RTEMS 6.1-rc1
Test context for spec:/rtems/sem/req/mrsp-obtain test case. More...
TQContext tq_ctx
 This member contains the thread queue test context.
rtems_id sema_id
 This member contains the MrsP semaphore to obtain.
rtems_id task_scheduler
 This member specifies the scheduler on which the task executes.
bool task_owns_mrsp_semaphore
 If this member is true, then the task shall already own a MrsP semaphore.
bool scheduler_a_idle
 If this member is true, then an idle task shall execute on scheduler A.
bool scheduler_b_idle
 If this member is true, then an idle task shall execute on scheduler B.
bool second_active
 If this member is true, then the second task shall be active.
rtems_task_priority second_priority
 This member specifies the priority of the second task.
bool third_active
 If this member is true, then the third task shall be active.
rtems_task_priority third_priority
 This member specifies the priority of the third task.
bool helping_active
 If this member is true, then the helping task shall be active.
rtems_task_priority sema_priority_scheduler_a
 This member specifies the priority of the MrsP semaphore with respect to scheduler A.
rtems_task_priority sema_priority_scheduler_b
 This member specifies the priority of the MrsP semaphore with respect to scheduler B.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSemReqMrspObtain_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
