RTEMS 6.1-rc1
Test context for spec:/rtems/scheduler/req/ident-by-processor test case. More...
Data Fields | |
rtems_id | second_scheduler_id |
This member contains the identifier of a second scheduler. | |
rtems_id | id_value |
This member provides the object referenced by the id parameter. | |
bool | cpu_has_scheduler |
If this member is true, then the processor specified by the cpu_index parameter shall be owned by a scheduler. | |
rtems_status_code | status |
This member contains the return value of the rtems_scheduler_ident_by_processor() call. | |
uint32_t | cpu_index |
This member specifies if the cpu_index parameter value. | |
rtems_id * | id |
This member specifies if the id parameter value. | |
struct { | |
size_t pci [3] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsSchedulerReqIdentByProcessor_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
