RTEMS 6.1-rc1
rtems_blkdev_stats Struct Reference
Block device statistics. More...
#include <diskdevs.h>
uint32_t read_hits
 Read hit count. More...
uint32_t read_misses
 Read miss count. More...
uint32_t read_ahead_transfers
 Read-ahead transfer count. More...
uint32_t read_ahead_peeks
 Read-ahead transfers caused by a peek.
uint32_t read_blocks
 Count of blocks transfered from the device.
uint32_t read_errors
 Read error count. More...
uint32_t write_transfers
 Write transfer count. More...
uint32_t write_blocks
 Count of blocks transfered to the device.
uint32_t write_errors
 Write error count. More...
Integer overflows in the statistic counters may happen.
Field Documentation
◆ read_ahead_transfers
uint32_t rtems_blkdev_stats::read_ahead_transfers
Each read-ahead transfer may read multiple blocks. This counts all transfers (including peeks).
◆ read_errors
uint32_t rtems_blkdev_stats::read_errors
Read error count.
Error count of transfers issued by the read or read-ahead requests.
◆ read_hits
uint32_t rtems_blkdev_stats::read_hits
Read hit count.
A read hit occurs in the rtems_bdbuf_read() function in case the block is in the cached or modified state.
◆ read_misses
uint32_t rtems_blkdev_stats::read_misses
Read miss count.
A read miss occurs in the rtems_bdbuf_read() function in case the block is in the empty state and a read transfer must be initiated to read the data from the device.
◆ write_errors
uint32_t rtems_blkdev_stats::write_errors
Write error count.
Error count of transfers issued by write requests.
◆ write_transfers
uint32_t rtems_blkdev_stats::write_transfers
Each write transfer may write multiple blocks.
