RTEMS 6.1-rc1
Structure is used to hold the parameters to configure a PWM fault. More...
#include <fsl_pwm.h>
Data Fields | |
pwm_fault_clear_t | faultClearingMode |
bool | faultLevel |
bool | enableCombinationalPath |
pwm_fault_recovery_mode_t | recoverMode |
bool _pwm_fault_param::enableCombinationalPath |
true: Combinational Path from fault input is enabled; false: No combination path is available
pwm_fault_clear_t _pwm_fault_param::faultClearingMode |
Fault clearing mode to use
bool _pwm_fault_param::faultLevel |
true: Logic 1 indicates fault; false: Logic 0 indicates fault
pwm_fault_recovery_mode_t _pwm_fault_param::recoverMode |
Specify when to re-enable the PWM output
