RTEMS 6.1-rc1
#include <capture_buffer.h>
Data Fields | |
uint8_t * | buffer |
size_t | size |
size_t | count |
size_t | head |
size_t | tail |
size_t | end |
size_t | max_rec |
Capture buffer. There is one per CPU.
uint8_t* rtems_capture_buffer::buffer |
The per cpu buffer.
size_t rtems_capture_buffer::count |
The number of used bytes in the buffer.
size_t rtems_capture_buffer::end |
Buffer current end, it may move in.
size_t rtems_capture_buffer::head |
First record.
size_t rtems_capture_buffer::max_rec |
The largest record in the buffer.
size_t rtems_capture_buffer::size |
The size of the buffer in bytes.
size_t rtems_capture_buffer::tail |
Head == Tail for empty.
