RTEMS 6.1-rc1
vmeUniverse.h
1
9#ifndef VME_UNIVERSE_UTIL_H
10#define VME_UNIVERSE_UTIL_H
11
12/*
13 * Authorship
14 * ----------
15 * This software was created by
16 * Till Straumann <strauman@slac.stanford.edu>, 2000-2007,
17 * Stanford Linear Accelerator Center, Stanford University.
18 *
19 * Acknowledgement of sponsorship
20 * ------------------------------
21 * This software was produced by
22 * the Stanford Linear Accelerator Center, Stanford University,
23 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
24 *
25 * Government disclaimer of liability
26 * ----------------------------------
27 * Neither the United States nor the United States Department of Energy,
28 * nor any of their employees, makes any warranty, express or implied, or
29 * assumes any legal liability or responsibility for the accuracy,
30 * completeness, or usefulness of any data, apparatus, product, or process
31 * disclosed, or represents that its use would not infringe privately owned
32 * rights.
33 *
34 * Stanford disclaimer of liability
35 * --------------------------------
36 * Stanford University makes no representations or warranties, express or
37 * implied, nor assumes any liability for the use of this software.
38 *
39 * Stanford disclaimer of copyright
40 * --------------------------------
41 * Stanford University, owner of the copyright, hereby disclaims its
42 * copyright and all other rights in this software. Hence, anyone may
43 * freely use it for any purpose without restriction.
44 *
45 * Maintenance of notices
46 * ----------------------
47 * In the interest of clarity regarding the origin and status of this
48 * SLAC software, this and all the preceding Stanford University notices
49 * are to remain affixed to any copy or derivative of this software made
50 * or distributed by the recipient and are to be affixed to any copy of
51 * software made or distributed by the recipient that contains a copy or
52 * derivative of this software.
53 *
54 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
55 */
56
65#ifdef __vxworks
66#include <vme.h>
67#else
68
69#include <bsp/vme_am_defs.h>
70
71#endif
72
73/* These bits can be or'ed with the address-modifier when calling
74 * the 'XlateAddr' routine below to further qualify the
75 * search criteria.
76 */
77#define VME_MODE_MATCH_MASK (3<<30)
78#define VME_MODE_EXACT_MATCH (2<<30) /* all bits must match */
79#define VME_MODE_AS_MATCH (1<<30) /* only A16/24/32 must match */
80
81
82typedef unsigned long LERegister; /* emphasize contents are little endian */
83
84/****** NOTE: USE OF VmeUniverseDMAPacket IS DEPRECATED *********
85 ****** USE API IN VMEDMA.h INSTEAD *********/
86
87/* NOTE: DMA packet descriptors MUST be 32 byte aligned */
89 LERegister dctl __attribute__((aligned(32)));
90 LERegister dtbc __attribute__((packed));
91 LERegister dla __attribute__((packed));
92 LERegister dummy1 __attribute__((packed));
93 LERegister dva __attribute__((packed));
94 LERegister dummy2 __attribute__((packed));
95 LERegister dcpp __attribute__((packed));
96 LERegister dummy3 __attribute__((packed));
98
99/* PCI CSR register */
100#define UNIV_REGOFF_PCI_CSR 0x4
101# define UNIV_PCI_CSR_D_PE (1<<31) /* detected parity error; write 1 to clear */
102# define UNIV_PCI_CSR_S_SERR (1<<30) /* SERR (signalled error) asserted; write 1 to clear */
103# define UNIV_PCI_CSR_R_MA (1<<29) /* received master abort; write 1 to clear */
104# define UNIV_PCI_CSR_R_TA (1<<28) /* received target abort; write 1 to clear */
105# define UNIV_PCI_CSR_S_TA (1<<27) /* signalled target abort; write 1 to clear */
106# define UNIV_PCI_CSR_DEVSEL_MASK (3<<25) /* device select timing (RO) */
107# define UNIV_PCI_CSR_DP_D (1<<24) /* data parity error detected; write 1 to clear */
108# define UNIV_PCI_CSR_TFBBC (1<<23) /* target fast back to back capable (RO) */
109# define UNIV_PCI_CSR_MFBBC (1<<9) /* master fast back to back capable (RO) */
110# define UNIV_PCI_CSR_SERR_EN (1<<8) /* enable SERR driver */
111# define UNIV_PCI_CSR_WAIT (1<<7) /* wait cycle control (RO) */
112# define UNIV_PCI_CSR_PERESP (1<<6) /* parity error response enable */
113# define UNIV_PCI_CSR_VGAPS (1<<5) /* VGA palette snoop (RO) */
114# define UNIV_PCI_CSR_MWI_EN (1<<4) /* Memory write and invalidate enable (RO) */
115# define UNIV_PCI_CSR_SC (1<<3) /* special cycles (RO) */
116# define UNIV_PCI_CSR_BM (1<<2) /* master enable (MUST SET TO ENABLE VME SLAVES) */
117# define UNIV_PCI_CSR_MS (1<<1) /* target memory enable */
118# define UNIV_PCI_CSR_IOS (1<<0) /* target IO enable */
119
120/* Special cycle (ADOH, RMW) control register */
121#define UNIV_REGOFF_SCYC_CTL 0x170 /* write 0 to disable */
122# define UNIV_SCYC_CTL_LAS_IO (1<<2) /* PCI address space (1: IO, 0: mem) */
123# define UNIV_SCYC_CTL_SCYC_RMW (1<<0) /* do a RMW cycle when reading PCI address */
124# define UNIV_SCYC_CTL_SCYC_ADOH (2<<0) /* do a ADOH cycle when reading/writing PCI address */
125
126/* Special cycle address register */
127#define UNIV_REGOFF_SCYC_ADDR 0x174 /* PCI address (must be long word aligned) */
128
129/* Special cycle Swap/Compare/Enable */
