RTEMS 6.1-rc1
#include <tms570_selftest_parity.h>
Data Fields | |
unsigned char | esm_prim_grp |
unsigned char | esm_prim_chan |
unsigned char | esm_sec_grp |
unsigned char | esm_sec_chan |
int | fail_code |
volatile uint32_t * | ram_loc |
volatile uint32_t * | par_loc |
uint32_t | par_xor |
volatile uint32_t * | par_cr_reg |
uint32_t | par_cr_test |
volatile uint32_t * | par_st_reg |
uint32_t | par_st_clear |
tms570_selftest_par_fnc_t * | partest_fnc |
volatile void * | fnc_data |
Decriptor specifying registers addresses and values used to test that parity protection is working for given hardware module/peripheral. It is used during initial chip self-tests.
unsigned char tms570_selftest_par_desc::esm_prim_chan |
ESM primary signalling channel number.
unsigned char tms570_selftest_par_desc::esm_prim_grp |
ESM primary signalling group number.
unsigned char tms570_selftest_par_desc::esm_sec_chan |
ESM optional/alternative signalling channel.
unsigned char tms570_selftest_par_desc::esm_sec_grp |
ESM optional/alternative signalling group.
int tms570_selftest_par_desc::fail_code |
Error code reported to bsp_selftest_fail_notification() in the case of the test failure.
volatile void* tms570_selftest_par_desc::fnc_data |
Pointer to the base of tested peripheral registers. It is required by some test functions (CAN and MibSPI)
volatile uint32_t* tms570_selftest_par_desc::par_cr_reg |
Address of module parity test control register.
uint32_t tms570_selftest_par_desc::par_cr_test |
Mask of bit which cause switch to a test mode.
volatile uint32_t* tms570_selftest_par_desc::par_loc |
Address of mapping of parity bits into CPU address space.
uint32_t tms570_selftest_par_desc::par_st_clear |
Optional value which is written to status register to clear error.
volatile uint32_t* tms570_selftest_par_desc::par_st_reg |
Optional module parity status register which.
uint32_t tms570_selftest_par_desc::par_xor |
Bitmask used to alter parity to cause intentional parity failure.
tms570_selftest_par_fnc_t* tms570_selftest_par_desc::partest_fnc |
Function which specialized for given kind of peripheral/module mechanism testing.
volatile uint32_t* tms570_selftest_par_desc::ram_loc |
Address of memory protected by parity.
