RTEMS 6.1-rc1
_snvs_lp_srtc_config Struct Reference
SNVS_LP config structure. More...
#include <fsl_snvs_lp.h>
bool srtcCalEnable
uint32_t srtcCalValue
This structure holds the configuration settings for the SNVS_LP peripheral. To initialize this structure to reasonable defaults, call the SNVS_LP_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
Field Documentation
◆ srtcCalEnable
bool _snvs_lp_srtc_config::srtcCalEnable
true: SRTC calibration mechanism is enabled; false: No calibration is used
◆ srtcCalValue
uint32_t _snvs_lp_srtc_config::srtcCalValue
Defines signed calibration value for SRTC; This is a 5-bit 2's complement value, range from -16 to +15