130#define UNIV_REGOFF_SCYC_EN 0x178 /* mask determining the bits involved in the compare and swap operations for VME RMW cycles */
131
132/* Special cycle compare data register */
133#define UNIV_REGOFF_SCYC_CMP 0x17c /* data to compare with word returned from VME RMW read */
134
135/* Special cycle swap data register */
136#define UNIV_REGOFF_SCYC_SWP 0x180 /* If enabled bits of CMP match, corresponding SWP bits are written back to VME (under control of EN) */
137
138/* PCI miscellaneous register */
139#define UNIV_REGOFF_LMISC 0x184
140# define UNIV_LMISC_CRT_MASK (7<<28) /* Univ. I only, not used on II */
141# define UNIV_LMISC_CRT_INF (0<<28) /* Coupled Request Timeout */
142# define UNIV_LMISC_CRT_128_US (1<<28) /* Coupled Request Timeout */
143# define UNIV_LMISC_CRT_256_US (2<<28) /* Coupled Request Timeout */
144# define UNIV_LMISC_CRT_512_US (3<<28) /* Coupled Request Timeout */
145# define UNIV_LMISC_CRT_1024_US (4<<28) /* Coupled Request Timeout */
146# define UNIV_LMISC_CRT_2048_US (5<<28) /* Coupled Request Timeout */
147# define UNIV_LMISC_CRT_4096_US (6<<28) /* Coupled Request Timeout */
148
149# define UNIV_LMISC_CWT_MASK (7<<24) /* coupled window timer */
150# define UNIV_LMISC_CWT_DISABLE 0 /* disabled (release VME after 1 coupled xaction) */
151# define UNIV_LMISC_CWT_16 (1<<24) /* 16 PCI clock cycles */
152# define UNIV_LMISC_CWT_32 (2<<24) /* 32 PCI clock cycles */
153# define UNIV_LMISC_CWT_64 (3<<24) /* 64 PCI clock cycles */
154# define UNIV_LMISC_CWT_128 (4<<24) /* 128 PCI clock cycles */
155# define UNIV_LMISC_CWT_256 (5<<24) /* 256 PCI clock cycles */
156# define UNIV_LMISC_CWT_512 (6<<24) /* 512 PCI clock cycles */
157
158/* PCI Command Error Log Register */
159#define UNIV_REGOFF_L_CMDERR 0x18c
160# define UNIV_L_CMDERR_CMDERR(reg) (((reg)>>28)&0xf) /* extract PCI cmd error log */
161# define UNIV_L_CMDERR_M_ERR (1<<27) /* multiple errors have occurred */
162# define UNIV_L_CMDERR_L_STAT (1<<23) /* PCI error log status valid (write 1 to clear and enable logging) */
163
164/* PCI Address Error Log */
165#define UNIV_REGOFF_LAERR 0x190 /* PCI fault address (if L_CMDERR_L_STAT valid) */
166/* DMA Xfer Control Register */
167#define UNIV_REGOFF_DCTL 0x200
168# define UNIV_DCTL_L2V (1<<31) /* PCI->VME if set */
169# define UNIV_DCTL_VDW_MSK (3<<22) /* VME max. width mask 0x00c00000 */
170# define UNIV_DCTL_VDW_8 (0<<22) /* VME max. width 8 */
171# define UNIV_DCTL_VDW_16 (1<<22) /* VME max. width 16 */
172# define UNIV_DCTL_VDW_32 (2<<22) /* VME max. width 32 */
173# define UNIV_DCTL_VDW_64 (3<<22) /* VME max. width 64 */
174# define UNIV_DCTL_VAS_MSK (7<<16) /* VME AS mask 0x00070000 */
175# define UNIV_DCTL_VAS_A16 (0<<16) /* VME A16 */
176# define UNIV_DCTL_VAS_A24 (1<<16) /* VME A24 */
177# define UNIV_DCTL_VAS_A32 (2<<16) /* VME A32 */
178# define UNIV_DCTL_PGM_MSK (3<<14) /* VME PGM/DATA mask 0x0000c000 */
179# define UNIV_DCTL_PGM (1<<14) /* VME PGM(1)/DATA(0) */
180# define UNIV_DCTL_SUPER_MSK (3<<12) /* VME SUPER/USR mask 0x00003000 */
181# define UNIV_DCTL_SUPER (1<<12) /* VME SUPER(1)/USR(0) */
182# define UNIV_DCTL_NO_VINC (1<<9) /* VME no VME address increment [Universe IIa/b ONLY */
183# define UNIV_DCTL_VCT (1<<8) /* VME enable BLT */
184# define UNIV_DCTL_LD64EN (1<<7) /* PCI 64 enable */
185
186/* DMA Xfer byte count register (is updated by DMA) */
187#define UNIV_REGOFF_DTBC 0x204
188/* DMA Xfer local (PCI) address (direction is set in DCTL) */
189#define UNIV_REGOFF_DLA 0x208
190/* DMA Xfer VME address (direction is set in DCTL)
191 * NOTE: (*UNIV_DVA) & ~7 == (*UNIV_DLA) & ~7 MUST HOLD
192 */
193#define UNIV_REGOFF_DVA 0x210
194
195/* DMA Xfer VME command packet pointer
196 * NOTE: The address stored here MUST be 32-byte aligned
197 */
198#define UNIV_REGOFF_DCPP 0x218
199/* these bits are only used in linked lists */
200# define UNIV_DCPP_IMG_NULL (1<<0) /* last packet in list */
201# define UNIV_DCPP_IMG_PROCESSED (1<<1) /* packet processed */
202
203/* DMA Xfer General Control/Status register */
204#define UNIV_REGOFF_DGCS 0x220
205# define UNIV_DGCS_GO (1<<31) /* start xfer */
206# define UNIV_DGCS_STOP_REQ (1<<30) /* stop xfer (immediate abort) */
207# define UNIV_DGCS_HALT_REQ (1<<29) /* halt xfer (abort after current packet) */
208# define UNIV_DGCS_CHAIN (1<<27) /* enable linked list mode */
209# define UNIV_DGCS_VON_MSK (7<<20) /* VON mask */
210# define UNIV_DGCS_VON_DONE (0<<20) /* VON counter disabled (do until done) */
211# define UNIV_DGCS_VON_256 (1<<20) /* VON yield bus after 256 bytes */
212# define UNIV_DGCS_VON_512 (2<<20) /* VON yield bus after 512 bytes */
213# define UNIV_DGCS_VON_1024 (3<<20) /* VON yield bus after 1024 bytes */
214# define UNIV_DGCS_VON_2048 (4<<20) /* VON yield bus after 2048 bytes */
215# define UNIV_DGCS_VON_4096 (5<<20) /* VON yield bus after 4096 bytes */
216# define UNIV_DGCS_VON_8192 (6<<20) /* VON yield bus after 8192 bytes */
217# define UNIV_DGCS_VON_16384 (7<<20) /* VON yield bus after 16384 bytes */
218# define UNIV_DGCS_VOFF_MSK (15<<16) /* VOFF mask */
219# define UNIV_DGCS_VOFF_0_US (0<<16) /* re-request VME master after 0 us */
220# define UNIV_DGCS_VOFF_2_US (8<<16) /* re-request VME master after 2 us */
