RTEMS 6.1-rc1
Test context for spec:/rtems/timer/req/cancel test case. More...
rtems_id timer_id
 This member contains a valid id of a timer.
rtems_id id_param
 This member specifies the id parameter for the action.
rtems_status_code status
 This member contains the return status of the action.
int invocations
 This member contains the counter for invocations of the Timer Service Routine.
PreConditionContext pre_cond_contex
 This member specifies which pre-condition context (none, interrupt context, server context) must be created before the cancel action gets executed.
Timer_Classes pre_class
 This member stores RTEMS internal clock and context settings of the timer before the execution of the test action.
Timer_States pre_state
 This member stores the state of the timer before the execution of the test action.
Timer_States post_state
 This member stores the state of the timer after the execution of the test action.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTimerReqCancel_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
