RTEMS 6.1-rc1
test-gcov.h
2
11/*
12 * Copyright (C) 2013, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_TEST_GCOV_H
37#define _RTEMS_TEST_GCOV_H
38
39#include <gcov.h>
40
41#include <rtems/linkersets.h>
42#include <rtems/dev/io.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
58RTEMS_LINKER_ROSET_DECLARE( gcov_info, const struct gcov_info * );
59
68void _Gcov_Dump_info( IO_Put_char put_char, void *arg );
69
78void _Gcov_Dump_info_base64( IO_Put_char put_char, void *arg );
79
82#ifdef __cplusplus
83}
84#endif /* __cplusplus */
85
86#endif /* _RTEMS_TEST_GCOV_H */
This header file provides the interfaces of the Device I/O Support.
void(* IO_Put_char)(int c, void *arg)
This type defines the put character handler.
Definition: io.h:65
void _Gcov_Dump_info_base64(IO_Put_char put_char, void *arg)
Dumps the gcov information as a base64 encoded gcfn and gcda data stream using the put character hand...
Definition: gcovdumpinfobase64.c:95
void _Gcov_Dump_info(IO_Put_char put_char, void *arg)
Dumps the gcov information as a binary gcfn and gcda data stream using the put character handler.
Definition: gcovdumpinfo.c:79
This header file provides the linker sets API.