221# define UNIV_DGCS_VOFF_4_US (9<<16) /* re-request VME master after 4 us */
222# define UNIV_DGCS_VOFF_8_US (10<<16)/* re-request VME master after 8 us */
223# define UNIV_DGCS_VOFF_16_US (1<<16) /* re-request VME master after 16 us */
224# define UNIV_DGCS_VOFF_32_US (2<<16) /* re-request VME master after 32 us */
225# define UNIV_DGCS_VOFF_64_US (3<<16) /* re-request VME master after 64 us */
226# define UNIV_DGCS_VOFF_128_US (4<<16) /* re-request VME master after 128 us */
227# define UNIV_DGCS_VOFF_256_US (5<<16) /* re-request VME master after 256 us */
228# define UNIV_DGCS_VOFF_512_US (6<<16) /* re-request VME master after 512 us */
229# define UNIV_DGCS_VOFF_1024_US (7<<16) /* re-request VME master after 1024 us */
230/* Status Bits (write 1 to clear) */
231# define UNIV_DGCS_ACT (1<<15) /* DMA active */
232# define UNIV_DGCS_STOP (1<<14) /* DMA stopped */
233# define UNIV_DGCS_HALT (1<<13) /* DMA halted */
234# define UNIV_DGCS_DONE (1<<11) /* DMA done (OK) */
235# define UNIV_DGCS_LERR (1<<10) /* PCI bus error */
236# define UNIV_DGCS_VERR (1<<9) /* VME bus error */
237# define UNIV_DGCS_P_ERR (1<<8) /* programming protocol error (e.g. PCI master disabled) */
238# define UNIV_DGCS_STATUS_CLEAR\
239 (UNIV_DGCS_ACT|UNIV_DGCS_STOP|UNIV_DGCS_HALT|\
240 UNIV_DGCS_DONE|UNIV_DGCS_LERR|UNIV_DGCS_VERR|UNIV_DGCS_P_ERR)
241# define UNIV_DGCS_P_ERR (1<<8) /* programming protocol error (e.g. PCI master disabled) */
242/* Interrupt Mask Bits */
243# define UNIV_DGCS_INT_STOP (1<<6) /* interrupt when stopped */
244# define UNIV_DGCS_INT_HALT (1<<5) /* interrupt when halted */
245# define UNIV_DGCS_INT_DONE (1<<3) /* interrupt when done */
246# define UNIV_DGCS_INT_LERR (1<<2) /* interrupt on LERR */
247# define UNIV_DGCS_INT_VERR (1<<1) /* interrupt on VERR */
248# define UNIV_DGCS_INT_P_ERR (1<<0) /* interrupt on P_ERR */
249# define UNIV_DGCS_INT_MSK (0x0000006f) /* interrupt mask */
250
251/* DMA Linked List Update Enable Register */
252#define UNIV_REGOFF_D_LLUE 0x224
253# define UNIV_D_LLUE_UPDATE (1<<31)
254
255
256/* PCI (local) interrupt enable register */
257#define UNIV_REGOFF_LINT_EN 0x300
258# define UNIV_LINT_EN_LM3 (1<<23) /* location monitor 3 mask */
259# define UNIV_LINT_EN_LM2 (1<<22) /* location monitor 2 mask */
260# define UNIV_LINT_EN_LM1 (1<<21) /* location monitor 1 mask */
261# define UNIV_LINT_EN_LM0 (1<<20) /* location monitor 0 mask */
262# define UNIV_LINT_EN_MBOX3 (1<<19) /* mailbox 3 mask */
263# define UNIV_LINT_EN_MBOX2 (1<<18) /* mailbox 2 mask */
264# define UNIV_LINT_EN_MBOX1 (1<<17) /* mailbox 1 mask */
265# define UNIV_LINT_EN_MBOX0 (1<<16) /* mailbox 0 mask */
266# define UNIV_LINT_EN_ACFAIL (1<<15) /* ACFAIL irq mask */
267# define UNIV_LINT_EN_SYSFAIL (1<<14) /* SYSFAIL irq mask */
268# define UNIV_LINT_EN_SW_INT (1<<13) /* PCI (local) software irq */
269# define UNIV_LINT_EN_SW_IACK (1<<12) /* VME software IACK mask */
270# define UNIV_LINT_EN_VERR (1<<10) /* PCI VERR irq mask */
271# define UNIV_LINT_EN_LERR (1<<9) /* PCI LERR irq mask */
272# define UNIV_LINT_EN_DMA (1<<8) /* PCI DMA irq mask */
273# define UNIV_LINT_EN_VIRQ7 (1<<7) /* VIRQ7 mask (universe does IACK automatically) */
274# define UNIV_LINT_EN_VIRQ6 (1<<6) /* VIRQ6 mask */
275# define UNIV_LINT_EN_VIRQ5 (1<<5) /* VIRQ5 mask */
276# define UNIV_LINT_EN_VIRQ4 (1<<4) /* VIRQ4 mask */
277# define UNIV_LINT_EN_VIRQ3 (1<<3) /* VIRQ3 mask */
278# define UNIV_LINT_EN_VIRQ2 (1<<2) /* VIRQ2 mask */
279# define UNIV_LINT_EN_VIRQ1 (1<<1) /* VIRQ1 mask */
280# define UNIV_LINT_EN_VOWN (1<<0) /* VOWN mask */
281
282/* PCI (local) interrupt status register */
283#define UNIV_REGOFF_LINT_STAT 0x304
284# define UNIV_LINT_STAT_LM3 (1<<23) /* location monitor 3 status */
285# define UNIV_LINT_STAT_LM2 (1<<22) /* location monitor 2 status */
286# define UNIV_LINT_STAT_LM1 (1<<21) /* location monitor 1 status */
287# define UNIV_LINT_STAT_LM0 (1<<20) /* location monitor 0 status */
288# define UNIV_LINT_STAT_MBOX3 (1<<19) /* mailbox 3 status */
289# define UNIV_LINT_STAT_MBOX2 (1<<18) /* mailbox 2 status */
290# define UNIV_LINT_STAT_MBOX1 (1<<17) /* mailbox 1 status */
291# define UNIV_LINT_STAT_MBOX0 (1<<16) /* mailbox 0 status */
292# define UNIV_LINT_STAT_ACFAIL (1<<15) /* ACFAIL irq status */
293# define UNIV_LINT_STAT_SYSFAIL (1<<14) /* SYSFAIL irq status */
294# define UNIV_LINT_STAT_SW_INT (1<<13) /* PCI (local) software irq */
295# define UNIV_LINT_STAT_SW_IACK (1<<12) /* VME software IACK status */
296# define UNIV_LINT_STAT_VERR (1<<10) /* PCI VERR irq status */
297# define UNIV_LINT_STAT_LERR (1<<9) /* PCI LERR irq status */
298# define UNIV_LINT_STAT_DMA (1<<8) /* PCI DMA irq status */
299# define UNIV_LINT_STAT_VIRQ7 (1<<7) /* VIRQ7 status */
300# define UNIV_LINT_STAT_VIRQ6 (1<<6) /* VIRQ6 status */
301# define UNIV_LINT_STAT_VIRQ5 (1<<5) /* VIRQ5 status */
302# define UNIV_LINT_STAT_VIRQ4 (1<<4) /* VIRQ4 status */
303# define UNIV_LINT_STAT_VIRQ3 (1<<3) /* VIRQ3 status */
304# define UNIV_LINT_STAT_VIRQ2 (1<<2) /* VIRQ2 status */
305# define UNIV_LINT_STAT_VIRQ1 (1<<1) /* VIRQ1 status */
306# define UNIV_LINT_STAT_VOWN (1<<0) /* VOWN status */
307# define UNIV_LINT_STAT_CLR (0xfff7ff)/* Clear all status bits */
