RTEMS 6.1-rc1
Test context for spec:/rtems/message/req/flush-pending test case. More...
rtems_id message_queue_id
 This member contains a valid ID of a message queue.
 storage_area [MAXIMUM_PENDING_MESSAGES]
 This member is used as storage area for the message queue.
rtems_status_code receive_status [NUMBER_OF_WORKERS]
 This member contains the returned status codes of the receivers.
rtems_status_code(* action )(rtems_id id, uint32_t *count)
 This member specifies the directive to be called as action. More...
rtems_id id_param
 This member specifies the id parameter of the action.
uint32_t * count_param
 This member specifies the count parameter of the action.
rtems_status_code status
 This member contains the returned status code of the action.
uint32_t count
 This member contains the value returned in parameter count of the action.
rtems_id worker_id [NUMBER_OF_WORKERS]
 This member contains the task identifiers of the worker tasks.
void(* check_msgq_unchanged )(void *ctx_in)
 This member contains a pointer to a function which is executed to check that the action has not changed the content of the message queue.
struct {
   size_t   pcs [6]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsMessageReqFlushPending_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
Field Documentation
◆ action
rtems_status_code(* RtemsMessageReqFlushPending_Context::action) (rtems_id id, uint32_t *count)
This is either rtems_message_queue_flush() or rtems_message_queue_get_number_pending().
