RTEMS 6.1-rc1
Test context for spec:/rtems/io/req/putc test case. More...
int output [2]
 This member contains the character output.
size_t output_count
 This member contains the character output count.
char character
 This member specifies if the c parameter value.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIoReqPutc_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