308
309/* PCI (local) interrupt map 0 register */
310#define UNIV_REGOFF_LINT_MAP0 0x308 /* mapping of VME IRQ sources to PCI irqs */
311# define UNIV_LINT_MAP0_VIRQ7(lint) (((lint)&0x7)<<(7*4))
312# define UNIV_LINT_MAP0_VIRQ6(lint) (((lint)&0x7)<<(6*4))
313# define UNIV_LINT_MAP0_VIRQ5(lint) (((lint)&0x7)<<(5*4))
314# define UNIV_LINT_MAP0_VIRQ4(lint) (((lint)&0x7)<<(4*4))
315# define UNIV_LINT_MAP0_VIRQ3(lint) (((lint)&0x7)<<(3*4))
316# define UNIV_LINT_MAP0_VIRQ2(lint) (((lint)&0x7)<<(2*4))
317# define UNIV_LINT_MAP0_VIRQ1(lint) (((lint)&0x7)<<(1*4))
318# define UNIV_LINT_MAP0_VOWN(lint) (((lint)&0x7)<<(0*4))
319
320#define UNIV_REGOFF_LINT_MAP1 0x30c /* mapping of internal / VME IRQ sources to PCI irqs */
321# define UNIV_LINT_MAP1_ACFAIL(lint) (((lint)&0x7)<<(7*4))
322# define UNIV_LINT_MAP1_SYSFAIL(lint) (((lint)&0x7)<<(6*4))
323# define UNIV_LINT_MAP1_SW_INT(lint) (((lint)&0x7)<<(5*4))
324# define UNIV_LINT_MAP1_SW_IACK(lint) (((lint)&0x7)<<(4*4))
325# define UNIV_LINT_MAP1_VERR(lint) (((lint)&0x7)<<(2*4))
326# define UNIV_LINT_MAP1_LERR(lint) (((lint)&0x7)<<(1*4))
327# define UNIV_LINT_MAP1_DMA(lint) (((lint)&0x7)<<(0*4))
328
329/* enabling of generation of VME bus IRQs, TODO */
330#define UNIV_REGOFF_VINT_EN 0x310
331# define UNIV_VINT_EN_DISABLE_ALL 0
332# define UNIV_VINT_EN_SWINT (1<<12)
333# define UNIV_VINT_EN_SWINT_LVL(l) (1<<(((l)&7)+24)) /* universe II only */
334
335
336/* status of generation of VME bus IRQs */
337#define UNIV_REGOFF_VINT_STAT 0x314
338# define UNIV_VINT_STAT_LINT(lint) (1<<((lint)&7))
339# define UNIV_VINT_STAT_LINT_MASK (0xff)
340# define UNIV_VINT_STAT_CLR (0xfe0f17ff)
341# define UNIV_VINT_STAT_SWINT(l) (1<<(((l)&7)+24))
342
343#define UNIV_REGOFF_VINT_MAP0 0x318 /* VME destination of PCI IRQ source, TODO */
344
345#define UNIV_REGOFF_VINT_MAP1 0x31c /* VME destination of PCI IRQ source, TODO */
346# define UNIV_VINT_MAP1_SWINT(level) (((level)&0x7)<<16)
347
348/* NOTE: The universe seems to always set LSB (which has a special purpose in
349 * the STATID register: enable raising a SW_INT on IACK) on the
350 * vector it puts out on the bus...
351 */
352#define UNIV_REGOFF_VINT_STATID 0x320 /* our status/id response to IACK, TODO */
353# define UNIV_VINT_STATID(id) ((id)<<24)
354
355#define UNIV_REGOFF_VIRQ1_STATID 0x324 /* status/id of VME IRQ level 1 */
356#define UNIV_REGOFF_VIRQ2_STATID 0x328 /* status/id of VME IRQ level 2 */
357#define UNIV_REGOFF_VIRQ3_STATID 0x32c /* status/id of VME IRQ level 3 */
358#define UNIV_REGOFF_VIRQ4_STATID 0x330 /* status/id of VME IRQ level 4 */
359#define UNIV_REGOFF_VIRQ5_STATID 0x334 /* status/id of VME IRQ level 5 */
360#define UNIV_REGOFF_VIRQ6_STATID 0x338 /* status/id of VME IRQ level 6 */
361#define UNIV_REGOFF_VIRQ7_STATID 0x33c /* status/id of VME IRQ level 7 */
362# define UNIV_VIRQ_ERR (1<<8) /* set if universe encountered a bus error when doing IACK */
363# define UNIV_VIRQ_STATID_MASK (0xff)
364
365#define UNIV_REGOFF_LINT_MAP2 0x340 /* mapping of internal sources to PCI irqs */
366# define UNIV_LINT_MAP2_LM3(lint) (((lint)&0x7)<<7*4) /* location monitor 3 */
367# define UNIV_LINT_MAP2_LM2(lint) (((lint)&0x7)<<6*4) /* location monitor 2 */
368# define UNIV_LINT_MAP2_LM1(lint) (((lint)&0x7)<<5*4) /* location monitor 1 */
369# define UNIV_LINT_MAP2_LM0(lint) (((lint)&0x7)<<4*4) /* location monitor 0 */
370# define UNIV_LINT_MAP2_MBOX3(lint) (((lint)&0x7)<<3*4) /* mailbox 3 */
371# define UNIV_LINT_MAP2_MBOX2(lint) (((lint)&0x7)<<2*4) /* mailbox 2 */
372# define UNIV_LINT_MAP2_MBOX1(lint) (((lint)&0x7)<<1*4) /* mailbox 1 */
373# define UNIV_LINT_MAP2_MBOX0(lint) (((lint)&0x7)<<0*4) /* mailbox 0 */
374
375#define UNIV_REGOFF_VINT_MAP2 0x344 /* mapping of internal sources to VME irqs */
376# define UNIV_VINT_MAP2_MBOX3(vint) (((vint)&0x7)<<3*4) /* mailbox 3 */
377# define UNIV_VINT_MAP2_MBOX2(vint) (((vint)&0x7)<<2*4) /* mailbox 2 */
378# define UNIV_VINT_MAP2_MBOX1(vint) (((vint)&0x7)<<1*4) /* mailbox 1 */
379# define UNIV_VINT_MAP2_MBOX0(vint) (((vint)&0x7)<<0*4) /* mailbox 0 */
380
381#define UNIV_REGOFF_MBOX0 0x348 /* mailbox 0 */
382#define UNIV_REGOFF_MBOX1 0x34c /* mailbox 1 */
383#define UNIV_REGOFF_MBOX2 0x350 /* mailbox 2 */
384#define UNIV_REGOFF_MBOX3 0x354 /* mailbox 3 */
385
386#define UNIV_REGOFF_SEMA0 0x358 /* semaphore 0 */
387#define UNIV_REGOFF_SEMA1 0x35c /* semaphore 0 */
388/* TODO define semaphore register bits */
389
390#define UNIV_REGOFF_MAST_CTL 0x400 /* master control register */
391# define UNIV_MAST_CTL_MAXRTRY(val) (((val)&0xf)<<7*4) /* max # of pci master retries */
392# define UNIV_MAST_CTL_PWON(val) (((val)&0xf)<<6*4) /* posted write xfer count */
393# define UNIV_MAST_CTL_VRL(val) (((val)&0x3)<<22) /* VME bus request level */
394# define UNIV_MAST_CTL_VRM (1<<21) /* bus request mode (demand = 0, fair = 1) */
395# define UNIV_MAST_CTL_VREL (1<<20) /* bus release mode (when done = 0, on request = 1) */
396# define UNIV_MAST_CTL_VOWN (1<<19) /* bus ownership (release = 0, acquire/hold = 1) */
397# define UNIV_MAST_CTL_VOWN_ACK (1<<18) /* bus ownership (not owned = 0, acquired/held = 1) */
