RTEMS 6.1-rc1
rtems_fdisk_segment_desc Struct Reference
Flash Segment Descriptor holds, number of continuous segments in the device of this type, the base segment number in the device, the address offset of the base segment in the device, and the size of segment. More...
#include <flashdisk.h>
uint16_t count
uint16_t segment
uint32_t offset
uint32_t size
Typically this structure is part of a table of segments in the device which is referenced in the flash disk configuration table. The reference is kept in the driver and used all the time to manage the flash device, therefore it must always exist.
Field Documentation
◆ count
uint16_t rtems_fdisk_segment_desc::count
Number of segments of this type in a row.
◆ offset
uint32_t rtems_fdisk_segment_desc::offset
Address offset of base segment in device.
◆ segment
uint16_t rtems_fdisk_segment_desc::segment
The base segment number.
◆ size
uint32_t rtems_fdisk_segment_desc::size
Size of the segment in bytes.
