RTEMS 6.1-rc1
Test context for spec:/rtems/intr/req/vector-disable test case. More...
bool interrupt_occurred
 If this member is true, then an interrupt occurred.
rtems_vector_number vector
 This member contains the current vector number.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_vector_disable() call.
struct {
   size_t   pci [3]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqVectorDisable_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
