RTEMS 6.1-rc1
Test context for spec:/score/tq/req/surrender test case. More...
Data Fields | |
CallWithinISRRequest | request |
This member contains the call within ISR request. | |
SMP_barrier_Control | barrier |
This member contains the barrier to synchronize the runner and the worker. | |
bool | intend_to_block |
If this member is true, then the dequeued thread shall be in the intend to block wait state. | |
uint32_t | expected_blocker_b_counter |
If this member contains the expected counter of worker B. | |
TQContext * | tq_ctx |
This member contains a copy of the corresponding ScoreTqReqSurrender_Run() parameter. | |
struct { | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
ScoreTqReqSurrender_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
