.1-rc1
Macros | Enumerations | Functions
watchdogimpl.h File Reference
This header file provides interfaces of the Watchdog Handler which are only used by the implementation. More...
#include <rtems/score/watchdogticks.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/rbtreeimpl.h>
#include <sys/types.h>
#include <sys/timespec.h>
#define WATCHDOG_INITIALIZER(routine)
 Watchdog initializer for static initialization. More...
#define _Watchdog_Tickle(header, first, now, lock, lock_context)    _Watchdog_Do_tickle( header, first, now, lock_context )
#define WATCHDOG_MAXIMUM_TICKS   UINT64_MAX
 The maximum watchdog ticks value for the far future.
#define WATCHDOG_NANOSECONDS_PER_SECOND   1000000000
#define WATCHDOG_BITS_FOR_1E9_NANOSECONDS   30
 The bits necessary to store 1000000000 (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds. More...
#define WATCHDOG_MAX_SECONDS   0x3ffffffff
 The maximum number of seconds representable in the nanoseconds watchdog format. More...
enum  Watchdog_State { WATCHDOG_SCHEDULED_BLACK , WATCHDOG_SCHEDULED_RED , WATCHDOG_INACTIVE , WATCHDOG_PENDING }
 Watchdog states. More...
void _Watchdog_Tick (struct Per_CPU_Control *cpu)
 Performs a watchdog tick. More...
void _Watchdog_Do_tickle (Watchdog_Header *header, Watchdog_Control *first, uint64_t now, ISR_lock_Context *lock_context)
 Calls the routine of each not expired watchdog control node. More...
void _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog, uint64_t expire)
 Inserts a watchdog into the set of scheduled watchdogs according to the specified expiration time. More...
void _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 In the case the watchdog is scheduled, then it is removed from the set of scheduled watchdogs. More...
