RTEMS 6.1-rc1
Data Structures | Typedefs | Enumerations | Functions
#include <bsp/irq-generic.h>
#include <rtems/irq-extension.h>
#include "tx-support.h"
#include <rtems/test.h>
struct  RtemsIntrReqEntryRemove_Entry
struct  RtemsIntrReqEntryRemove_Context
 Test context for spec:/rtems/intr/req/entry-remove test case. More...
typedef RtemsIntrReqEntryRemove_Context Context
enum  RtemsIntrReqEntryRemove_Pre_Vector { RtemsIntrReqEntryRemove_Pre_Vector_Valid , RtemsIntrReqEntryRemove_Pre_Vector_Invalid , RtemsIntrReqEntryRemove_Pre_Vector_NA }
enum  RtemsIntrReqEntryRemove_Pre_Entry { RtemsIntrReqEntryRemove_Pre_Entry_Obj , RtemsIntrReqEntryRemove_Pre_Entry_Null , RtemsIntrReqEntryRemove_Pre_Entry_NA }
enum  RtemsIntrReqEntryRemove_Pre_Routine { RtemsIntrReqEntryRemove_Pre_Routine_Valid , RtemsIntrReqEntryRemove_Pre_Routine_Null , RtemsIntrReqEntryRemove_Pre_Routine_NA }
enum  RtemsIntrReqEntryRemove_Pre_EntryObj { RtemsIntrReqEntryRemove_Pre_EntryObj_Installed , RtemsIntrReqEntryRemove_Pre_EntryObj_Match , RtemsIntrReqEntryRemove_Pre_EntryObj_NoMatch , RtemsIntrReqEntryRemove_Pre_EntryObj_NA }
enum  RtemsIntrReqEntryRemove_Pre_Init { RtemsIntrReqEntryRemove_Pre_Init_Yes , RtemsIntrReqEntryRemove_Pre_Init_No , RtemsIntrReqEntryRemove_Pre_Init_NA }
enum  RtemsIntrReqEntryRemove_Pre_ISR { RtemsIntrReqEntryRemove_Pre_ISR_Yes , RtemsIntrReqEntryRemove_Pre_ISR_No , RtemsIntrReqEntryRemove_Pre_ISR_NA }
enum  RtemsIntrReqEntryRemove_Pre_CanDisable { RtemsIntrReqEntryRemove_Pre_CanDisable_Yes , RtemsIntrReqEntryRemove_Pre_CanDisable_Maybe , RtemsIntrReqEntryRemove_Pre_CanDisable_No , RtemsIntrReqEntryRemove_Pre_CanDisable_NA }
enum  RtemsIntrReqEntryRemove_Pre_First { RtemsIntrReqEntryRemove_Pre_First_Yes , RtemsIntrReqEntryRemove_Pre_First_No , RtemsIntrReqEntryRemove_Pre_First_NA }
enum  RtemsIntrReqEntryRemove_Pre_Last { RtemsIntrReqEntryRemove_Pre_Last_Yes , RtemsIntrReqEntryRemove_Pre_Last_No , RtemsIntrReqEntryRemove_Pre_Last_NA }
enum  RtemsIntrReqEntryRemove_Post_Status {
  RtemsIntrReqEntryRemove_Post_Status_Ok , RtemsIntrReqEntryRemove_Post_Status_InvAddr , RtemsIntrReqEntryRemove_Post_Status_IncStat , RtemsIntrReqEntryRemove_Post_Status_InvId ,
  RtemsIntrReqEntryRemove_Post_Status_CalledFromISR , RtemsIntrReqEntryRemove_Post_Status_Unsat , RtemsIntrReqEntryRemove_Post_Status_NA
enum  RtemsIntrReqEntryRemove_Post_Disabled {
  RtemsIntrReqEntryRemove_Post_Disabled_Nop , RtemsIntrReqEntryRemove_Post_Disabled_Yes , RtemsIntrReqEntryRemove_Post_Disabled_Maybe , RtemsIntrReqEntryRemove_Post_Disabled_No ,
  RtemsIntrReqEntryRemove_Post_Disabled_NA
enum  RtemsIntrReqEntryRemove_Post_Installed { RtemsIntrReqEntryRemove_Post_Installed_No , RtemsIntrReqEntryRemove_Post_Installed_Nop , RtemsIntrReqEntryRemove_Post_Installed_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqEntryRemove, &RtemsIntrReqEntryRemove_Fixture)
