RTEMS 6.1-rc1
This header file provides interfaces of the RTEMS Test Support. More...
struct | rtems_test_parallel_context |
Internal context for parallel job execution. More... | |
struct | rtems_test_parallel_job |
Basic parallel job description. More... | |
#define | RTEMS_TEST_INITIAL_EXTENSION { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension, NULL } |
Initial extension for tests. | |
#define | TEST_STATE RTEMS_TEST_STATE_PASS |
#define | RTEMS_TEST_PARALLEL_PROCESSOR_MAX 32 |
Typedefs | |
typedef struct rtems_test_parallel_job | rtems_test_parallel_job |
typedef void(* | rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
Worker task setup handler. More... | |
Enumerations | |
enum | RTEMS_TEST_STATE { RTEMS_TEST_STATE_PASS , RTEMS_TEST_STATE_FAIL , RTEMS_TEST_STATE_USER_INPUT , RTEMS_TEST_STATE_INDETERMINATE , RTEMS_TEST_STATE_BENCHMARK } |
Test states. | |
void | rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
Fatal extension for tests. | |
int | rtems_test_begin (const char *name, const RTEMS_TEST_STATE state) |
Prints a begin of test message using printf(). More... | |
int | rtems_test_end (const char *name) |
Prints an end of test message using printf(). More... | |
RTEMS_NO_RETURN void | rtems_test_exit (int status) |
Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code. | |
void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
Runs a bunch of jobs in parallel on all processors of the system. More... | |
void | rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds) |
Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread. More... | |
RTEMS_NO_RETURN void | rtems_test_run (rtems_task_argument arg, const RTEMS_TEST_STATE state) |
Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a task. More... | |
void | rtems_test_gcov_dump_info (void) |
Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char(). | |
const char | rtems_test_name [] |
Each test must define a test name string. | |