398# define UNIV_MAST_CTL_PABS(val) (((val)&0x3)<<3*4) /* PCI aligned burst size (32,64,128 byte / 0x3 is reserved) */
399# define UNIV_MAST_CTL_BUS_NO(val) (((val)&0xff)<<0*4) /* PCI bus number */
400
401#define UNIV_REGOFF_MISC_CTL 0x404 /* misc control register */
402# define UNIV_MISC_CTL_VBTO(val) (((val)&0x7)<<7*4) /* VME bus timeout (0=disable, 16*2^(val-1) us) */
403# define UNIV_MISC_CTL_VARB (1<<26) /* VME bus arbitration mode (0=round robin, 1= priority) */
404# define UNIV_MISC_CTL_VARBTO(val) (((val)&0x3)<<6*4) /* arbitration time out: disable, 16us, 256us, reserved */
405# define UNIV_MISC_CTL_SW_LRST (1<<23) /* software PCI reset */
406# define UNIV_MISC_CTL_SW_SYSRST (1<<22) /* software VME reset */
407# define UNIV_MISC_CTL_BI (1<<20) /* BI mode */
408# define UNIV_MISC_CTL_ENGBI (1<<19) /* enable global BI mode initiator */
409# define UNIV_MISC_CTL_SYSCON (1<<17) /* (R/W) 1:universe is system controller */
410# define UNIV_MISC_CTL_V64AUTO (1<<16) /* (R/W) 1:initiate VME64 auto id slave participation */
411
412/* U2SPEC described in VGM manual */
413/* NOTE: the Joerger vtr10012_8 needs the timing to be tweaked!!!! READt27 must be _no_delay_
414 */
415#define UNIV_REGOFF_U2SPEC 0x4fc
416# define UNIV_U2SPEC_DTKFLTR (1<<12) /* DTAck filter: 0: slow, better filter; 1: fast, poorer filter */
417# define UNIV_U2SPEC_MASt11 (1<<10) /* Master parameter t11 (DS hi time during BLT and MBLTs) */
418# define UNIV_U2SPEC_READt27_DEFAULT (0<<8) /* VME master parameter t27: (latch data after DTAck + 25ns) */
419# define UNIV_U2SPEC_READt27_FAST (1<<8) /* VME master parameter t27: (latch data faster than 25ns) */
420# define UNIV_U2SPEC_READt27_NODELAY (2<<8) /* VME master parameter t27: (latch data without any delay) */
421# define UNIV_U2SPEC_POSt28_FAST (1<<2) /* VME slave parameter t28: (faster time of DS to DTAck for posted write) */
422# define UNIV_U2SPEC_PREt28_FAST (1<<0) /* VME slave parameter t28: (faster time of DS to DTAck for prefetch read) */
423
424/* Location Monitor control register */
425#define UNIV_REGOFF_LM_CTL 0xf64
426# define UNIV_LM_CTL_EN (1<<31) /* image enable */
427# define UNIV_LM_CTL_PGM (1<<23) /* program AM */
428# define UNIV_LM_CTL_DATA (1<<22) /* data AM */
429# define UNIV_LM_CTL_SUPER (1<<21) /* supervisor AM */
430# define UNIV_LM_CTL_USER (1<<20) /* user AM */
431# define UNIV_LM_CTL_VAS_A16 (0<<16) /* A16 */
432# define UNIV_LM_CTL_VAS_A24 (1<<16) /* A16 */
433# define UNIV_LM_CTL_VAS_A32 (2<<16) /* A16 */
434
435/* Location Monitor base address */
436#define UNIV_REGOFF_LM_BS 0xf68
437
438/* VMEbus register access image control register */
439#define UNIV_REGOFF_VRAI_CTL 0xf70
440# define UNIV_VRAI_CTL_EN (1<<31) /* image enable */
441# define UNIV_VRAI_CTL_PGM (1<<23) /* program AM */
442# define UNIV_VRAI_CTL_DATA (1<<22) /* data AM */
443# define UNIV_VRAI_CTL_SUPER (1<<21) /* supervisor AM */
444# define UNIV_VRAI_CTL_USER (1<<20) /* user AM */
445# define UNIV_VRAI_CTL_VAS_A16 (0<<16) /* A16 */
446# define UNIV_VRAI_CTL_VAS_A24 (1<<16) /* A14 */
447# define UNIV_VRAI_CTL_VAS_A32 (2<<16) /* A32 */
448# define UNIV_VRAI_CTL_VAS_MSK (3<<16)
449
450/* VMEbus register acces image base address register */
451#define UNIV_REGOFF_VRAI_BS 0xf74
452
453/* VMEbus CSR control register */
454#define UNIV_REGOFF_VCSR_CTL 0xf80
455# define UNIV_VCSR_CTL_EN (1<<31) /* image enable */
456# define UNIV_VCSR_CTL_LAS_PCI_MEM (0<<0) /* pci mem space */
457# define UNIV_VCSR_CTL_LAS_PCI_IO (1<<0) /* pci IO space */
458# define UNIV_VCSR_CTL_LAS_PCI_CFG (2<<0) /* pci config space */
459
460/* VMEbus CSR translation offset */
461#define UNIV_REGOFF_VCSR_TO 0xf84
462
463/* VMEbus AM code error log */
464#define UNIV_REGOFF_V_AMERR 0xf88
465# define UNIV_V_AMERR_AMERR(reg) (((reg)>>26)&0x3f) /* extract error log code */
466# define UNIV_V_AMERR_IACK (1<<25) /* VMEbus IACK signal */
467# define UNIV_V_AMERR_M_ERR (1<<24) /* multiple errors occurred */
468# define UNIV_V_AMERR_V_STAT (1<<23) /* log status valid (write 1 to clear) */
469
470/* VMEbus address error log */
471#define UNIV_REGOFF_VAERR 0xf8c /* address of fault address (if MERR_V_STAT valid) */
472
473/* VMEbus CSR bit clear register */
474#define UNIV_REGOFF_VCSR_CLR 0xff4
475# define UNIV_VCSR_CLR_RESET (1<<31) /* read/negate LRST (can only be written from VME bus */
476# define UNIV_VCSR_CLR_SYSFAIL (1<<30) /* read/negate SYSFAIL */
477# define UNIV_VCSR_CLR_FAIL (1<<29) /* read: board has failed */
478
479/* VMEbus CSR bit set register */
480#define UNIV_REGOFF_VCSR_SET (0xff8)
481# define UNIV_VCSR_SET_RESET (1<<31) /* read/assert LRST (can only be written from VME bus */
482# define UNIV_VCSR_SET_SYSFAIL (1<<30) /* read/assert SYSFAIL */
483# define UNIV_VCSR_SET_FAIL (1<<29) /* read: board has failed */
484
485/* VMEbus CSR base address register */
486#define UNIV_REGOFF_VCSR_BS 0xffc
487#define UNIV_VCSR_BS_MASK (0xf8000000)
488
489/* offset of universe registers in VME-CSR slot */
490#define UNIV_CSR_OFFSET 0x7f000
491
492#ifdef __cplusplus
493extern "C" {
494#endif
495
496/* base address and IRQ line of 1st universe bridge
497 * NOTE: vmeUniverseInit() must be called before
498 * these may be used.
