RTEMS 6.1-rc1
_pmu_static_bandgap_config Struct Reference
Bandgap config in static mode. More...
#include <fsl_pmu.h>
uint8_t powerDownOption
bool enableLowPowerMode
pmu_bandgap_output_VBG_voltage_value_t outputVoltage
pmu_bandgap_output_current_value_t outputCurrent
Field Documentation
◆ enableLowPowerMode
bool _pmu_static_bandgap_config::enableLowPowerMode
Turn on/off the Low power mode.
  • true Turns on the low power operation of the bandgap.
  • false Turns off the low power operation of the bandgap.
◆ outputCurrent
pmu_bandgap_output_current_value_t _pmu_static_bandgap_config::outputCurrent
The output current from the bandgap to the temperature sensors.
◆ outputVoltage
pmu_bandgap_output_VBG_voltage_value_t _pmu_static_bandgap_config::outputVoltage
The output VBG voltage of Bandgap.
◆ powerDownOption
uint8_t _pmu_static_bandgap_config::powerDownOption
