RTEMS 6.1-rc1
Test context for spec:/rtems/intr/req/get-affinity test case. More...
rtems_vector_number vector
 This member contains the current vector number.
rtems_vector_number some_vector
 This member contains some valid vector number.
cpu_set_t cpuset_obj [2]
 This member provides the object referenced by the affinity parameter.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_get_affinity() call.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
size_t cpusetsize
 This member specifies if the affinity_size parameter value.
cpu_set_t * cpuset
 This member specifies if the affinity parameter value.
struct {
   size_t   pci [4]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqGetAffinity_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
