RTEMS 6.1-rc1
irq-extension.h
2
11/*
12 * Copyright (C) 2021 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36/*
37 * This file is part of the RTEMS quality process and was automatically
38 * generated. If you find something that needs to be fixed or
39 * worded better please post a report or patch to an RTEMS mailing list
40 * or raise a bug report:
41 *
42 * https://www.rtems.org/bugs.html
43 *
44 * For information on updating and regenerating please refer to the How-To
45 * section in the Software Requirements Engineering chapter of the
46 * RTEMS Software Engineering manual. The manual is provided as a part of
47 * a release. For development sources please refer to the online
48 * documentation at:
49 *
50 * https://docs.rtems.org
51 */
52
53/* Generated from spec:/rtems/intr/if/header-2 */
54
55#ifndef _RTEMS_IRQ_EXTENSION_H
56#define _RTEMS_IRQ_EXTENSION_H
57
58#include <rtems/rtems/intr.h>
59
60#ifdef __cplusplus
61extern "C" {
62#endif
63
64#ifdef __cplusplus
65}
66#endif
67
68#endif /* _RTEMS_IRQ_EXTENSION_H */
This header file defines the Interrupt Manager API.
