RTEMS 6.1-rc1
Test context for spec:/score/tq/req/enqueue-fifo test case. More...
Data Fields | |
TQContext * | tq_ctx |
This member contains a copy of the corresponding ScoreTqReqEnqueueFifo_Run() parameter. | |
struct { | |
size_t pcs [1] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
ScoreTqReqEnqueueFifo_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
