RTEMS 6.1-rc1
usart_dma.h File Reference
#include "chip.h"
struct  UsartChannel
 usart Transfer Request prepared by the application upper layer. More...
struct  UsartDma
#define USARTD_ERROR   1
#define USARTD_ERROR_LOCK   2
typedef void(* UsartdCallback) (uint8_t, void *)
uint32_t USARTD_Configure (UsartDma *pUsartd, uint8_t USARTId, uint32_t UsartMode, uint32_t BaudRate, uint32_t UsartClk)
 Initializes the USARTDma structure and the corresponding USART & DMA . hardware select value. The driver will uses DMA channel 0 for RX and DMA channel 1 for TX. The DMA channels are freed automatically when no USART command processing. More...
uint32_t USARTD_EnableTxChannels (UsartDma *pUsartd, UsartChannel *pTxCh)
 This function initialize the appropriate DMA channel for Tx channel of USART. More...
uint32_t USARTD_EnableRxChannels (UsartDma *pUsartd, UsartChannel *pRxCh)
 This function initialize the appropriate DMA channel for Rx channel of USART. More...
uint32_t USARTD_DisableTxChannels (UsartDma *pUsartd, UsartChannel *pTxCh)
 This function disables the appropriate DMA channel for Tx channel of USART. More...
uint32_t USARTD_DisableRxChannels (UsartDma *pUsartd, UsartChannel *pTxCh)
 This function disables the appropriate DMA channel for Rx channel of USART. More...
uint32_t USARTD_SendData (UsartDma *pUsartd)
 Starts a USART master transfer. This is a non blocking function. It will return as soon as the transfer is started. More...
uint32_t USARTD_RcvData (UsartDma *pUsartd)
Implementation of USART driver, transfer data through DMA.
◆ USARTD_ERROR
An unspecified error has occurred.
◆ USARTD_ERROR_LOCK
USART driver is currently in use.
Typedef Documentation
◆ UsartdCallback
USART transfer complete callback.
◆ USARTD_Configure()
uint32_t USARTD_Configure ( UsartDma pUsartd,
uint8_t  usartId,
uint32_t  UsartMode,
uint32_t  BaudRate,
uint32_t  UsartClk
Parameters
pUSARTDPointer to a UsartDma instance.
pUsartHwAssociated USART peripheral.
usartIdUSART peripheral identifier.
UsartClkUSART clock.
pXdmadPointer to a Dmad instance.
◆ USARTD_DisableRxChannels()
uint32_t USARTD_DisableRxChannels ( UsartDma pUsartd,
UsartChannel pRxCh
Parameters
pUsartdPointer to a UsartDma instance.
pRxChPointer to TxChannel configuration
Returns
0 if the transfer has been started successfully; otherwise returns USARTD_ERROR_LOCK is the driver is in use, or USARTD_ERROR if the command is not valid.
◆ USARTD_DisableTxChannels()
uint32_t USARTD_DisableTxChannels ( UsartDma pUsartd,
UsartChannel pTxCh
Parameters
pUsartdPointer to a USARTDma instance.
pTxChPointer to TxChannel configuration
Returns
◆ USARTD_EnableRxChannels()
uint32_t USARTD_EnableRxChannels ( UsartDma pUsartd,
UsartChannel pRxCh
Parameters
Returns
◆ USARTD_EnableTxChannels()
uint32_t USARTD_EnableTxChannels ( UsartDma pUsartd,
UsartChannel pTxCh
Parameters
Returns
◆ USARTD_RcvData()
uint32_t USARTD_RcvData ( UsartDma pUsartd)
Parameters
pUSARTDPointer to a USARTDma instance.
Returns
◆ USARTD_SendData()
uint32_t USARTD_SendData ( UsartDma pUsartd)
Parameters
Returns