499 */
500extern volatile LERegister *vmeUniverse0BaseAddr;
501extern int vmeUniverse0PciIrqLine;
502
503
504/* Initialize the driver */
505int
506vmeUniverseInit(void);
507
508/* setup the universe chip, i.e. disable most of its
509 * mappings, reset interrupts etc.
510 */
511void
512vmeUniverseReset(void);
513
514/* avoid pulling stdio.h into this header.
515 * Applications that want a declaration of the
516 * following routines should
517 * #include <stdio.h>
518 * #define _VME_UNIVERSE_DECLARE_SHOW_ROUTINES
519 * #include <vmeUniverse.h>
520 */
521/* print the current configuration of all master ports to
522 * f (stderr if NULL)
523 */
524void
525vmeUniverseMasterPortsShow(FILE *f);
526
527/* print the current configuration of all slave ports to
528 * f (stderr if NULL)
529 */
530void
531vmeUniverseSlavePortsShow(FILE *f);
532
533/* disable all master or slave ports, respectively */
534void
535vmeUniverseDisableAllMasters(void);
536
537void
538vmeUniverseDisableAllSlaves(void);
539
540/* configure a master port
541 *
542 * port: port number 0..3 (0..7 for a UniverseII)
543 *
544 * address_space: vxWorks compliant addressing mode identifier
545 * (see vme.h). The most important are:
546 * 0x0d - A32, Sup, Data
547 * 0x3d - A24, Sup, Data
548 * 0x2d - A16, Sup, Data
549 * additionally, the value 0 is accepted; it will
550 * disable this port.
551 * vme_address: address on the vme_bus of this port.
552 * local_address: address on the pci_bus of this port.
553 * length: size of this port.
554 *
555 * NOTE: the addresses and length parameters must be aligned on a
556 * 2^16 byte (0x10000) boundary, except for port 4 (only available
557 * on a UniverseII), where the alignment can be 4k (4096).
558 *
559 * RETURNS: 0 on success, -1 on failure. Error messages printed to stderr.
560 */
561
562int
563vmeUniverseMasterPortCfg(
564 unsigned long port,
565 unsigned long address_space,
566 unsigned long vme_address,
567 unsigned long local_address,
568 unsigned long length);
569
570/* translate an address through the bridge
571 *
572 * vmeUniverseXlateAddr(0,0,as,addr,&result)
573 * yields a VME a address that reflects
574 * a local memory location as seen from the VME bus through the universe
575 * VME slave.
576 *
577 * likewise does vmeUniverseXlateAddr(1,0,as,addr,&result)
578 * translate a VME bus addr (through the VME master) to the
579 * PCI side of the bridge.
580 *
581 * a valid address space modifier must be specified.
582 *
583 * The 'reverse' parameter may be used to find a reverse
584 * mapping, i.e. the pci address in a master window can be
585 * found if the respective vme address is known etc.
586 *
587 * RETURNS: translated address in *pbusAdrs / *plocalAdrs
588 *
589 * 0: success
590 * -1: address/modifier not found in any bridge port
591 * -2: invalid modifier
592 */
593int
594vmeUniverseXlateAddr(
595 int master, /* look in the master windows */
596 int reverse, /* reverse mapping; for masters: map local to VME */
597 unsigned long as, /* address space */
598 unsigned long addr, /* address to look up */
599 unsigned long *paOut/* where to put result */
600 );
601
602/* configure a VME slave (PCI master) port */
603int
604vmeUniverseSlavePortCfg(
605 unsigned long port,
606 unsigned long address_space,
607 unsigned long vme_address,
608 unsigned long local_address,
609 unsigned long length);
610
611/****** NOTE: USE OF vmeUniverseStartDMA IS DEPRECATED *********
612 ****** USE API IN VMEDMA.h/vmeUniverseDMA.h INSTEAD *********/
613
614/* start a (direct, not linked) DMA transfer
615 *
616 * NOTE: DCTL and DGCS must be set up
617 * prior to calling this routine
618 */
619int
620vmeUniverseStartDMA(
621 unsigned long local_addr,
622 unsigned long vme_addr,
623 unsigned long count); /* DEPRECATED */
624
625int
626vmeUniverseStartDMAXX(
627 volatile LERegister *ubase,
628 unsigned long local_addr,
629 unsigned long vme_addr,
630 unsigned long count); /* DEPRECATED */
631
632
633/* read a register in PCI memory space
634 * (offset being one of the declared constants)
635 */
636unsigned long
637vmeUniverseReadReg(unsigned long offset);
638
639/* write a register in PCI memory space */
640void
641vmeUniverseWriteReg(unsigned long value, unsigned long offset);
642
643/* convert an array of unsigned long values to LE (as needed
644 * when the universe reads e.g. DMA descriptors from PCI)
645 */
646void
647vmeUniverseCvtToLE(unsigned long *ptr, unsigned long num);
648
649/* reset the VME bus */
650void
651vmeUniverseResetBus(void);
652
653/* The ...XX routines take the universe base address as an additional
654 * argument - this allows for programming secondary devices.
655 */
656
657unsigned long
658vmeUniverseReadRegXX(volatile LERegister *ubase, unsigned long offset);
659
660void
661vmeUniverseWriteRegXX(volatile LERegister *ubase, unsigned long value, unsigned long offset);
662
663int
664vmeUniverseXlateAddrXX(
665 volatile LERegister *ubase,
666 int master,
667 int reverse,
668 unsigned long as,
669 unsigned long addr,
670 unsigned long *paOut
671 );
672
673int
674vmeUniverseMasterPortCfgXX(
675 volatile LERegister *ubase,
676 unsigned long port,
677 unsigned long address_space,
678 unsigned long vme_address,
679 unsigned long local_address,
680 unsigned long length);
681
682int
683vmeUniverseSlavePortCfgXX(
684 volatile LERegister *ubase,
685 unsigned long port,
686 unsigned long address_space,
687 unsigned long vme_address,
688 unsigned long local_address,
689 unsigned long length);
690
691void
692vmeUniverseDisableAllMastersXX(volatile LERegister *ubase);
693
694void
695vmeUniverseDisableAllSlavesXX(volatile LERegister *ubase);
696
697/* print the current configuration of all master ports to
698 * f (stderr if NULL)
699 */
700void
701vmeUniverseMasterPortsShowXX(
702 volatile LERegister *ubase,FILE *f);
703
704/* print the current configuration of all slave ports to
705 * f (stderr if NULL)
706 */
707void
708vmeUniverseSlavePortsShowXX(
709 volatile LERegister *ubase,FILE *f);
710
711/* Raise a VME Interrupt at 'level' and respond with 'vector' to a
712 * handler on the VME bus. (The handler could be a different board
713 * or the universe itself - [only works with universe II]).
714 *
715 * Note that you could install a interrupt handler at UNIV_VME_SW_IACK_INT_VEC
716 * to be notified of an IACK cycle having completed.
717 *
718 * This routine is mainly FOR TESTING.
