RTEMS 6.1-rc1
sai transfer format More...
#include <fsl_sai.h>
Data Fields | |
uint32_t | sampleRate_Hz |
uint32_t | bitWidth |
sai_mono_stereo_t | stereo |
uint8_t | channel |
uint8_t | channelMask |
uint8_t | endChannel |
uint8_t | channelNums |
sai_protocol_t | protocol |
bool | isFrameSyncCompact |
sai transfer format
uint32_t _sai_transfer_format::bitWidth |
Data length of audio data, usually 8/16/24/32 bits
uint8_t _sai_transfer_format::channel |
Transfer start channel
uint8_t _sai_transfer_format::channelMask |
enabled channel mask value, reference _sai_channel_mask
uint8_t _sai_transfer_format::channelNums |
Total enabled channel numbers
uint8_t _sai_transfer_format::endChannel |
end channel number
bool _sai_transfer_format::isFrameSyncCompact |
True means Frame sync length is configurable according to bitWidth, false means frame sync length is 64 times of bit clock.
sai_protocol_t _sai_transfer_format::protocol |
Which audio protocol used
uint32_t _sai_transfer_format::sampleRate_Hz |
Sample rate of audio data
sai_mono_stereo_t _sai_transfer_format::stereo |
Mono or stereo
