RTEMS 6.1-rc1
Test context for spec:/rtems/task/req/construct test case. More...
rtems_id scheduler_b_id
 This member contains the scheduler B identifier.
unsigned int thread_zombie_ticket
 This member contains the thread zombie registry ticket right before the task exit of the zombie task.
volatile bool zombie_ready
 If this member is true, then the zombie thread is ready to get killed.
rtems_mode actual_modes
 This member contains the actual modes of the constructed task.
rtems_status_code status
const rtems_task_configconfig
rtems_task_config config_obj
rtems_id zombie_id
rtems_idid
rtems_id id_obj
bool create_extension_status
uint32_t create_extension_calls
uint32_t delete_extension_calls
uint32_t delete_zombie_extension_calls
uint32_t storage_free_calls
size_t stack_size
rtems_id extension_ids [2]
void * seized_objects
struct {
   size_t   pcs [15]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqConstruct_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