719 *
720 * NOTES:
721 * - several registers are modified: the vector is written to VINT_STATID
722 * and (universe 1 chip only) the level is written to the SW_INT bits
723 * int VINT_MAP1
724 * - NO MUTUAL EXCLUSION PROTECTION (reads VINT_EN, modifies then writes back).
725 * If several users need access to VINT_EN and/or VINT_STATID (and VINT_MAP1
726 * on the universe 1) it is their responsibility to serialize access.
727 *
728 * Arguments:
729 * 'level': interrupt level, 1..7
730 * 'vector': vector number (0..254) that the universe puts on the bus in response to
731 * an IACK cycle. NOTE: the vector number *must be even* (hardware restriction
732 * of the universe -- it always clears the LSB when the interrupter is
733 * a software interrupt).
734 *
735 * RETURNS:
736 * 0: Success
737 * -1: Invalid argument (level not 1..7, vector odd or >= 256)
738 * -2: Interrupt 'level' already asserted (maybe nobody handles it).
739 * You can manually clear it be writing the respective bit in
740 * VINT_STAT. Make sure really nobody responds to avoid spurious
741 * interrupts (consult universe docs).
742 */
743
744int
745vmeUniverseIntRaiseXX(volatile LERegister *base, int level, unsigned vector);
746
747int
748vmeUniverseIntRaise(int level, unsigned vector);
749
750/* Map internal register block to VME.
751 *
752 * This routine is intended for BSP implementors. The registers can be
753 * made accessible from VME so that the interrupt handler can flush the
754 * bridge FIFO (see below). The preferred method is by accessing VME CSR,
755 * though, if these are mapped [and the BSP provides an outbound window].
756 * On the universe we can also disable posted writes in the 'ordinary'
757 * outbound windows.
758 *
759 * vme_base: VME address where the universe registers (4k) can be mapped.
760 * This VME address must fall into a range covered by
761 * any pre-configured outbound window.
762 * address_space: The desired VME address space.
763 * (all of SUP/USR/PGM/DATA are always accepted).
764 *
765 * See NOTES [vmeUniverseInstallIrqMgrAlt()] below for further information.
766 *
767 * RETURNS: 0 on success, nonzero on error. It is not possible (and results
768 * in a non-zero return code) to change the CRG VME address after
769 * initializing the interrupt manager as it uses the CRG.
770 */
771int
772vmeUniverseMapCRGXX(volatile LERegister *base, unsigned long vme_base, unsigned long address_space);
773
774int
775vmeUniverseMapCRG(unsigned long vme_base, unsigned long address_space);
776
777
778#ifdef __rtems__
779
780/* VME Interrupt Handler functionality */
781
782/* we dont use the current RTEMS/BSP interrupt API for the
783 * following reasons:
784 *
785 * - RTEMS/BSP API does not pass an argument to the ISR :-( :-(
786 * - no separate vector space for VME vectors. Some vectors would
787 * have to overlap with existing PCI/ISA vectors.
788 * - RTEMS/BSP API allocates a structure for every possible vector
789 * - the irq_on(), irq_off() functions add more bloat than helping.
790 * They are (currently) only used by the framework to disable
791 * interrupts at the device level before removing a handler
792 * and to enable interrupts after installing a handler.
793 * These operations may as well be done by the driver itself.
794 *
795 * Hence, we maintain our own (VME) handler table and hook our PCI
796 * handler into the standard RTEMS/BSP environment. Our handler then
797 * dispatches VME interrupts.
798 */
799
800typedef void (*VmeUniverseISR) (void *usrArg, unsigned long vector);
801
802/* use these special vectors to connect a handler to the
803 * universe specific interrupts (such as "DMA done",
804 * VOWN, error irqs etc.)
805 * NOTE: The wrapper clears all status LINT bits (except
806 * for regular VME irqs). Also note that it is the user's
807 * responsibility to enable the necessary interrupts in
808 * LINT_EN
809 *
810 * !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
811 * DO NOT CHANGE THE ORDER OF THESE VECTORS - THE DRIVER
812 * DEPENDS ON IT
813 * !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
814 *
815 */
816#define UNIV_VOWN_INT_VEC 256
817#define UNIV_DMA_INT_VEC 257
818#define UNIV_LERR_INT_VEC 258
819#define UNIV_VERR_INT_VEC 259
820/* 260 is reserved */
821#define UNIV_VME_SW_IACK_INT_VEC 261
822#define UNIV_PCI_SW_INT_VEC 262
823#define UNIV_SYSFAIL_INT_VEC 263
824#define UNIV_ACFAIL_INT_VEC 264
825#define UNIV_MBOX0_INT_VEC 265
826#define UNIV_MBOX1_INT_VEC 266
827#define UNIV_MBOX2_INT_VEC 267
828#define UNIV_MBOX3_INT_VEC 268
829#define UNIV_LM0_INT_VEC 269
830#define UNIV_LM1_INT_VEC 270
831#define UNIV_LM2_INT_VEC 271
832#define UNIV_LM3_INT_VEC 272
833
834#define UNIV_NUM_INT_VECS 273
835
836
837/* install a handler for a VME vector
838 * RETURNS 0 on success, nonzero on failure.
839 */
840int
841vmeUniverseInstallISR(unsigned long vector, VmeUniverseISR handler, void *usrArg);
842
843/* remove a handler for a VME vector. The vector and usrArg parameters
844 * must match the respective parameters used when installing the handler.
845 * RETURNS 0 on success, nonzero on failure.
846 */
847int
848vmeUniverseRemoveISR(unsigned long vector, VmeUniverseISR handler, void *usrArg);
849
850/* query for the currently installed ISR and usr parameter at a given vector
851 * RETURNS: ISR or 0 (vector too big or no ISR installed)
852 */
853VmeUniverseISR
854vmeUniverseISRGet(unsigned long vector, void **parg);
855
856/* utility routines to enable/disable a VME IRQ level.
857 *
858 * To enable/disable the internal interrupt sources (special vectors above)
859 * pass a vector argument > 255.
860 *
861 * RETURNS 0 on success, nonzero on failure
862 */
863int
864vmeUniverseIntEnable(unsigned int level);
865int
866vmeUniverseIntDisable(unsigned int level);
867
868/* Check if an interrupt level or internal source is enabled:
869 *
870 * 'level': VME level 1..7 or internal special vector > 255
871 *
872 * RETURNS: value > 0 if interrupt is currently enabled,
873 * zero if interrupt is currently disabled,
874 * -1 on error (invalid argument).
875 */
876int
877vmeUniverseIntIsEnabled(unsigned int level);
878
879
880/* Change the routing of IRQ 'level' to 'pin'.
881 * If the BSP connects more than one of the eight
882 * physical interrupt lines from the universe to
883 * the board's PIC then you may change the physical
884 * line a given 'level' is using. By default,
885 * all 7 VME levels use the first wire (pin==0) and
886 * all internal sources use the (optional) second
887 * wire (pin==1).
888 * This feature is useful if you want to make use of
889 * different hardware priorities of the PIC. Let's
890 * say you want to give IRQ level 7 the highest priority.
