RTEMS 6.1-rc1
_rtems_rfs_group Struct Reference
Creates bit allocator for blocks in the group simpler. More...
#include <rtems-rfs-group.h>
rtems_rfs_buffer_block base
size_t size
rtems_rfs_bitmap_control block_bitmap
rtems_rfs_buffer_handle block_bitmap_buffer
rtems_rfs_bitmap_control inode_bitmap
rtems_rfs_buffer_handle inode_bitmap_buffer
A group is a selection of blocks on the disk. Typically the number of blocks in a group is determined by the number of bits a block holds. This makes the bit allocator for blocks in the group simpler plus is allows a simple way to localise access to files and directories.
Field Documentation
◆ base
rtems_rfs_buffer_block _rtems_rfs_group::base
Base block number.
◆ block_bitmap
rtems_rfs_bitmap_control _rtems_rfs_group::block_bitmap
The block bitmap control.
◆ block_bitmap_buffer
rtems_rfs_buffer_handle _rtems_rfs_group::block_bitmap_buffer
The handle to the block bitmap buffer.
◆ inode_bitmap
rtems_rfs_bitmap_control _rtems_rfs_group::inode_bitmap
The inode bitmap control.
◆ inode_bitmap_buffer
rtems_rfs_buffer_handle _rtems_rfs_group::inode_bitmap_buffer
The handle to the inode bitmap buffer.
◆ size
size_t _rtems_rfs_group::size
The number of blocks in the group. Groups may be different sizes.
