RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions
This header file provides the interfaces of the RTEMS Termios Device Support. More...
#include <rtems/thread.h>
#include <rtems/rtems/intr.h>
#include <sys/ioccom.h>
struct  rtems_termios_device_context
 Termios device context. More...
struct  rtems_termios_device_handler
 Termios device handler. More...
struct  rtems_termios_device_flow
 Termios device flow control handler. More...
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(name)
 Initializer for static initialization of Termios device contexts. More...
typedef struct rtems_termios_device_context rtems_termios_device_context
enum  rtems_termios_device_mode { TERMIOS_POLLED , TERMIOS_IRQ_DRIVEN , TERMIOS_TASK_DRIVEN , TERMIOS_IRQ_SERVER_DRIVEN }
void rtems_termios_device_lock_acquire_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context)
void rtems_termios_device_lock_release_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context)
◆ RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER (   name)
Value:
rtems_termios_device_lock_acquire_default, \
rtems_termios_device_lock_release_default \
#define RTEMS_INTERRUPT_LOCK_INITIALIZER(_name)
Statically initializes an ISR lock object.
Definition: intr.h:853
Parameters
nameThe name for the interrupt lock. It must be a string. The name is only used if profiling is enabled.
Typedef Documentation
◆ rtems_termios_device_context
See also
RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(), rtems_termios_device_context_initialize() and rtems_termios_device_install().