891 * You could then give 'pin 0' a higher priority (at the
892 * PIC) and 'pin 1' a lower priority and issue.
893 *
894 * for ( i=1; i<7; i++ ) vmeUniverseIntRoute(i, 1);
895 *
896 * PARAMETERS:
897 * 'level' : VME interrupt level '1..7' or one of
898 * the internal sources. Pass the internal
899 * source's vector number (>=256).
900 * 'pin' : a value of 0 routes the requested IRQ to
901 * the first line registered with the manager
902 * (vmeIrqUnivOut parameter), a value of 1
903 * routes it to the alternate wire
904 * (specialIrqUnivOut)
905 * RETURNS: 0 on success, nonzero on error (invalid arguments)
906 *
907 * NOTES: - DONT change the universe 'map' registers
908 * directly. The driver caches routing internally.
909 * - support for the 'specialIrqUnivOut' wire is
910 * board dependent. If the board only provides
911 * a single physical wire from the universe to
912 * the PIC then the feature might not be available.
913 */
914int
915vmeUniverseIntRoute(unsigned int level, unsigned int pin);
916
917/* Loopback test of the VME interrupt subsystem.
918 * - installs ISRs on 'vector' and on UNIV_VME_SW_IACK_INT_VEC
919 * - asserts VME interrupt 'level'
920 * - waits for both interrupts: 'ordinary' VME interrupt of 'level' and
921 * IACK completion interrupt ('special' vector UNIV_VME_SW_IACK_INT_VEC).
922 *
923 * NOTES:
924 * - make sure no other handler responds to 'level'.
925 * - make sure no ISR is installed on both vectors yet.
926 * - ISRs installed by this routine are removed after completion.
927 * - no concurrent access protection of all involved resources
928 * (levels, vectors and registers [see vmeUniverseIntRaise()])
929 * is implemented.
930 * - this routine is intended for TESTING (when implementing new BSPs etc.).
931 * - one RTEMS message queue is temporarily used (created/deleted).
932 * - the universe 1 always yields a zero vector (VIRQx_STATID) in response
933 * to a self-generated VME interrupt. As a workaround, the routine
934 * only accepts a zero vector when running on a universe 1.
935 *
936 * RETURNS:
937 * 0: Success.
938 * -1: Invalid arguments.
939 * 1: Test failed (outstanding interrupts).
940 * rtems_status_code: Failed RTEMS directive.
941 */
942int
943vmeUniverseIntLoopbackTst(int level, unsigned vector);
944
945
946/* the universe interrupt handler is capable of routing all sorts of
947 * (VME) interrupts to 8 different lines (some of) which may be hooked up
948 * in a (board specific) way to a PIC.
949 *
950 * This driver only supports at most two lines. By default, it routes the
951 * 7 VME interrupts to the main line and optionally, it routes the 'special'
952 * interrupts generated by the universe itself (DMA done, VOWN etc.)
953 * to a second line. If no second line is available, all IRQs are routed
954 * to the main line.
955 *
956 * The routing of interrupts to the two lines can be modified (using
957 * the vmeUniverseIntRoute() call - see above - i.e., to make use of
958 * different hardware priorities of the two pins.
959 *
960 * Because the driver has no way to figure out which lines are actually
961 * wired to the PIC, this information has to be provided when installing
962 * the manager.
963 *
964 * Hence the manager sets up routing VME interrupts to 1 or 2 universe
965 * OUTPUTS. However, it must also be told to which PIC INPUTS they
966 * are wired.
967 * Optionally, the first PIC input line can be read from PCI config space
968 * but the second must be passed to this routine. Note that the info read
969 * from PCI config space is wrong for many boards!
970 *
971 * PARAMETERS:
972 * vmeIrqUnivOut: to which output pin (of the universe) should the 7
973 * VME irq levels be routed.
974 * vmeIrqPicLine: specifies to which PIC input the 'main' output is
975 * wired. If passed a value < 0, the driver reads this
976 * information from PCI config space ("IRQ line").
977 * specialIrqUnivOut: to which output pin (of the universe) should the
978 * internally irqs be routed. Use 'vmeIRQunivOut'
979 * if < 0.
980 * specialIrqPicLine: specifies to which PIC input the 'special' output
981 * pin is wired. The wiring of the 'vmeIRQunivOut' to
982 * the PIC is determined by reading PCI config space.
983 *
984 * RETURNS: 0 on success, -1 on failure.
985 *
986 */
987
988/* This routine is outside of the __INSIDE_RTEMS_BSP__ test for bwrds compatibility ONLY */
989int
990vmeUniverseInstallIrqMgr(int vmeIrqUnivOut,
991 int vmeIrqPicLine,
992 int specialIrqUnivOut,
993 int specialIrqPicLine);
994
995
996#if defined(__INSIDE_RTEMS_BSP__)
997#include <stdarg.h>
998
999/* up to 4 universe outputs are now supported by this alternate
1000 * entry point.
1001 * Terminate the vararg list (uni_pin/pic_pin pairs) with a
1002 * '-1' uni_pin.
1003 * E.g., the old interface is now just a wrapper to
1004 * vmeUniverseInstallIrqMgrAlt(0, vmeUnivOut, vmePicLint, specUnivOut, specPicLine, -1);
1005 *
1006 * The 'IRQ_MGR_SHARED' flag uses the BSP_install_rtems_shared_irq_handler()
1007 * API. CAVEAT: shared interrupts need RTEMS workspace, i.e., the
1008 * VME interrupt manager can only be installed *after workspace is initialized*
1009 * if 'shared' is nonzero (i.e., *not* from bspstart()).
1010 *
1011 * If 'PW_WORKAROUND' flag is set then the interrupt manager will try to
1012 * find a way to access the control registers from VME so that the universe's
1013 * posted write FIFO can be flushed after the user ISR returns:
1014 *
1015 * The installation routine looks first for CSR registers in CSR space (this
1016 * requires:
1017 * - a VME64 crate with autoid or geographical addressing
1018 * - the firmware or BSP to figure out the slot number and program the CSR base
1019 * in the universe.
1020 * - the BSP to open an outbound window to CSR space.
1021 *
1022 * If CSR registers cannot be found then the installation routine looks for CRG registers:
1023 * - BSP must map CRG on VME
1024 * - CRG must be visible in outbound window
1025 * CAVEAT: multiple boards with same BSP on single backplane must not map their CRG
1026 * to the same address!
1027 */
1028
1029#define VMEUNIVERSE_IRQ_MGR_FLAG_SHARED 1 /* use shared interrupts */
1030#define VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND 2 /* use shared interrupts */
1031
1032int
1033vmeUniverseInstallIrqMgrAlt(int flags, int uni_pin0, int pic_pin0, ...);
1034
1035int
1036vmeUniverseInstallIrqMgrVa(int flags, int uni_pin0, int pic_pin0, va_list ap);
1037
1038#endif /* __INSIDE_RTEMS_BSP__ */
1039#endif /* __rtems__ */
1040
1041#ifdef __cplusplus
1042}
1043#endif
1044
1045#endif
Definition: vmeUniverse.h:88
Definition: xnandpsu_onfi.h:181
vxworks compatible addressing modes
