RTEMS 6.1-rc1
PDM voice activity detector user configuration structure. More...
#include <fsl_pdm.h>
Data Fields | |
uint8_t | channel |
uint8_t | initializeTime |
uint8_t | cicOverSampleRate |
uint8_t | inputGain |
uint32_t | frameTime |
pdm_hwvad_hpf_config_t | cutOffFreq |
bool | enableFrameEnergy |
bool | enablePreFilter |
uint8_t _pdm_hwvad_config::channel |
Which channel uses voice activity detector
uint8_t _pdm_hwvad_config::cicOverSampleRate |
CIC filter over sampling rate
pdm_hwvad_hpf_config_t _pdm_hwvad_config::cutOffFreq |
High pass filter cut off frequency
bool _pdm_hwvad_config::enableFrameEnergy |
If frame energy enabled, true means enable
bool _pdm_hwvad_config::enablePreFilter |
If pre-filter enabled
uint32_t _pdm_hwvad_config::frameTime |
Voice activity frame time
uint8_t _pdm_hwvad_config::initializeTime |
Number of frames or samples to initialize voice activity detector.
uint8_t _pdm_hwvad_config::inputGain |
Voice activity detector input gain
